Question about HP TouchSmart IQ770 PC Desktop
Turn ons for 3 sec and then shuts off - HP TouchSmart IQ770 PC Desktop
  • Dana Newcombe
    Dana Newcombe May 11, 2010
    Please clarify for me that the desktop "completely boots up and then turns off or "starts" to boot up and shut down after three seconds.
    Guru:
  • 163 Answers
This is because of the power supply problem. Change the power supply and then check it .
Posted on Apr 27, 2010
My controls locked button light is on, pressing cycle button for 3 seconds does not turn it off. any other suggestions? thanks
Unplug the unit from the wall for 2 min's then plug back in and depress the lock button and hold until the beep or light shuts off. Sometimes it will take more than just 3 sec's and sometimes as long a 20 sec's,
Apr 02, 2011 | Kenmore 87562 Dryer
It doesn't want to shut off and we have no heat?
when you say it doesnt want to shut off i'm guessing you mean the fan. the fans run on a timer when the thermostat calls for heat it will come on 90-120 sec.later. turn your t stat down below room temp and it will shut off in 30-60 sec.your ignitor is most likly bad. turn your t stat back up and look at it. it should glow. furnace will try to light 3 times,you may hear the gas flow for 3 sec.during this cycle. if no glow good chance that is your problem and you will need to replace it.be carefull it is very brittle and breaks easy if tapped. be sure to turn the t stat down again or the fan will start running again.
Jan 26, 2011 | Coleman Propane Forced Air Heater...
I have a Dell Inspiron mini 10 . net book. Out of now where said something about windows and shut off ... now we cant get it to turn on, wont go past the inspiron load screen the little blue only goes...
tryt to do this
1.unplug the ac adapter
2.remove the battery
3.press the power for 30 secs
4.plug the ac adapter back in and after few secs try to turn it on
Oct 04, 2010 | Dell Inspiron Mini 10 Notebook
Panasonic pt47wx52cf tv shut off and wont turn
Please count red light flashes and let me know. There would be long pause between flashes so count pause to pause. It is an error code of TV problem.
May 18, 2009 | Panasonic Televison & Video
Reprogram remote
xl-7 programming instructions first you need to stuff your head up under the dash and locate your module drivers side upper corner under dash does it say programmable transmitter (the first models had no programable modules) if it says that then......
1 confirm all doors are shut and key is out of ignition
2 open drivers door insert key and turn to on within 10 sec
3 turn ignition switch to off in 10 sec
4 push and release drivers door switch 3 times in 20 sec
5 turn ign. switch to on in 10 sec
6 turn ign. switch to off in 10 sec
7 press and hold lock and unlock button on transmitter for 5 sec within 20 sec of step 6 alldoors will lock/unlockto confirm correct process
8 press lock unlock buttons on second remote within 5 sec after step 7 once again all doors will lock/unlock to confirm
9 to add another remote up to a max of four repeat steps 1 through 8 this was taken directly out of an owners manual supplement that comes with a new keyless entry kit (part number for a xl-7 or grand vitara can't remember which one it goes to but it works on either one is 84900-67810) which you would have to purchase if yours is not programable these instructions are the same for vitara, grand vitara, xl-7 and the esteem hope this helps
Jul 05, 2008 | 2002 Suzuki Grand Vitara
Dryer stays on for 3 secs and turns off; sometimes won't turn on at all.
sometimes the movement will cause the door to open, thus shutting off the dryer. Does the door shut tight when you close it? there is a little clip that if broken, the door will pop open easily. After it shuts off is it easy to start again?
Mar 12, 2008 | Dryers
My computer shuts down after 3 secs
Try to separate the power cord of your monitor from your system or maybe if your using UPS(uninterrupted power supply) directly plug the UPS to the wall outlet. either you can use pretty voltage regulator to the regulate the AC power.
if not solve the problem try to examine the your system power supply.
Dec 11, 2007 | Computers & Internet
HP TouchSmart IQ770 PC Desktop Logo
101 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
