Question about HP Pavilion dv6000z Notebook
Error 39, corrupt DVD/CD-Rom Drive
My DVD/CD-Rom drive doesn't work. It comes up with error 39, may be corrupt or missing
  • 1 more comment
  • Nick666 Mar 27, 2008
    Sorted, thanks a lot, it has worked!
  • Gammy2 Jun 18, 2008
    I have the same problem, what to do without having to take it to a computer store.
  • NormireX Aug 15, 2008
    I have a Sony CDU5211 and DW U10A drives. I just recently got the error 39.  I have tried to fix it using the regedit method but in my editor there are no Upper or Lower filters.........what can I do to fix the problem now?
    Master:
  • 351 Answers
Dear NICK,
its a windows registry related problem, you can fix it through :
This method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756/) How to back up and restore the registry in WindowsLog on to Windows by using an account that has administrator rights and permissions. Then, follow these steps. Step 1: Start Registry Editor loadTOCNode(3, 'resolution');Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor. Step 4: Restart the computer loadTOCNode(3, 'resolution');If a CD recording program no longer works after you restart the computer, you must reinstall the CD recording program.
Posted on Mar 24, 2008
What if there are no Upper or Lower Filters?  I have this same error but I don't see any Upper or Lower Filters to delete.
Posted on Aug 15, 2008
4 Suggested Answers
  • 1257 Answers
SOURCE: Error 39, corrupt DVD/CD-Rom Drive
Follow this article to fix the issue..
http://www.windowsguru.org/solutions.html
Posted on May 26, 2009
  • 97 Answers
This has been a common windows issue. I'm sure that this will solve your problem. You can go to this link, http://tinyurl.com/toshibadvd, download the registry file and run it. After that, just restart your computer and it should be good to go.
If you're not sure and is worried about security since this is messing with the registry, you can just click on this microsoft link where it explains and gives you detailed instructions on how to manually edit the registry and fix the problem. http://support.microsoft.com/kb/929461.
This is typically the same thing, the first one is just a shortcut on how to do it. Just a reminder, EDIT THE REGISTRY AT YOUR OWN RISK!!!
Posted on Sep 16, 2008
  • 13433 Answers
Heres the solution to that problem.
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
Posted on May 03, 2009
Got an error code 39 on my laptop what does it mean
error code 39 is:
Windows cannot load the driver
The driver might be corrupt or missing
suggests re-installing correct drivers
Sep 12, 2010 | Toshiba Computers & Internet
Driver is corrupted or missing?
Go to Dell website, check your model and download the Driver from there, reinstall it and check if it works.
Jun 17, 2009 | Dell DVD-rom DVD Drive
Drive not showing in WinXP (error code 39)Liteon Combo SOHC-5236v
After loading the Windows, the DVD/CD-ROM drives work properly, but we can not see the drives in “My Computer” (System can not recognize the drives.). When try to run the drives, it shows up a notice “Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code39).” Before solving this error, check the drives connection correctly, then follow the steps below:
Delete Device Manager. Most people will firstly think of Windows “Find New Hardware” when drives missed, but it does not always work out. To fix the problem: open “My Computer”’ “Control Panel” ’“System”’“Device Manager”’ “HDC(Hard Disk Controller) ”, then click “Delete”. Follow the note to reboot computer. After rebooting, the computer will find the Primary IDE Controller and Secondary IDE Controller again and install the drivers. Restart the computer again while the installation is completed. In this, we can get back our CD/DVD-ROM Drives.
The other way is by editing the registry to return the missed CD/DVD-ROM drives (Code 39 error.). Obviously, it is too risky to edit the registry if you are not familiar with it. To fix the error from the registry, carry out the following steps:
Exit and close all applications currently running on your PC.
Step1. Click Start > Run and type in Regedit, press Enter.
Step2. Look for the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
Delete any of the following registry entries under this key directory:
LowerFilters
LowerFilters.bak
UpperFilters
UpperFilters.bak
Step3. Reboot your PC and open My Computer to check that the CD-ROM drive is visible.
Also, have a look at the Device Manager to see if the yellow exclamation mark and the error code 39 are gone.
System errors are not welcome guests that bring up unhappy computing experience. Registry Easy (www.registryeasy.com) is a professional troubleshooting system maintenance tool that can help you to solve this error and many more.
Article Source: How to fix DVD/CD-ROM drives (Code 39 error) in Windows XP or Vista
Posted on 2 January '09 by , under TECH NEWS.
This worked for me.
Feb 12, 2009 | Lite On (SOHC5236V) CD-RW/DVD-ROM Combo...
! on my LG GCC4522B CD-RW/DVD-ROM
To solve this Code 39 error, follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Nov 21, 2008 | Computers & Internet
Sony CD Rom Ccdu 5212 not working
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Oct 25, 2008 | Sony (CDU5212) Internal 52x CD-ROM Drive
DVD/CD-ROM DRIVES driver may be corrupted or missing. (Code 39)
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Another possible CD/DVD issue you may want to investigate
Oct 12, 2008 | Computers & Internet
Mar 30, 2008 | Toshiba Satellite A205-S4617 Notebook
HP Pavilion dv6000z Notebook Logo
731 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
