Question about Panasonic PT-53WX42 53" Rear Projection Television
Convergence Resistors Hi. We've figured out that we have a convergence problem with our Panasonic PT53WX42F Rear Projection TV. Since it is so old, decided to try a DIY fix rather than putting a lot of repair money into an old set. We replaced the STK convergence ICs. When we powered up, we got the convergence distress signal (3 flashes on the Power LED) and can see a glowing, burned out part by one of the ICs. This is the dumb question: how can we be certain what replacement part to order? I'm assuming it is an IC resistor; it is one of 2 that are parallel to the IC, but is discolored and doesn't have readable numbers on it anymore; it's at postion C7004. There are 7 small white resistors that are perpendicular to this one and these appear to be 2.2 ohm. Any help is greatly appreciated.
  • 1 more comment
  • Anonymous Mar 24, 2008
    Sorry. It is a resistor. R7059. I found the service manual for the PT47WX33 series but unable to locate one for the 53WX42.
  • larmer2828 Apr 01, 2008
    I have the same tv, and having the same problem. Turned on tv and have yellow in right side of tv and blue's in background. Can someone please tell me what the part number I need to fix this problem? I want to try and fix myself. thanks
  • threets Apr 08, 2008
    We have the Panasonic PT-53WX42F, as well. We have red lines running horizontally which then dip down towards the right of the screen. Would the same resistor part correct this convergence problem?
    [email protected], Grandview, WA
Thanks so much. If you could post the link to the location of the service manual, we'll probably purchase for future reference.
Posted on Mar 25, 2008
  • Panasonic Master
  • 8,617 Answers
Can you check that location number again The parts list doesnt list a capacitor with that location number. Is the item a resistor or a capacitor ? Let me know the other site I work at has full service manuals with part numbers and specs in them. I will be able to tell you the specs on your part
Posted on Mar 24, 2008
  • Sonny Berry
    Sonny Berry Mar 25, 2008
    The resistor R7059 Is a 100K 1/10watt at 5% tolerance metal film/oxide(flame Resistant) The panasonic part number Is ERJ6GEYJ332V But any 1/10th watt 100K resistor will work as long as it is either metal oxide or metal film which are both flameproof for safety. If you need any more assistance please let me know I can post a link to the service manual also if you would like to purchase one. Good luck with your repair
SOURCE:
Have a Panasonic PT-47WX53 47. It's probably as old as when it came out. I've messed around with the convergence before but it was never un-fixable. Then a couple a days ago I came into the ro
yes and also possibly the low ohm resistors. You can get the PT53WX53 convergence kit which fits your model from www.tvrepairworld.com which has the 2 ICs and associated resistors plus the CD with repair instructions.
Jun 09, 2012 | Panasonic PT-47WX53 47" Rear Projection...
What is a convergence amplifier
The convergence amplifier is a three channel Integrated circuit which controls the convergence alignment of the three picture tubes in a rear projection TV. Your convergence amps are STK392-110 there are two of them also check the six 2.2 ohm 2watt resistors
Aug 06, 2010 | Panasonic PT-47WX49 47" Rear Projection...
My 10 year old tv goes off after about 5 minutes and the blue
Any colors mis alignments R,G,B.The tv have a problems known as convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced in the tv convergence board to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 17, 2010 | Panasonic PT-56WXF95 56" Rear Projection...
Tv wont turn on
You need 2 STK392-110 Convergence ICs and possibly 6 2.2 ohm 2watt resistors. You can get the convergence repair kit for your model from www.tvrepairworld.com the kit contains the ICs, resistors and the CD with instructions. The PT47WX42 convergence kit is the correct one for your model.
May 10, 2010 | Panasonic PT-53WX42 53" Rear Projection...
There are blue/yellow streaks across the bottom of the screen on my Panasonic rear projection tv model# PT53WX42F. The tv was manufactured in November of 2002.Need to know info on whether this is something...
Ur tv convergence are dead.U must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts and labors.
Apr 21, 2010 | Panasonic PT-51HX41 51" Rear Projection...
I have problem with my convergence rear projection panasonic
most of the time you need to change the stk392-110 chips an ome resistors let me know if you need more help
Jul 31, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic rear projection tv blinking one time will not turn on . tried to reset it but no luck
The 3 blinks is a error code for the convergence circuit. You can get the convergence repair kit for your model at the following link which contains both Convergence ICs and all six feed resistors and they include step by step instructions with pictures that show how to do the repair yourself. Heres a link to the proper kit for your model Panasonic.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Jun 15, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Convergence Problem
Replace the Convergence Ics and the six 2.2 ohm resistors. Heres a link to the proper repair kit for your model which contains both Ics and the resistors plus step by step instructions with pics on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
May 06, 2009 | Panasonic PT-53WX52 53" Rear Projection...
Panasonic cinema vision 1080 hd projection tv shut off and red
thats the error code for the convergence ICs. Replace both STK392-110 Convergence Ics and the 2.2 ohm resistors. You can get the Panasonic rear projection Convergence repair kit #1 at the following link which contains the two ICs and all six resistors plus step by step instructions with pictures so you can do the repair yourself.
Feb 14, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Failed resistor
those are the convergence feed resistors. # blinks on a panasonic means convergence IC failure. You will need to replace the two stk392-110 convergence ICs and the six resistors. You can get replacement ICs and resistors at the following link.
Sep 06, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
549 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
