Question about Kenmore Elite HE4 Electric Dryer
Unit work but do not heat-up - Kenmore Elite HE4 Electric Dryer
  • 78 Answers
THE ELEMENTSARE PROBALLY OUT, CHECK POWER TO UNIT, YOU SAID IT WORKS, THEN CHECK THE HEATING ELEMENTS, THESE GO OUT PRETTY OFTEN, ACORDING TO USE LOADS AND DRYING TIME THKS LARRY
Posted on Apr 27, 2010
Air conditioning worked all summer and now heat will not come on and outside unit will not run
Is this a heat pump or straight cool with heat strips. If straight cool the outdoor unit should not run in heat. If heat pump, did it work last year? If it did and now the outdoor unit will not run you likely have a bad control board. Possibly lost your settings in your tstat... check the stat first, make sure its configured for HP
Mar 17, 2017 | Heating & Cooling
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
Jun 02, 2016 | Heating & Cooling
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
Problem with Fujitsu minisplit heating
did you try to set to maximum heat? (suspect the thermostat is defective)
Oct 03, 2015 | Fujitsu AOU24RLXFZ Dual, Tri and Quad Zone...
Heating stops working all of a sudden
what kind of heater is this a household unit or a window unit... could be numerous problems if the heat starts to work is the fan continuing to run? also may want to check for obstructions such as a dirty coil which would make the unit get to hot and a limit is shutting unit off... what kind of unit and brand? i work on heating /air and all major appliances for over 17 years let me know
Dec 31, 2010 | Heating & Cooling
I have an intertherm rpbmb030k combo a/c and heat. Had frion put in the unit over the summer and a new digital thermostat. Unit has worked great until we needed heat. Unit works great on aux. heat but...
Hi, if the unit had a leak in it, was the leak located and repaired? Did he check the pressures in the unit now? If it switches to the aux mode ( Heat Strips ) is normally caused when your primary unit, compressor and freon are low on charge. I would have that checked.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Dec 03, 2010 | Intertherm P3RA-060K Air Conditioner
No heat/// blower works
First, check the duct work! The most common "no heat" problems with dryers are caused by duct work blockage. If your duct is blocked, it will overheat the unit, causing it to shut down the heat source (gas or electric, it doesn't matter). Most units will continue to "blow" without the heat. Remove the duct work, remove all lint from the duct and "exit" port of the unit. Then, check the wall duct, both inside and outside the house.
Feb 14, 2010 | Dryers
Duo therm roof air is stuck in the heat pump mode, it won,t cool
The control circuit board that controls the contactor for that unit is proboly damaged
If it is a heat pump. And not electric heat
Or the Yellow wire from the thermostat going to the unit that wont work in thecooling mode is broken,burned,or loose
May 26, 2009 | Heating & Cooling
Friedrich YM18J34 will not heat
Sounds like a bad limit switch. Open and test continuity on all limits with power off and at least one wire off one side of each
Jun 17, 2017 | Friedrich TwinTemp YM18J34 Air Conditioner
Kenmore Elite HE4 Electric Dryer Logo
87 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
