Question about Sony Cyber-shot DSC-T20 Digital Camera
Camara vibrates dear expert help on fixing the problem my camera keeps on vibrating, help on how to solve it.
  • R Swaroop Jun 29, 2008
    The camera vibrates and the shots are shaken. The camera does not shake - vibration is internal to the camera body.
Hi kundaj,
I wish there was a simple solution, but sadly there isn't.
It's the camera's lens motor system that's gone bad. Best thing you can do I think is get a replacement if you can and then extend warranty.
Cheers
Posted on Jun 03, 2008
Vibrating most of the time when it is turned on causing it to lose ficus and produce blurred pictures, is there a DIY way to fix this problem?
This problem can solve only to apply grease in the sliding bars of zoom lens,and no part required to solve this problem. against this problem sony has a technical news to solve this. The pics are given below where to apply grease please contact any expert who can do this job.
Thanks for using fixya.
Nov 09, 2009 | Sony Cyber-shot DSC-T20 Digital Camera
Sony dsc-t70 camara vibrates when turn on
it's actually a failure with the lens mechanism, I just experienced the same situation....Sony has another T20 that they had the same situation with and they offered to fix the cameras until July 2011..currently checking if Sony will fix this defect in this T70
what you are experiencing probably is best described by this article:
www.sonyinsider.com/.../dsc-t20-cyber-shot-camera-vibration/
Oct 25, 2009 | Sony DSC-T70 Digital Camera
if you alsow get vibrationOn Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
this was tested and worked on 2 additional cammeras
Sep 13, 2009 | Sony DSC-T70 Digital Camera
The camera wil vibrate much like if your cell
Vibration in this model is problem with lens assembly.
Qualified camera tech can fix it either by repairing lens mechanism or replacing it.
Aug 12, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Sony Alpha A100 shakes when I turn it on
It's actually, believe it or not, an anti-dust mechanism. All Sony Alpha A100's (mine included) do a little shake/vibration to help keep the dust off. It's nothing to worry about unless it lasts for more than a second.
May 14, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony dsc t20
I found the following shortly after posting my similar problem. It looks like Sony will fix the camera:
http://www.photographyblog.com/news/sony_cyber_shot_dsc_t20_problem/
Oct 17, 2008 | Sony Cybershot DSC-T200 Digital Camera
Vibration when using the Sony Cyber-Shot dsc-t20
Well, it seems that this is either a manufacturing defect or a defective/sub-standard part being used in the product. It would do Sony well to address this problem immediately so that all of us Sony lovers would continue to believe in their products. If this can be solved via a firmware upgrade then I hope Sony can guide us through it.
Feb 22, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Sony dsc t20
I had to send it back to repair. It was under warranty still so no charges. You should check the warranty they will fix the vibrating problem.
Feb 12, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Sony Cyber-shot  DSC-T20 Digital Camera Logo
118 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
