Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
I have a sony 55 in. lcd in the right lower corner there is a blue spot. can you tell me what is causing that to happen.
  • 175 Answers
It will probably be the polarized filters, it will get worse over time
Posted on Apr 27, 2010
I have a Sony KDF50WE655 with blue dots allover the right side of the picture, they are very define as a "mountain" from bottom to top, and is very high when against dark background, they told me I need the Light Engine replaced?, what do you think!....leelisto7414@socal.rr.com
Posted on Sep 06, 2010
I have a sony lcd projection tv model kf-60xbr800, green spots on the lower right corner , it start with one spot and now the spot are all over the screen
Those Rear LCD TVs get bad light engine on some. Causes fuzzy spots size of quarter. Or sharp small bright spots looks like road map or 'stars'. Need new/rebuilt light engine.
Apr 08, 2014 | Sony Grand WEGA KDF-60WF655 60" Rear...
Blue spots on Sony WEGA KDF60XS955
Thats caused by a bad optical block. The cost of that repair will almost always be greater than replacing the TV.Thats a very common issue with alot of Sony DLP models which suffered that optical block issue with the blobs of color usually blue or green
Dec 10, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Blue pixelation spots all over main viewing screen.
Your dlp chip needs replacing. It's a job to do but you can do it.
Jul 23, 2017 | Sony Video Cameras
I've noticed a dark patch in the lower right corner of the screen. Is this a bad panel or backlight? It's mostly visible in scenes containing blues.
Sounds like a backlight is out probably due to a bad inverter board. If you can see the spot when the tv is off its probably a bad lcd panel.
Mar 13, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony wega kdf55 has blue spot in lower right corner - how do I fix
That is a symptom of the light engine failing. that is the projector part of your TV where the lamp plugs in. Go to Sony's website to contact them and see if your model is still under extended warranty, if so they will help set up repair. If not it could cost several hundred dollars just for the engine plus labor. Good luck
Feb 06, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
The lower left hand corner of the screen is turning blue
catually is problum is related with blue lcd & blue polizer but first you clean the optical unit if the problum gon then ok other wise must chang blue lcd & blue polorize with uv filter plese contect to your nearst sony service centre
Feb 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Blue triangle growing on lower right side
He is most likely right--a burnt light engine will cause problems like this and is very expensive to replace--the set uses a hot lamp for brightness and it sometimes burns one of the optical lens in the engine--blue,red or green. Google the model number and you will see how much the part by itself costs.
Sorry, Steve
Aug 07, 2009 | Sony Televison & Video
Screen appears blue
Try Moving The Speaker You Have There Away From It?
www.Myspace.com/CrossRoadsToNowhere2007
Jan 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
Blue spot
the model number KP-51WS510 deosnt use a bulb or lamp. and touching the face of the lamp will not cause color problems in the picture. if your tv is an LCD projection then i would suspect the optical engine as the culprit. to check when you turn the tv off do you still see the blue distortion? if so then you have a bad optical engine.......as long as it is an LCD projection.
Apr 04, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
244 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
