Question about Maytag Dryers
Maytag dryer tumbles and heats but will run only 10-20 seconds before shutting off.
    Scholar:
  • 126 Answers
Is there an berrrrrr noise for 1 or 2 seconds when starting the dryer? this sound is a bad motor. another cause is loose power cord where it attaches to the dryer. 3rd is aluminum wiring from your breaker to the dryer outlet. these screws that hold the wiring at the breaker and outlet can loosen and should be tightened. give me some feed back so i can help.
Posted on Apr 27, 2010
MED9700SQ dryer sensor light comes on but will not run
I have the same problem with the same model Maytag dryer. I called a repairman and paid a hefty service charge and the repairman found that the electronic control board needed to be replaced. This particular part (Part #8558455) costs between $250 and $350. Evidently there are many people with the same problem.
Feb 02, 2013 | Maytag MED9700S Electric Dryer
Dryer is cool not getting hot?
1. Close the dryer door and press the "Start" button for at least one second. Some dryer brands require the button to be pressed for several seconds. If the drum tumbles, you can eliminate the possibility of a problem with the electrical circuit that supplies the motor.
2. Check all the connections on the back of the dryer. Many dryers have two electrical circuits--one for the heat and one for the tumbling motor. If the motor works, but there is no heat, check to see if the larger plug is plugged into its receptacle. Your dryer may have two plugs--one small regular household plug and one larger 240-volt plug for the heat. Both must be plugged in for the dryer to work properly. The larger, three-pronged 240-volt plug will not fit in a normal household outlet; it needs a special dryer outlet. The plug cannot be cut down to fit.
3. Check the circuit breakers or fuse panel if the dryer runs but there is no heat.
Jan 14, 2011 | Maytag PYE2300AY Electric Dryer
The dryer runs about 10 seconds then shut off. It
Maytag gas dryer , runs for about 15 sec. heats up , then completly shuts off , Checked thermal fuse & it was blown , replaced & it ran for about 15 sec again & blew fuse again ....help .
Apr 26, 2010 | Maytag PYE3300 Dryer
Maytag dryer runs and tumbles but will not heat up to dry clothes. model # LDG7500AAW, serial # A3351803. it does have flame but will not stay hot. Is this a thermostat problem?
I would suspect a faulty high limit thermostat is causing this problem. It is usually a small round, black device mounted on a small plate and attached to the internal ductwork with two screws. Hope this helped and best wishes.
Aug 05, 2009 | Dryers
Maytag pye2300ayw runs but does not heat.
hi..the reason to this problem is your heating
element might have gone bad.
check it out..
thank u..
kindly rate my response..
Jun 30, 2009 | Whirlpool LER5636P Electric Dryer
Dryer not heating...tumbles and blows OK - is 2 30 amp fuses enough
ELEMENT IS BAD NEED TO HAVE A SERVICE TECH REPLACE THE HEATING ELEMENT
May 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dry runs, but does not heat up
dude I just came here to find the same answer with my Maytag dryer! Just 10 seconds ago!
Apr 04, 2009 | Frigidaire GLGR331A Gas Dryer
Maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Mar 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
