Question about Lifetime 3819 Impact 44" Basketball Backboard & Rim Combo
How do you fix a fiberglass backboard - Lifetime 3819 Impact 44" Basketball Backboard & Rim Combo
I have a Spalding 60 inch glass basketball system. It was lowered all the way down and now it can't be raised because it's too low. How do I fix this?
In-ground Basketball Goals: Spalding 88369 NBA ...
www.atlantahoops.com > In-Ground Basketball Goals
The Spalding 88369 NBA Inground Basketball Goal System includes a 60'W x 36'H Pro style extruded aluminum framed Tempered Glass or Acrylic backboard ... Click here to download the Spalding 88369 Basketball Goal Owner's Manual
Jul 26, 2015 | Spalding 79307 Basketball Backboard and...
How is drywall properly installed in a home, the walls and ceilings in kitchens living rooms and bedrooms? Is it just nailed to the studs or does it have to have back on board behind it? But as backerboard...
First, insulation is put in on exterior walls with specific R ratings, drywall is just screwed to studs then spackled.in bathrooms it's a little different. There's different options for material backboard that are waterproof. Some are fiberglass then are finished in resin sealant
Feb 22, 2015 | Drywall
Huffy center court replacement backboard
you can go online like to ebay or some other dearler ship and search huffy center couter or (backboard) and there you go. Also its cheap
Mar 16, 2013 | Basketball
Broken tempered glass backboard
Garage/yard sales, craigslist. Do you know someone in the neighborhood who hasn't used theirs for awhile, Ask them if they will take $50 for theirs that may be in the way.
Apr 11, 2012 | Microwave Ovens
I am getting an E3 Error message on my temp
Do this...
The e3/e4 problem is the "connectors" for the fans to the middle separator shelf are put in the pathway of condensation. This causes them to get wet and rust. PLEASE NOTE: If you decide to attempt this fix, you take full responsibility for your fridge and the outcome. If you don’t think you can do this…DON’T! Call a licensed electrician. Here is how I resolved my e3 issue: 1) Unplug the fridge
2) Remove all wine and the metal shelves
3) Remove the 2 screws from the middle separator shelf, one on each side on top
4) Remove the 4 screws from the backboard, one in each corner
5) Slide out the middle shelf slowly, on the right hand side towards the front of the shelf there will be 4 connectors you must disconnect before removing the shelf (they are tucked into the shelf). With one hand on the backboard and one on the shelf, slowly take them out together
6) Once you have the backboard and shelf out, you'll see there is a black and white connector, each having a red and black wire on each side
7) These are the fan connectors that are causing the issue. Mine were brown/green and damp (not good for electricity)
8) Using wire cutters, cut as close as possible to the "black" connector on each side to remove it. You will have 4 wires left, 2 from the backboard and two from the shelf (both having a red and black)
9) Take some of the sheath (cover) off of each wire
10) Take the red wire from the backboard and the red wire from the shelf and twist the metal portion together
11) Cover w/ electrical tape!!! Or you will have the same e3/e4 issue
12) Repeat step 10 and 11 for the black wires
13) Move onto the "white" connector and repeat steps 8 - 12
14) Put the backboard and shelf back in the fridge. Be careful not to pull the backboard and shelf apart or your connection may come apart
15) As you slide the shelf in, make sure the wires you disconnected in step 5 are in the "channel" on the side of the shelf or the shelf won't slide properly.
16) Reattached the 4 connectors and then re-attach the backboard and the shelf with the screws
17) Plug the fridge back in
18) Put the metal shelves and wine back in
Feb 06, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
E3 error message on Magic Chef wine cooler MCWC44DZ. Can I fix it myself?
Taken from another poster at Home Depot reviews and similiar to what others have found...
" Sucks that a $0.10 piece of heatshrink on the connectors could avoid this...? Bad Design.
Jun 08, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Basketball pole
Ihave a pole and backboard but my backboard is cracked badly. Would you consider selling yours?
Apr 18, 2009 | Lifetime 3819 Impact 44" Basketball...
Basketball backboard problem
well it is probably a cheap backboard then. sorry
Nov 23, 2008 | Lifetime 3819 Impact 44" Basketball...
2 inch crack in shower pan fiberglass floor
I repair such fiberglass shower pan liners in the Philadelphia > NYC corridor. Generally, this fix should cost you between $150 and $500 depending on the size of the shower and how many people in your area do fiberglassing. I would strongly suggest having the entire shower basin re-fiberglassed as opposed to trying to patch the hole. However, a good fiberglasser should be able to fix this in a couple of hours for a few hundred bucks. If you are in our area, visit www.CFINJ.com and contact us. Brian
Mar 01, 2008 | Washing Machines
Lifetime 3819 Impact 44" Basketball Backboard & Rim Combo Logo
243 people viewed this question
Top Lifetime Sport & Outdoor - Others Experts
Vernon Taylor
michael vanier
Are you a Lifetime Sport and Outdoor - Other Expert? Answer questions, earn points and help others
