Question about Fisher PC-19S90 TV
Blue line on TV screen
When i turn the tv on its a black screen with a blue line across in the middle.
  • saveskee Mar 24, 2008
    help
  • 750GIXXER Apr 01, 2009
    AFTER TURNING THE TV THE SCREEN IS BLACK AND THEN THE BLUE LINE COMES ACROSS AND ITS TURNS ITS SELF OFF....
    Brigadier General:
  • 6,966 Answers
Hi
Your TV has a vertical fault. Based on your description, chances are that it is the vertical IC that went bad. It is relatively a simple repair job and any person with basic familiarity with electronic components and circuitry and soldering would be able to do the job. Should you venture to do a DIY please be reminded of the standard safe practices involve when working inside a TV unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 24, 2008
    New Friend:
Dan - can you please send me your instructions to fix the Vertical IC issue?
Posted on Oct 27, 2012
Where exactly is the vertical circuit located?
Posted on Nov 15, 2008
2 Suggested Answers
SOURCE:
  • 4234 Answers
SOURCE: NO PICTURE BLACK SCREEN AND A BLUE LINE ACROSS SCREEN.
The vertical circuit has failed. This can be as simple as poor connections on the pins of the vertical IC or a defective IC. If you can solder, you can fix this yourself. Let me know if you wish to attempt the repair and I'll provide details and instructions.
Dan
Posted on Apr 01, 2009
Blue line horizonally across the middle of the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 01, 2015 | Vizio VL470M 47 in. LCD TV
Hi I have a 55 inch LCD TV that while I was watching TV it went completely black when I turned it off and the on again there were rainbow vertical lines moving across the screen then at some points there...
My first thought would be to check your TV on multiple inputs to verify that it IS the TV and NOT isolated to your input cable(s). If you can get a solid blue color to come up on the screen by changing inputs then it would really narrow down the issue(s).
Hope this helps.
Jan 04, 2018 | Insignia NSLTDVD26 LCD TV
I have a sanyo DS35580 and there is a blue line across the middle of the screen
You haven't stated whether there is screen or picture. If you see only a blue line across the screen with high brightness, vertical output Ic of your TV has burned out. Don't switch on the set further or increase its brightness, till the fault is retified. Otherwise there will a phosphur burn occur where the blue line is now, and it is internal, whcih cannot be retified anymore.
Oct 16, 2010 | Sanyo DS31520 31" TV
Dan
Apr 01, 2009 | RCA TruFlat 27F520T 27" TV
Weird blue flash when tv turns on or off
TV will need service soon, blue CRT is on its way out, will need replacing
Mar 25, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony KF50WE610 Vertical Blue Lines Across Screen
the vertical blue lines indicate some interference from other electronic gadgets near your tv. it started showing up on my sony grand wega when i installed my wireless modem. i almost ordered a new rear projection lamp costing over $100 but decided to experiment. i first moved my desk computer farther away from the tv then isolated the wireless modem router by placing it inside a small glass - the vertical blue lines became lighter in color so i dedided to find another small glass that fit inside the first glass container then put the router in the double glass - no more blue lines and my wireless modem router still works.
do some deductive thinking to figure out what's messing up your tv and isolate the interference.
good luck!
Jan 18, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Blue streaks across picture
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
Jan 26, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Blue tint and lines on screen.
Those lines sound like "retrace lines" and several things can cause them. The most common are shorts inside the picture tube and shorted semiconductors in the video driver circuits. They can also be seen if the blue screen voltage is too high or if someone has tampered with the screen voltage control.
Jan 20, 2007 | Philips 28PW9536 28" TV
Fisher PC-19S90 TV Logo
2,812 people viewed this question
Top Fisher Televison & Video Experts
matt martin
matt martin
Mike
 Grubhead
Grubhead
Are you a Fisher Televison and Video Expert? Answer questions, earn points and help others
