Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Steam vac won't vacuum water back up from carpet well - 1/2 of upper tank emptied on carpet and only 2 Tbsp. in lower tank retrieved. What can I do?
Is that float stuck up stopping the suction?
Posted on Apr 28, 2010
Proheat sprays the water but doesn't suck it back up
Your lid is not on tight on the water collection tank it can't create a section to pull the water out. Usually take it off and putting it back on will solve the problem. good luck& God bless
Angela
Aug 23, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
SteamVac Carpet/Upholstery Deep Cleaner Vacuum: how do i add the solution to the steam vac? how mu...
You didn't give a model number so I'll tell you both methods. The F5xxx and F6xxx models have a cap at the top of the clean water tank that doubles as a measuring cup. The cap is about 3 inches in diameter. Fill the cap to the fill line with shampoo and dump it in the tank. Then fill the tank with hot (Not Boiling) water.
The F7xxx series has a 2 section tank. The large section is for hot (Not Boiling) water. The smaller section is for shampoo. Fill the smaller section with shampoo and the Steam Vac will mix the water and shampoo for you in the proper proportion.
May 16, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
How does lower and upper buckets work . is it the dirty water suppose to go in lower bucket or what . as i am trying to use this vac i am not able to
The Upper tank is for hot, clean water, with carpet cleaning solution mixed in at 5 ounces/gallon.
The Lower tank is the dirty water ecovery tank, hooked to the nozzle on the hood to **** up the water from the carpet.
Jan 01, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
The hoover steam vac 5 brush agitator dispenses water and soap but does not show any return water to dirty water reservoir. The carpet seems damp but not soaked, still a bit troubling no waste water...what...
You do not have the needed vacuum on the dirty water intake. Possible causes are:
1. No adapter sleeve in the back of the dirty water tank (the one that you remove to put the fabric hose adapter in)
2. The dirty water top is not sealed (cracked, not on correctly)
3. The intake shoot at the front of the unit is clogged with dirt/hair.
REMEMBER: This is NOT a vacuum cleaner - it is not designed to remove hair and dust.... ONLY wet dirt. If you fail to vacuum floors just before steam cleaning, the unit will clog up in minutes!!
Nov 24, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steam cleaner will not pick up the water the machine pu
Two checks:
(1) Is the lid aligned and sealed to the recovery tank
(2) Is the round rubber gasket installed on the tubular post under the hood, where the tank seals to the base? The tube extending down from the tank must sit on the rubber seal to get vacuum from the motor.
Sep 29, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Steam vac won't **** water
check to see if the recovery tank lid is on correctly. if this is not on, the machine will not **** up the dirty water from the carpet. all you will get is suction that is chopy when it comes up instead of more like a flow.
Jul 31, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Steamvac won't **** the water into the recovery tank.
This usually means one of a few things:
1. The lower tank is full
2. You did not dispense water (sloution tank empty), when applying solution to the floor.
Jan 19, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Upright Steam Vac, 12 amp
  • Check to make sure that the lower dirty water lid is installed and secure and not cracked.
  • Check to make sure the front duct panel is installed on the dirty water tank (this will transition the water from the front nozzle into the tank)
  • Check the filter in the dirty tank lid, clean if necessary
  • Remove the lower tank and look at the motor cover, locate a round hole, you should see a black ring (gasket).
  • with the lower tank removed, turn the machine on to check suction at the round hole, if OK then your problem will be with one of the above reasons
Jan 12, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac
in most cases you will need to replace the dirty water tank assy. this is usually around $40 to $50.
Aug 14, 2008 | Hoover F7431-900 SteamVac Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
205 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
