Question about Sewing Machines
I can't thread a jcpenney sewing machine that I bought used and have no manual for it. Model # 7000.serial #0152742.Thank you!
  • 4 Answers
Its got jc penney on machine this on back viking white sewing machine company,i have manuel i could send to your email vicky
Posted on Oct 04, 2014
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • 87 Answers
SOURCE: Threading a husqvarna viking 3610
This should be your machine:
http://www.sewingmanuals.com/Viking_Pics/Viking_3610i1.jpg
Sewingmanuals.com shows that they have this downloadable in Adobe PDF format here:
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Viking.htm
#37 in the list as of me posting this. You can get a CD version too but you'll just pay more and wait longer for the same thing. Once you have it print the manual (preferably both sides to keep it small) ang you'll have it. You can also peruse eBay to see if anyone is selling a manual but I doubt that will yield regular results. The machine looks to be pretty basic and standard but it's best you have the manual to get the most out of the machine. Also be sure to check the cleaning and lubrication section and go through the process so that the machine is in top working order before you put it into regular use - saves a lot of headaches.
Posted on Apr 28, 2008
  • 323 Answers
SOURCE: how to thread sewing machine
Yes, but it is a good basic machine.
Here's how to thread it:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Mar 20, 2009
  • 11 Answers
SOURCE: How to thread Kenmore 25 sewing machine Model 385
Hey if you need a new manual go to this link www.ifixmachines.com and dont forget to put this code (150t) so you can get $1.50 discount. Hope this help.. By the way the manual cost only $10. BYE
Posted on Jul 22, 2009
  • 139 Answers
SOURCE: how to thread & what needles for singer 660 A2 sewing machine
You can download a manual here:
http://parts.singerco.com/IPsvcManuals/
Posted on Apr 07, 2010
How do I thread my dressmaker 5700 model #18679 sewing machine?
Difficult finding info for your particular model, but this may be helpful:
Dressmaker 7000 Sewing Machine Threading Diagram
FWIW, sewing machines tend to thread very similar to other models.
Oct 15, 2017 | Sewing Machines
I need a manual for a JCPenney Model 6601. Or at least how to thread it.
Back in my 7th grade home ec class (I'm 52 yo now), our teacher told us that all machines thread basically the same and I never forgot that and it has served me well through the years. No matter what brand of machine, or level of machine (from little girls first one, my embroidery or my heavy duty industrial leather machine) they have all threaded the same:
Thread spool
thread guide
thread guide
tension
take up lever
thread guide
thread guide
needle
(the number of thread guides may vary)
Best of luck and happy sewing!
Dec 13, 2014 | Sewing Machines
Missing parts on singer sewing machine model 974 serial no. SH30010021
take it back to place purchased .have them correct the problem
Mar 15, 2017 | Singer Sewing Machines
New Home Type F threading bobbin take up
Perhaps one of these will help:
New Home Model 532 Sewing Machine Threading Diagram
New Home Model 2022 Machine Threading Diagram
Thread Bobbin on Newhome Sewing Machine
HINT: install a brand new needle. Remove the top thread from the machine. ALWAYS RAISE the presser foot and then rethread the top thread. The upper tension should start out set at the midway point. Use only fresh, good quality thread--AVOID old or bargain bin threads.
If the machine is threaded correctly top and bottom, but is still not catching the bobbin thread, then it's possible the machine is out of time. Search for sewing machine timing or take it for service.
Since it is an older mechanical machine, it is recommended to clean and oil the machine frequently. Oil Before using it if it has been in storage. If the machine is sticky, motor drags, etc., here's a good reference for getting it back in shape:
Wheel on right side that controls the needle up and down is very tight...
May 26, 2017 | New Home Sewing Machines
Need a manual for a free arm sewing machine model #6923
I looked for a manual for the machine, but I can't find one
I suggest that you go to these sites below & email them & ask them
about a manual for the machine
http://sewvacdoctor.com/
http://www.a1sewingmachine.com/
Sep 01, 2012 | Sewing Machines
Old JCPENNEY # 6915 Sewing Machine Manuals
check with the sewvacdoctor.com & ask them about the manual
Feb 23, 2012 | Sewing Machines
I cannot seem to get the top thread of my machine to pull smoothly through the tension disks. The machine was bought as JCPenney 25 years ago, no name brand-- Thank you!
Are you trying to pull the thread when the presser foot is up or down. Try this, rethread, then with the presser foot up, pull the thread it should feed smoothly, Now put the presser foot down, now the thread should barely move. Sometimes this seats the thread in the tension discs. Also, check your top tension control, I use 3 and maybe that will help you. Is your bobbin threaded right? Hopefully, this will help
Nov 14, 2010 | Sewing Machines
I need a operating manual for a JcPenney serger model 7015A
I have a manual for JCPenney serger 7015. How do I get it to you?
Jul 28, 2010 | Sewing Machines
Sewing Machines Logo
357 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
