Question about Kitchen Ranges
F2 E1 - Cancel key invalid on Kitchenaid range
F2 E1 - Cancel key invalid on Kitchenaid range model #KGST300HBT6 - color Biscuit. Other keypad numbers + features that also don't work: Bake, Control Lock, #6 + #9.
    Scholar:
  • 126 Answers
F2 E1 Cancel key. Cancel key invalid. Needs surface cleaning.
this is what the tech sheet says. But I am sure you did this. This type of failure looks to me that the glass control user interface needs replace. There is a 5% chance that is the control board. But very unlikely. let me know if you need help. Part 9754350CB
Part 9754350CB
part number 9754350CB
appox $230.00
Posted on Apr 27, 2010
Error code of E1 F2 on a kitchenaid double wall oven. What does that mean?
F2 - E1
Keypad cable unplugged
1.
Check keypad connector for firm connection (keypad connects to control
board).
2. Press CANCEL. If error code returns after 60 seconds, replace
keypad (also called touch pad or membrane switch). Some models incorporate
keypad in to control board as one unit. In this case, replace control board
(also called ERC or clock).
Feb 15, 2011 | KitchenAid KEBC207 Electric Double Oven
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Hi, I have Kitchenaid gas stove. the control panel shows the error code F2/E1.. What should I do to fix that?
Most of your F2 errors on stoves has to do with a stuck key. Use a hair dryer or a hot dish towel to warm up the keypad to loosen up that stuck key.
Jan 31, 2011 | KitchenAid KGST307 Gas Kitchen Range
F2 &F3 error codes, oven keeps beeping, I already tried turning off circuit breaker did not solve problem
F2
- E0 Shorted keypad (also called touch
pad) 1. Check keypad connector for firm
connection (keypad connects to control board).
returns after 60 seconds, replace keypad (also called touch pad or membrane
switch). Some models incorporate keypad in to control board as one unit. In this
case, replace control board (also called ERC or clock). F2 - E1 Keypad cable unplugged F2 - E5 Cancel key drive line open F2 - E6 Cancel key drive line open F3 - E0 Oven temperature sensor (RTD) opened (upper oven,
if double oven) Replace Oven temperature
sensor (RTD)
Note: Applies to all F3-E...
codes. F3 - E1 Oven temperature sensor (RTD) shorted (upper
oven, if double oven) F3 - E2 Oven temperature is too high (Cook
mode) F3 - E3 Oven temperature is too high (Clean
mode) F3 - E4 Oven temperature sensor (RTD) opened (lower oven,
if double oven) F3 - E5 Oven temperature sensor (RTD) shorted (lower
oven, if double oven) F3 - E6 Warming drawer sensor open F3 - E7 Warming drawer sensor
shorted
Dec 20, 2010 | Whirlpool Accubake RF362LXTT Electric...
My oevn will not work and range had the mesaage: F2:E3 and now F2:E1. Can diagnose the problem. Tom Wilson Thomas_Wilson@rush.edu
F2 - E1 Keypad cable unplugged 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
.com
Nov 26, 2010 | KitchenAid Ovens
Error f2:e1
F2-E1 - Touch Pad (Keypad) Cable Unplugged - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 15, 2010 | KitchenAid KESC307 Electric Kitchen Range
Kitchenaid YKGRT607HS6
F2:E0 is shorted keypad, and F2:E1 is no keypad connection, you need to replace the keypad.
You can find schematics and find replacements by entering model number here.
Dec 14, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
F2:E1
This has happens to us regularly. Today when it happened I unplugged the oven and let the it cool hoping that would help. It didn't. I did that several times over a couple of hours to no avail. When it powers up, there are a sequence of different readings on the screen before the error code comes up. In my final effort, just before the code F2:E1 appeared, and it read PF, I quickly turned on the oven and that interrupted the sequence. It is now working. Lucky. I hope this helps someone.
Apr 03, 2007 | KitchenAid KGRC707 Stainless Steel Gas...
Kitchen Ranges Logo
277 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
