Question about Dualit 20247 2-Slice Toaster
Dualit toaster toaster crackles then trips the electrics
  • 32 Answers
Please check with the Dualit Repair center and they can help you:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
[email protected]
www.electra-craft.com
Posted on Jun 05, 2008
SOURCE:
1978 ge toaster
Their website claims that the ProHeat elements fit toasters made in the last 50 years...
I would say take the thing to a good electrician, and she can inspect one of the ones that still works, compare it to the one that burnt out, and come up with some sort of fix...
Nov 19, 2013 | Dualit Kitchen Appliances - Others
Dualit toaster short circuit
Is not an open curcuit but a short curcuit. Means that one of the wire conections you have made is either contact with toasters body or one contact is touching with other contact. So you need to have all contacts of the toaster from the bottom side to see if their are clear to each other or from the toasters body
Oct 09, 2012 | Dualit 20084 2Slice Toaster
Dualit toaster sticking timer
This a common problem for all dualit toasters after some years since the timer is also a power electric contactor and the cotntact are sticking. Their is not any solution and you need to replace the timer with new one. You can buy a new one from ebay which the prices are very good and we have also one link how to reach the elements which will help you reach also the timer.
Nov 28, 2011 | Dualit 40352 4Slice Toaster
Trps the breaker as soon as switched on
Check the wire for any cuts, burns or kinks. You may have a short in the wire or inside the toaster (two wires are touching or arcing causing the breaker to trip).
Sep 16, 2011 | Dualit 40352 4Slice Toaster
The timer dial has stopped working. Is there an easy fix or does it mean a new timer from Dualit
This one of the most frequent problem of dualit toaster. Timer is also power electric switch whith contacts which from long time use they stuck due to sparking during contact. You need to replace the timer switch . you can find one at ebay is the same for all models. just take care the voltage 120v or 240 v. Als take a picture before remove the wires on the timer since you might forget how to put them back on the new switch since it can not be repaired
Jul 28, 2011 | Dualit 40352 4Slice Toaster
Toaster wont heat up
This one of the most frequent problem of dualit toaster. Timer is also power electric switch whith contacts which from long time use they stuck due to sparking during contact. You need to replace the timer switch . you can find one at ebay is the same for all models. just take care the voltage 120v or 240 v. Als take a picture before remove the wires on the timer since you might forget how to put them back on the new switch.
Jul 06, 2011 | Dualit 40352 4Slice Toaster
Our Dualit toaster doesn't work. The red light doesn't work. I have changed the fuse in the socket with a working one. The timer turns normally. Yet none of the heating units heats...
You need to replace the timer-contactor. This part is acting both as timer and electrical contactor. It consist from electrical contact moved with springs on and off. Due to electrical load and extreme heat these contact have been tear out thus they can not contact properly and in your case they don't contact at all.
So from the web page of dualit or ebay you can order A new timer contactor and replace it.
Jun 12, 2011 | Dualit Vario 3 Slices Toaster
Dualit Toaster trips RCD on consumer unit as soon as the timer switch is turned
One of elements, or one of the wires have be cut and is touching the metallic body so you need to replace the element or wire
Mar 09, 2011 | Dualit 20084 2Slice Toaster
Dualit toaster - timer sticking.
The dualit all electrical parts like elements and timer switch are all manufacture in china and they are not as they used to be. I have a customer with a toaster of 25 years old and we have replace only one heating element up to now. For recent models we replace electrical parts in about 2 to 3 years, some times every year as you describe.
Feb 22, 2010 | Dualit Vario 3 Slices Toaster
Dualit 20247 2-Slice Toaster Logo
344 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Herve Boissonnault
Herve Boissonnault
Ross Keen
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
