Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Airston AW122 washer will not drain or spin. Light blinks 5 times and dial turns round and round then stops but machine still will not drain.
  • 641 Answers
SOURCE: dial clicks round
Open the rear panel and look for a broken or worn belt. If this is the problem you can replace it easily. Good luck !
Posted on Jun 16, 2006
SOURCE: Washing machine will not drain
Will the water in tub come out when you take off the hose?
Posted on Mar 22, 2008
  • 20 Answers
SOURCE: machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Posted on Jan 19, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
pic498
  • 32 Answers
SOURCE: WILL NOT DRAIN OR SPIN AFTER WASH CYCLE HAVE TO JIGGLE DIAL
could be the timer or possible the lid switch. push your finger in the hole where the lid switch is and you should heard an audible "click". If it doesn't click then that's probably the problem.
Posted on Jul 20, 2009
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
My washing machine has just decided to stop before spinning and the dial continues to click round and round and round... Its still full of water...... What do i do?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Indesit Washing Machines
My airston a1237 washing machine is stuck on wash will not move on to rinse unless stop it and do it manually by the dial.
This sounds like it may be a timer problem.The timer isn't advancing on it's own unless you move it.Also make sure there isn't a button or setting thats been activated to stop the draining at that point.such as a Drip dry option.
May 29, 2010 | Washing Machines
Ariston washer dial starts turning and won't stop -no wash/spin..
CHECK THE PIPE TO THE DRAIN HOSE AND FILTER TRAP IF ONE FITTED IF BLOCKED CAN CAUSE THE SAME THING ESPECALY IF YOU HAVE A NON RETURN VALVE FITTED
Jan 05, 2010 | Ariston Technologies Washing Machines
Machine fills and agitates, but won't drain
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Indesit W123 5 flashes error!!
The F05 fault means the pump is blocked, check the filter at the front bottom right of the machine behind the plinth and if its connected under a sink check the hose & connection
Nov 03, 2008 | Indesit W 123 Front Load Washer
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
99 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
