Hi there! Perhaps you can help... I dropped my Canon IXUS 65 today and now have that "Lens Error, Restart Camera"message. Did you manage to fix it? What did you do? Sorry, I'm just ina bit of a panic mood now because it was so expensive when I bought it!Argh!!!
Cheers,
Susan
SOURCE: HiI have a Canon IXUS 80 IS digital camera. The
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
SOURCE: how to fix digital camera canon ixus 70 'lens
Would not recommend opening the camera as the chances are much greater
for you causing greater damage. BUT would instead recommend that you
try the seven sequential repair step outlined for a lens error in the
below listed Related Link "Fixing a Lens Error on a Digital Camera".
None of the steps outlined in this link involve opening the camera. and
reportedly you should have close to a 50% chance of success with these
techniques.
If you cannot repair the lens yourself with the
first related link, then consider trying the two 'Digital camera
repair" links below for two online digital camera repair businesses.
SOURCE: how to restart Canon IXUS 70
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they are just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
SOURCE: Canon Ixus 900 Ti ~ Lens error Restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
