Question about Samsung DualView TL220 Digital Camera
The zoom doesn't seem to be working... the camera was not dropped, so I don't know if the zoom is turned off or something, or actually broken.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 27, 2010
Will resetting my camera make the buttons work again? Is there a way to reset the camera without going to the menu (since the buttons don't work)?
Only the two buttons on top of the camera. It looks like you have a real problem. All buttons on the back look dead.
Reset of a camera is done every time you switch it on, so that will not bring any difference. One step up is removing the battery for a few moments, bit when the error keeps coming back, I think someone must have dropped the camera once, or some moisture came in the camera, and did something with internal connections.
When nothing helps and you did not drop the camera, check if it is still under warranty and contact a Olympus certified service centre.
DOn't send it in unless you know what it could cost. Sometimes repairs are more expensive than a new camera.
Jan 28, 2015 | Olympus Vr-340 16mp Camera Digital Optical...
My nikon D90 felldown from my hand and now the flsh not working ; i mean it pup up but no liting
Assuming you don't have the flash turned off, the most likely scenario is that the drop broke something. It could be a loose or broken wire, or a damaged flash tube. Without an actual examination it's impossible to diagnose the exact problem.
If you know how to repair cameras, you can order a replacement flash head here. Otherwise, take the camera in to an authorized Nikon shop and have them take a look at it.
Yes, I know either option will cost money. But if the flash is broken, it's broken.
Dec 15, 2011 | Nikon D90 Digital Camera with 18-200mm...
The zoom wheel does not stop when I want it to. It like it has its "own" will... Once I start zooming it goes all the way until the max. Sometimes when I make it (somehow... I don't know how)...
Hello.
It sounds like your camera's lens is broken. Did you accidentally drop it? When you shake your camera, do you hear something moving inside? Like a loose part? Or looking in the lens do see anything amiss?
Aug 13, 2011 | Panasonic Lumix DMC-FZ28 Digital Camera
I have the SD790 IS, and the zoom button seems to be stuck/sticking making it very difficult to get the camera to zoom (or playback to zoom) however, when it does, it "jumps" to where it wants to...
The SD790 has a problem with the power button and sometimes the zoom switch, thankfully they are on the same assembly. You can get a new part for $35 incl shipping, or have it installed for just $30 more.
Another design flaw of this camera is:
If you haven't checked the screws recently on the handstrap side of your SD790 to make sure they are tight, I would advise doing so. Actually, take them out and secure them with Locktite, because if you don't they will fall out and the whole side of your camera will fall off.
If you need the zoom switch replaced, I happen to know the shop linked below would check and secure your screws for you at no additional cost!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 11, 2011 | Canon PowerShot SD790 IS Digital Camera
Dropped Camera.
The lens motor mechanism is very fragile and will stoppworkin even if you look at it too hard let alone drop it.
The cost of repair will be high - best bet is to write it off[are you insured against accidental damage?]Check out the manufacturer off course.
Jan 15, 2008 | Panasonic Lumix DMC-FZ1 Digital Camera
Zoom Problem
The zoom are lock due to sudden dropped , the moving parts of the zoom dislocate or broken, the zoom malfunction,you try visit some camera juck shop or repair shop same brand to replce broken parts.
Dec 23, 2007 | Olympus FE-280 Digital Camera
Elura 60 Zoom Problem
Guys, so weird but on another site it offered this suggestion: banged the base of your camera against something hard and it will become unstuck. So bang the base of your camera against something hard and it will work again, at least it works like it did but not sure for how long. Good luck. I can't believe that worked. Give it a try. I didnt hit it too hard either.
Dec 20, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Eek,
non - motorized lens cameras , will survive more drops ( ebay it - as is - for parts ) ;
Aug 14, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Unable to get camera to stay on
Get the next one. If it is that costly. Certainly it seems that something is dislodged or shaken in side if not actually broken If you are up to it see if you can get some fine tools an take it apart. I'll be an educational exercise is nothing else. Meanwhile if you have household insurance investigate the possibility of an accidental damage claim.[the price of a new camera perhaps]
May 07, 2007 | Kodak EasyShare Z730 Digital Camera
Zoom Problem
There are two components to a camera lense. One adjusts the final lense distance from the CCD imaging chip the other adjusts the distance between the lenses in the assembly (which zooms the image in and out). It sounds like something inside the lense came loose and when you zoom the lense the focal lense is moving with the rest. The lense will probably have to be replaced if it cannot be taken apart. Odds are something is broken inside anyway. This could be something you might be capable of, I have no way of knowing. If you do not think you are up to the task, have a reputable repair shop do it. Cost should not be excessive. I would think less than $100 US plus the cost of the part. Good luck.
Jun 16, 2006 | Samsung VP-D103i Mini DV Digital Camcorder
Samsung DualView TL220 Digital Camera Logo
115 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
