Question about Dell Dimension 5100 (D51L1) PC Desktop
Hard drive not working
Hi i just put another hard drive in to my computer so now i have #2 but when its in my com will not start becoz it has win 95 on it so how do i fix it?
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    you are running win 95?..that's amazing..i'm not clear that support two drives, and finding drivers is almost non existent..
    maybe it's a museum piece you have there.
  • 655 Answers
OS does not matter how many HDD you have.
But OS must be put on your master HDD, b.coz when you put two HDD in a system one must be mater and another the slave.
There are Jumper settings in your Hard Disk to make one master or slave. Set this setting and then try to boot.
If you can tell me what you have in each disk, regarding OS, it will help me to give you proper support.
Ask Me for more details.
Thanks
Iqbal
Posted on Mar 24, 2008
Trying to put win 7 on hard drive says no bootable device insert boot disk and press any key put in boot disk and nothing
if you have win 7 on a disc and you want to put it on the hard drive , try this
on start up hold down alt+ delete to get into bios
change the boot up from hard drive to cd as primary start up boot up
put the disc in a cd and close it down
restart and the pc should then boot from the disc in the cd drive
you should be able also to simply put the disc in the cd, go to computer , click on the cd drive and run and that should put the win 7 on the hard drive
talk with a computer shop for other ideas as to how to do it if that doesn't work
Nov 29, 2016 | Cell Phones
I got "incorrect disk" error message when Win 95 access maxtor 91021u2
http://www.driverguide.com/driver/detail.php?driverid=673706
it would appear that there are no drivers for Win 95
I think it's time you upgrade your computer
Nov 28, 2013 | Maxtor Computers & Internet
I have a Seagate ST3200822AS 200 GB Hard Drive(windows XP).I want to use this as external but I don't want it to mix with HD on new computer(windows 7). How do I keep them separate and run one or the other...
Is the Seagate ST3200822AS an External Drive ( like USB connectivity ) or actual Hard Drive ? Even if it is Internal Hard Drive, You can make connect it to Win 7 and still keep it as Seperate Drive.
Connect the Hard Drive to Win 7 PC and Make it Slave ( partition ) by changing the Jumper on the Hard Drive ( jumper is a small pin or a lock that makes a Hard Drive Primary or Slave.
Once you connect the HD to Win 7, you will find new Drives Created in Win 7, this way you will differentiate between the Win 7 Drives and XP Drives
This link will how you the jumper position : Remove the jumper from slot 1 and put it in slot 2
http://www.google.com.sg/imglanding?q=changing%20jumper%20on%20Hard%20drive&imgurl=http://www.mysuperpc.com/build_your_own_computer/sata_hard_drive_connectors_jumpers_cr.jpg&imgrefurl=http://www.mysuperpc.com/build_your_own_computer/pc_install_sata_hard_drive.shtml&usg=__iTyJjkCN501Kstme6LZ42u0Q3ZU=&h=538&w=600&sz=95&hl=en&um=1&itbs=1&tbnid=2EXt5zyA0OXYxM:&tbnh=121&tbnw=135&prev=/images%3Fq%3Dchanging%2Bjumper%2Bon%2BHard%2Bdrive%26um%3D1%26hl%3Den%26sa%3DN%26tbs%3Disch:1&um=1&sa=N&tbs=isch:1&start=8#tbnid=t42Gq31Rw32OCM&start=13
Jun 30, 2010 | Seagate ST3200822AS 200 GB Hard Drive
How do I format C drive with windows 7 on it I want to put windows XP on
hi
thank you for using Fixya
to formate C drive and re install windows XP
1 put widows XP CD in to your CD drive
2 restart your PC
3 it will boot your CD just put Enter
4 if not then selact boot option by presing F12 0r F2
5 it will start reding your CD
then just folow the instruction
it will ask you foue setps
May 16, 2010 | Compaq Presario CQ60-220US PC Laptop
How to install windows xp into compaq presario cq40
compaq cq40 is one particular model from compaq which is literally designed for vista and when you want to install win xp ;it doesn't work becoz the BIOS block it;the only way out is to downgrade the system BIOS which is a risky thing.check your bios model and version and google for a lower version and download it and flash the ealier BIOS.gooogle more on How to downgrade BIOS
Sep 21, 2009 | HP Compaq Presario CQ50Z-AMD Sempron(TM)...
NTLDR MSSING, how can i solve this?
NTLDR is short for NT loader – a program loaded from the hard drive boot sector that displays the Microsoft Windows NT startup menu and helps Microsoft Windows NT load. So when it goes missing for some reason, your windows cannot load.
Cause:
1. Computer is booting from a non-bootable source.
2. Computer hard disk drive is not properly setup in BIOS.
3. Corrupt NTLDR and/or NTDETECT.COM file.
4. Misconfiguration with the boot.ini file.
5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
6. New hard disk drive being added.
7. Corrupt boot sector / master boot record.
8. Seriously corrupted version of Windows 2000 or Windows XP.
9. Loose or Faulty IDE/EIDE hard disk drive cable.
if there is attached drive ,remove the drive first before restarting the system if not then if you had access to another computer, copy the NTLDR and NTDETECT.COM which is available from the recovery CD which comes with computer. If you do not have the recovery CD, its available on microsoft site or is available from another computer using the same Operating System (Windows XP ). The location may be C:\i386\ntldr C:\i386\ntdetect.com use a bootable disc to restart the computer (the Win XP bootable CD or Win 98 bootable CD worked). After entering MS DOS mode, copy these 2 files to the C drive in the proper location. After restart, then pressing F10 on start up (used for system recovery ), then start the repair of Windows via system recovery This will reinstalled all Windows drivers and system files, while preserving all data on your computer.
Sep 16, 2009 | Computers & Internet
How to upgrade win 95 to winxp without removing files installed
A computer running Windows 95 WILL NOT RUN Windows XP in most cases. Post all of your hardware details and we can explore that further.
Most programs that run on Windows 95 WILL NOT RUN under Windows XP easily. There are some compatibility things you can try for each one, but most simply will crash, and some will seem to work for a while then crash at inopportune moments.
What you should do is buy an newer computer with Windows XP, remove your current hard drive, and put your current hard drive as a second drive in the new computer. You will have access to your documents, but your programs will not run.
Mar 14, 2009 | Intel Pentium III, 800 MHz...
I have a hard drive with windows 95 and i am trying to install windows xp professional addition but it comes back saying you can't intall this version of windows on this system
Windows 95 uses the FAT 32 system and uses a boot-up partition that will not recognize a windows xp default system install that uses the NTFS system. You can do it the other way around though, if XP is installed first, or another drive you have with XP on it is the first drive set to boot in your BIOS XP will recognize WIN 95 on its FAT 32 partition and either let you boot from that partition when you first start up your computer or when in XP right clicking a WIN 95 application and setting its properties to run as a Win 95 environment. Solution I would use if I were you would be to download Microsoft's free Virtual PC application from their website and run a full version of WIN 95 in its own virtual environment. Win 95 will run about 10 times faster than it ever would on its own partion if run under XP.
Aug 26, 2008 | Computers & Internet
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Dell Dimension 5100 (D51L1) PC Desktop Logo
29 people viewed this question
Alun Cox
