Question about JVC HR-XVC19S DVD Player/VCR
I can play dvds but not vhs. how do i hook it up or program it, etc, so I can watch vhs?
  • 566 Answers
Hi dave
To answer your question;
In order to watch both the dvd and vcr on the same tv input , you need to use the dvd/vcr output of your jvc.
The component output is for the dvd only.
So if you want to keep the component output for high definition when playing a dvd you can connect another rca cable from the dvd/vcr output of your jvc to another input on your tv when playing vhs.
If you want the owners manual online you can find it HERE
You`ll find all the info on page 11
Hope this help Good luck
Posted on Apr 27, 2010
LGRC389H will not play any type of dvds
presuming hooked up correctly and you get some message like no disc, cannot read disc, etc.
You have either a dirty or bad optical pickup in the player.
May 25, 2012 | LG RC389H DVD/VHS Recorder
We just bought a new 32" panasonic led tv. Hooked everything up and works fine with normal television broadcast. However, we have a Sony DVD/VHS combo hooked up that doesn't perform well. When we play...
If you are using the composite cables (RWY) make sure the red and white are plugged into the audio jacks and NOT the component cable plugs (RGB.) If you have the red audio cable plugged into the red component plug this will cause issues, especially with the sound.
Aug 10, 2010 | Panasonic Televison & Video
DVD/VHS combination will play brand new DVDs but will not play
does your vhs/dvd can copy to copy from dvd to vhs, if yes this might be the problem.
May 29, 2009 | Philips Magnavox 27MS343S 27" TV
Can't see dvd on TV
how to hook up to watch dvds
May 25, 2009 | Sansui VRDVD4005 DVD Player/VCR
How to record ditigally on old comb tv/vhs
If you have the box hooked up to your 1996 combo turn or tune on channel 3 if the converter box is selected to channel 3 you should get all your digital reception from the box to your tv/vcr. Select what you want to watch or tape on the box, what you see on your tv will record to your vcr when you select record.
Jan 14, 2009 | Televison & Video
Tv/digital converter box & vcr-dvd hook-up
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Seinfeld DVD episodes won't play
It is probably not your VCR. If it is only the Seinfeld DVD's then the format that the production company wrote on those few episodes are incompatible with your vcr. I know I'm not solving your problem much, but don't go waste money on a brand new Vcr when not needed.
Nov 24, 2008 | JVC HR-VP650 VHS VCR
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Vcr - dvd player problems
I just got done recording a vhs to dvd and it worked great. Also you can print the manual at manualsonline.com or something like that.. google it, i printed mine. I had to watch the enitre vhs to record it. As you are playing the vhs (right at the beginning) push the blue D. Dubbing button then when its done playing push stop on the DVD side it will say writing to disk on the bottom once thats done ooha la!! I am trying to figure out if there is a way to dub a vhs to dvd without having to watch the howl movie but unfortunatley I don't think there is!
Apr 06, 2008 | Samsung DVD-VR325 DVD Recorder/VCR
Watching videos on a computer
Yes. DVDs are easy as you probably already know, you just need a DVD capable drive and appropreate software to play. VHS tapes are another matter altogether. You'll have to purchase something that will convert the analog signal from the VHS player to a digital signal your PC can use. I have a device I use to convert VHS tapes to DVD (ADS technologies) I could use to watch tapes but the software leaves a lot to be desred.
Feb 20, 2007 | Samsung DVD/VHS/MP3/SVHS Playback
JVC HR-XVC19S DVD Player/VCR Logo
127 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
