Question about Roper REX4634KQ Electric Dryer
I have a roper dryer. I took it apart today
I have a roper dryer. I took it apart today because sometimes it would take 3 times on a timed cycle before the clothes would dry. The vents are clean. The heating coil is working because I saw it heat up. I put everything back together and now the timer goes down to the cool off cycle but will not turn off automatically. It continues to run unless I manually turn it off
  • 10,319 Answers
Remove all duct work connected to this dryer. Clean thoroughly. You will find amass of lint inside of it causing your problem. If not the moister sensor is not working properly and needs to be replaced.
I do hope you will find a clogged vent tube for it is easier to clean the tube than to replace the sensor. The sensor is a fail safe part. It keeps the dryer from catching on fire when the lint tube is clogged up
Posted on Apr 27, 2010
I have a Roper Mod:REX4634JQO Electric Dryer. The Dryer does not fully heat up on any of the cycles. I have to run the cycle twice, sometimes 3 times (50 minutes each time) to dry my cloths. Any ideas of...
either your heating coil is damaged or you have a bad resistor in the back of the panel ...any tech can take a look and tell...the resistors run about 20.00 the coils on the other hand may turn out to be as high as 200.00 plus labor..hopefully it is the resistor..GOD bless
Sep 18, 2017 | Roper REX4634KQ Electric Dryer
Heat is not always coming on in dryer. Roper dryer from Lowes
There are numerous temperature sensors on the dryer. Some are near the drum, some could be near the lint filter if it is located inside the dryer door. Try changing these first as they are an in expensive fix. It could also be the heating coils themselves. Highly unlikely it would be the dial, unless the dial was accidentally turned in the wrong direction.
Apr 26, 2010 | Roper REX4634KQ Electric Dryer
Dryer will not get real hot
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Oct 21, 2009 | Roper Dryers
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Roper dryer drum has to be manually turned a few times
Sounds like the belt is slipping
Mar 20, 2009 | Dryers
Roper Dryer model # RED4405Q shutting off
The motor may be getting hot due to bad rolers idler or glide. You need to take the machine apart and oil it. While you have it broken down you may want to turn the motor and see if it is stiff. The motor can be oiled but it is tricky. there are no oil ports you must make some. I use zoomspout oiler from ace hardware. Its high temp resistant formula and viscosity is perfect for dryers and HVAC needs.
75ddae3.jpgI have various essays on accessing these machines and diagnosis HERE
Mar 02, 2009 | Roper REX4634KQ Electric Dryer
I have a very old roper dryer (11 yrs), it quit mid cycle. It ticks when I set the timer but nothing happens. The on button quit along time ago but when you shut the door it would start. Today nothing...
You've got an open circuit somewhere in the loop betwixt the start button, the "safety" button actuated by the door, and the motor/heat coils. Trace out those circuits and you'll have that thing running in no time.
Feb 27, 2009 | Roper REK2950W Electric Dryer
Roper dryer no heating properly
Have you checked the lint trap and made sure the entire exhaust is clean? You may have a bad control switch that won't allow it to ignite on medium. The bigger problem is the short time cycle. Something is telling it to shut itself off for safety reasons.
Feb 11, 2009 | Roper RGS7646KQ Gas Dryer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Roper REX4634KQ Electric Dryer Logo
258 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
