Question about Eureka 4467AV Upright Vacuum
Nothing is going into the waste basket when i vacuume
  • 50 Answers
Do you mean the "bag"? If so you have a clog. The first thing is to check is the on board tool hose. Remove the hose from the machine and check suction at the end of the hose. If you have no suction there the clog is between the end of the hose and the bag. Open the bag door and remove the bag. You will have to use a coat hanger wire, make a small turn at one and slowly put it though hose to unclog. If you have suction there, check the section of hose between there and the head of the vacuum with coat hanger wire. If nothing there, then remove the base plate and check the inlet for the dirt there. You should also check to make sure the belt still turns the brush roller, if not replace it.
Posted on Apr 27, 2010
Is the motor shot when it makes a loud noise?
Hi! If you notice a change in your motor's pitch, that may mean your filter needs cleaning. Try removing the filter and tapping it clean in your waste basket. If that doesn't help, just let us know. You can reach us here on Fixya, at Facebook.com/DirtDevil, or @DirtDevil on Twitter. Hope this helps!
Oct 14, 2014 | Dirt Devil BD10125 Gator Bagless Hand Held...
I have a Beam SC375C vacuum system and can't remove the basket
go to web page for troubleshooting and help:
http://www.beamvac.com/usa/support/trouble_shooting.aspx
God bless you
Jul 24, 2012 | Vacuums
Saeco Grind and Brew model IDR 008 TG first the grounds were backing up and door not opening to go into basket, cleaned the dispenser per directions.. now the beans do not even grind at all nothing is...
Your grinder needs cleaning- maybe oily beans got used and/or storing beans in refrig/freezer? Both are a problem for grinder. Also, grinder should not be set to "fine"- it will definitely cause clogging and the situation you point out. ----------- The powder from the coffee grounds seems to get caked in the grinder. The only way to get it out is to run hot water into the little opening where the grounds funnel into the filter basket. --------- This will help.Thanks.Helpmech.
Aug 25, 2011 | Saeco Vacuums
Not picking stuff up and no suction in hose as well, suction sounds good until you go to vaccuum floor
Because this unit is bagless there are more gaskets to seal the suction portion of the vac. you are most likely missing a seal, can you remove the basket and place your hand near the suction on the vacuum? it is shielded so you wont lose fingers. if there is suction there, look at the bottom of the basket for a gasket, same for the top
Jan 01, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
No Suction + loud Noise
motor is probably is full of dust or needs replacing
May 11, 2009 | Vacuums
IRobot 5800 Scooba Vacuum dirt not going into the fliter basket
You can try rinsing the tank very thoroughly with warm water. Be very sure that you rinse the four ports on the underside of the tank (one round, two oval, one curved like Scooba's filter) very thoroughly, because all the dirt and dirty water moves through those openings and can clog things up.
Fembot
Jan 02, 2009 | iRobot 5800 Scooba Vacuum
Chatter
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11557&thid=576381
Chatter
Posted by CANRN on May 06, 2008
We have a Kirby Ultimate G. Since we purchased it bounces across the floor and the level of the sweeper has nothing to do with it. To get it to stop, it has to be at the highest level. The place we bought it, has done nothing to help us. We tried a new beater brush, no help. If I have to use it at it's highest level to sweep my carpet, I might as well not waste my time. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Kirby Ultimate G Bagged Upright Vacuum
The only thing I can suggest is that the brushroll could be in backwards, as you look @ the bottom of the brushroll from the bottom plate, the head of the screws should be facing the floor on each side of the brushroll, so check the brushroll because I thing that is what is happening, what you can do is adjust the brushroll down using the screws doing a ¼ or ½ turn
Until the brushroll stops bouncing across the floor, once you get it adjusted correctly then raise the height adjustment to the highest level and adjust downward to listen for the tone to change and then try it, it should work and if not go down one more adjustment – also change the belt every 4 to 6 months as recommended by the manufacturer. Feel free to contact a local vac dealer in your area for the brushroll height adjustment if you have problems. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
For a owner manual contact the Kirby Factory Dealer.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Don – The Vac Man
Go Ahead. Use Us.
May 06, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Hair gets stuck in upper filter basket instead of going into the lower basket that you are supposed to empty. It is a Bissell 37604 Lift-Off Revolution Pet Bagless Upright Vacuum Cleaner
Check both filters. If one or other is increasingly dirty, wash or clean it out. Also check the air waves leading to the bagless bin canister part. If one air way is blocked the remaining dirt will try and access the bin other way due to the natural vacuum suction aspect.
Apr 19, 2008 | Vacuums
Eureka 4467AV Upright Vacuum Logo
89 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
