Question about SK Electricians Starter Tools Meets IBEW Specifications 18-Pc. Set
I have three old cloth electrical wires coming out of a cable and their colors have faded. i can not detemine which are hot and neutral, any sugestions?
  • 2,100 Answers
Get out the tester and try one with the other end of the tester on a piece of metal in the box. If it is not grounded, it won't light up, but you can test it against the other 2 wires, Both neutral and ground will light up the tester with the hot wire, if you touch 2 wires and nothing happens, assume they are white and neutral. so the last one is hot. Only in a very modern fuse box where everything is polarized, ( and you have cloth wires so I don't think this is you), will a white wire differ from ground. They are both bolted to the same bar in the panel. Hope this helps.
Posted on Apr 27, 2010
I am hooking up a leviton 1755 3 rocker switch that controls a light, fan, heater all in one ceiling unit. The old switch had the white wire in the top switch, one black in the middle and the other black...
1) Look at screw color.
New device has brass screws on one side, and 1 silver screw for each switch located on other side of device.
Hot wire goes to brass screw.
Wire to fan goes to one silver screw
Wire to light goes to another silver screw.
Wire to heater goes to another silver screw.
If you do not have a wire for each individual Load, then you will have to add wiring.
2) Electricians don't guess, they test.
Separate wires for testing.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire.
Hot wire connects to brass-colored screw.
If any wires on old switch was connected to same Hot wire, then also connect that wire to brass-colored screws.
Hot wire is identified.
Test Hot wire to each other wire in box, except bare ground.
Tester lights up on Neutral wire. Neutral wire will NOT connect to this switching device.
Next, connect one of the remaining wires to a silver screw.
Turn power ON.
Flip switch to see what Load that wire controls.
By process of elimination, add wires to each silver screw and test each by flipping switch.
Breaker will trip if you connect Neutral to silver screw.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on circuit.
Jan 10, 2011 | Leviton 003-1755-W Three Rocker Switches
Old electrical box has 3 black wires. new device has 4 colored wires (white, red, green-ground, black - hot), the box does not have a ground wire (that I can see) and the old device only had three wires. ...
Early installations grounded the neutral line at the transformer, but did not bring in a direct ground wire as required for modern installations. White is neutral and should be connected back to the transformer secondary center tap. You will need to drive an 8-foot grounding rod near the panel and bring the ground connection into the box grounding bar (tied directly to the box as opposed to the neutral bar which is insulated from the box). Red and black wires are for 220 volt connections back to the transformer and feed each breaker on that particular rail with 110 volts. Any dual 220 volt breaker will contact both vertical rails. Each light and outlet in the house should have a ground connection, a neutral connection, and a 110 volt connection. Always place a switch to interrupt the 110 volt connection, not the neutral connection. You will likely need to measure the voltage across the suspected two hot wires to confirm the incoming 220 volt lines. Hope this helps!
Dec 27, 2010 | Garden
I need to know what screws are for what 2 black, 1 gold 1 silver
You are install a switch-receptacle combo.
As you have realized, screw color is the key.
1) Black hot wire connects to dark colored screws.
Both dark screws are connected together with brass plate, so hot wire only needs to connect to one of the dark screws.
2) Wire going to Load (light,fan, motor) connects to brass colored screw.
3) White neutral wire connects to silver colored screw.
4) Lets look at problem as if new wiring device is replacing old on-off switch that has two wires.
So old on-off switch has two wires >> one is black hot wire, and other is wire going to load.
Separate wires, turn on power and test each wire to bare ground wire.
Tester lights up on hot wire. This wire goes on dark screw.
If old on-off switch had another wire connected with the hot wire, that wire also goes on the dark screw.
The other wire from old switch is the Load wire, and it connects to brass colored screw.
Now you need a neutral wire.
In back of box are white wires twisted together and covered with wire nut.
These are neutrals.
To confirm that these wires are neutrals >> turn on power and test hot wire to other wires in box. Tester lights up on neutral.
Neutral wire connects to silver screw, and this will complete the circuit for any electric device plugged into receptacle.
If box does not have neutral wires as described above, you can violate code and connect bare ground to silver screw >>> but do NOT do this if your new plug is going to be used regularly.
You can use bare ground temporarily until additional wiring is made available.
Dec 14, 2010 | Leviton 10 Brown Switch Outlet...
I have a combination single pole switch. Light switch and receptacle. In have running in the old box 2 white, 2 black and a ground. How do I install the new switch to have power to the light switch and...
You are replacing old switch-receptacle device.
New device also has switch and receptacle.
You want switch to control light, but not receptacle.
You want receptacle 'hot' all the time.
You have 2 cables that enter box.
Each cable has white, black and ground wires.
Ground wires are twisted together and attached to green ground screws and not discussed more.
Screws on new device:
Side 1 of device: New device has dark screw(s) or brass screws on one side ... these screws are connected together by brass plate. This side is the Hot side of device.
Side 2 of device: Other side has 2 separate and unconnected screws. These screws are not connected in any way. Each of the 2 disconnected screws sits opposite the switch and opposite the plug.
Cables.
One cable comes from breaker box. This cable has a Hot and Neutral wire. The Hot is black. Neutral is white.
The other cable goes to Load (light). Black supplies power to Load (light), and white connects to Neutral.
If you are uncertain which is which, testing is shown below.
Connect the device:
Side 1 of device: Black Hot goes to dark colored screw(s) that are connected by brass plate. (This is only wire connected to this side of device)
Side 2 of device: Black that goes to Load (light) connects to screw that sits opposite the switch.
Side 2 of device: White Neutral connects to screw that sits opposite the plug
One wire is left .. the white from light. This white wire connects to white Neutral wire. Since white neutral is already connected to device, look on back of device to see if there is a quick-connect hole for you to shove wire into back of device. If device doesn't have quick-connect, then twist white wires together, and add a short jumper wire to device, and then all the whites are connected to neutral. Circuit is complete.
How to test for Hot and Neutral
Separate wires.
Turn on power.
Test each wire to bare ground.
Now test hot wire to other wires.
Nov 17, 2010 | Leviton COMBINATION SINGLE POLE TOGGLE...
How to wire to attic fan? Old Sping loaded timer has two wire connections Marked LINE and LOAD . There are two Romex- Three wire cables with Black , White (Common) and bare (Grd) wires coming into this box...
OK, your new switch will require the use of a neutral wire. So you will have to do what is called a pigtail. You will have to twist another white wire in with your other white wires to attach your neutrals to your switch. Note: white wires are called neutral not common. Hook the wires that were originally hooked up to your LINE to your HOT (Black) on your new timer, and the what was originally LOAD up to the new timer LOAD. SO as far as wiring all that will change is your white wires that need to attach to your timer NEUTRAL.
Jul 10, 2010 | GE 60minute Automatic ShutOff Timer Switch...
Four prong cord three prong outlet
Ok this is how you will wire the three prong to the dryer.
You have 2 wires that are gold/brass in color, those are the hot wires.
You have 1 wire that is crome/silver in color, that is the neutral
On back of fryer where you wire it you put the wires on like this right to left Gold/brass hot, silver/nuetral, then the other hot wire.
On back of dryer you will have screws from right to left this color gold/brass, silver/crome, then gold/brass again.
If you do have a 4 wire cord the extra wire is ground and you screw that to the machine body.
Mar 14, 2010 | Roper RGS7646KQ Gas Dryer
I have an old maytag electric dryer model #DE608 that has a three wire cord. I moved into a new home with a four hole dryer outlet. Can I switch the dryer electrical line from the existing three wire to a...
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
Jul 06, 2009 | Dryers
I want to replace just the 3 wire receptacle head of my clothes dryer. there are three wires in the cord. white, black, green. i unscrewed the head and I dont know where which wire goes.
white and black are power green is ground the ground should be marked on the plug the black and white does not matter as long as the are on the power terminals they are across from each other the ground is by itself at bottom of plug W B
G
Jun 10, 2009 | Whirlpool LER4634J Electric Dryer
Electrical cable for the power pulled out of machine
Ground wire will be GREEN or bare copper wire. White neutral wire will go to chrome colored AC terminal. BLACK(or maybe brown or other darker color) hot wire goes to brass colored terminal.
If terminals on dishwasher are not chrome(white metal) and brass(yellow metal) colored, then you must look for other ID on Dishwasher side. If terminals or wires on dishwasher side are not a different color, then it does not matter which of the two AC wire, neutral or hot, goes to which. The ground wire is the safety wire against against shock from fault hot wire getting to chassis of washer.
Humming sounds more like dishwasher is in the middle of a timing cycle, but I could be wrong and it is sometimes best to find someone to look at your washer when electrical wires are being hooked up.
Feb 13, 2009 | Sunbeam SNB652SAAW Dishwasher
SK Electricians Starter Tools Meets IBEW Specifications 18-Pc. Set Logo
314 people viewed this question
Top SK Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a SK Measuring Tool and Sensor Expert? Answer questions, earn points and help others
