Question about Dishwashers
Hotpoint fdw60 eco error code
Have a hotpoint fdw60 dishwasher which wont start wash cycle and then goes on to eco wash but doesnt start, eco light just stays flashing .This is one of the only codes not in book and woman at hotpoint says have to get an engineer out .any ideas what this problem is?
  • Anonymous Apr 05, 2008
    Same problem! New machine, but flashes eco and won't let you select another programme. Even eco won't start up. Sometimes after much messing, I can select a programme and wash the damn dishes! - Going back to where I bought it!"
I had this problem too, but discovered the cause and the remedy.
The flashing eco light signifies that the drain sump has water in it. Before the machine takes on water it checks a float located in the sump. If the float says that there is water in the sump then the machine presumes that there has been a problem when draining and decides not to take on any more water.
In my particular case, the sump collected extra water after the machine has last drained itself because the bottom spray arm has come off and allowed some water to enter the machine. Make sure that you check that!
The simple solution is to empty the sump of water. Do this by tipping the machine onto its right side. Warning! You will get wet feet! There was about a 1/4 pint of water in my dishwasher.
After that you should find that your dishwasher works perfectly again! Why Hotpoint couldn't include this simple task in their manual I'll never know! Health & Safety I guess...
HTH!
Posted on Sep 21, 2008
  • 2 more comments
  • karlburl Dec 19, 2010
    Just experienced this problem myself and, after referring to the user manual which was no help, thought I'd have to call an engineer out. Thankfully I found your solution first.
    I did exactly as suggested - pulled the dishwasher out, tipped it on its side (right side as you face it and only about 45deg) and got wet feet. Solved the problem immediately.
    What a waste of money it would have been to call an engineer out for something so easily resolved. I can't believe it's not included in the manual.
    Thank you.
  • Nick May 12, 2012
    Thanks philhusbands. Your solution worked perfectly for my machine. Went wrong last week, found your solution and tried it today...Bingo.
    Thanks again.
  • seanrooneycn
    seanrooneycn Sep 02, 2012
    Thanks philhusbands, your solution worked a treat!!! thanks again!!! :-))
  • Sean Lee
    Sean Lee Apr 03, 2014
    Nearly 6 years later and philhusbands is still helping people fix this problem! Thank you so much.
I would like to thank Philhusbands for his advice on flashing eco light. After being told by hotpoint i would need an engineer plus call out fee. i decided to take a quick look on internet & to my surprise found this artical. So after reading it i did as advised & tipped my dishwasher to one side low & behold water came gushing out. After several minutes of mopping tried selecting programme again & it's working !!Yippee so than you who ever you are.
Posted on Nov 08, 2008
I done exactly what philhusbands said, and it worked straight away. my bottom spray arm had also come off.
thanks phil
Posted on Nov 28, 2009
Brilliant, I just fixed the flashing 4th and 6th light problem - 2 new heater elements later (2ND ONE IS A HOTPOINT PART (£50) - 1ST one lasted 2 months and was an inferior , cheaper (£35) pattern part - do not use) , then came up against the Eco light - tipped on side, worked straight away. 3 year old machine , £85 worth of parts, my labour, think I'll buy Meile next time!!
Posted on Jul 15, 2010
I solved this by removing the filters and simply soaking the excess water out with a tea towel. Worked a treat , only a couple of mins and no need to move the dishwasher
Posted on Aug 02, 2010
    New Friend:
Just a words of grateful thanks to Philhusbands for letting us know how to fix this "Eco" light problem. As he said: pull out dishwasher, tip it over onto the RHS, get wet feet!!!, stand it upright again, re-install it, and..... Bingo... all systems go! THANK YOU, PHIL!
Posted on Apr 11, 2015
Thanks. Helped me the same as all the above answers. So simple!
Posted on Aug 10, 2014
Excellent solutions on here. I didn't pull the dishwasher out I used a sponge and a bucket it did the same thing and I kept my feet dry. Just soak up the water around the sump at the bottom. It worked a treat.
Posted on Jun 05, 2012
Just tried your solution after having the same error message and the dishwasher is working a treat, a massive thanks to philshusband you saved the day as well as my hands & nails
Posted on May 07, 2012
Just had the same problem with my FDW60, after an engineer from General "fixing it" 2 hours earlier...cured 3 faults and still left me with a dishwasher not working. Called to see if he would come back and told "No" and then told would have to wait till Thursday as a light was flashing it was a fault but could not say what! Paying General over £200 a year to repair my appliances and having to wait over 2 weeks! Luckily found this post and problem solved!! Thank you ever so.....would have had dish pan hands soon.
Posted on May 07, 2010
What a result something so simple done exactly as said and its back working fantastic Thanks colin
Posted on Feb 07, 2010
My hotpoint Aquarius Dishwasher starts up bu only runs a few moments before stopping with 2 lights flashing " wash " " drying "
I had the problem of flashing lights and water did not pump out.Found a piece of bacon in drain pump wedged between impellor and pump body...cleaned it out...problem solved..
Mar 18, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
When I switch on my dishwasher setting it at normal wash cycle it appears to start as normal then after few seconds goes onto to Eco 45 c wash - the light flashes but nothing happens i.e. no water comes...
you may want to check and clear the pump
you have something slowing your drain
but for giggles make sure your float valve is free to go up and down like it should
all dishwashers attempt to drain first
so you have a conflict between the float position and the pump sensor
Oct 08, 2009 | Hotpoint 24 in. FDW60 Free-standing...
I have a hotpoint aquarius sdw60 with the eco 45 light flashing fast and will not reset I have tried turning off the power I have stripped the pump this was clear. then reinstalled it but it is still same
I have a Hotpoint Aquarius SDW 60 The delay 3hr &12hr lights are flashing at the same time. Machine won't start. If the door is slamed shut. It get stuck on the Fast & Prewash 40 degree cycle. and stays there.
Jul 13, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint aquarius fdw60
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Sep 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
4,541 people viewed this question
Top Dishwashers Experts
