Question about Garden
Craftsman rear tine tiller will only go forward. The shift lever will not move to either the ''Till'' position or the ''Reverse'' position
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
Pretty common failure for all brands unfortunately. The transmission will have to opened up to determine the cause and it is not cheap to have done. Sorry
Posted on Apr 30, 2010
Transmission will not come out of reverse
what year is it does it have Belt Driven or chain drive ? do you put it gear with lever does it have handle to put it in gear ?is ther something stuck on the blades ? does it turn either Way ?
May 26, 2014 | Garden
If you cant move the tines by hand then I wouldn't think you sheared the pins, more like a gear box problem.
Mar 21, 2014 | Craftsman Garden
Tires and tines will not engage
model number would be VERY helpful here because craftsman made many different styles/models throughout the years
Nov 28, 2013 | Craftsman Garden
Tiller has been sitting up for some time and now won't engage into forward or reverse.
Hello. make sure all of your clevis pins are in place. And on mine even if i get it in gear...make sure that the "dead man" is cable connected for sure. Make sure when you squeeze the "safety stop" or "Run/engage" lever that it is actually moving a lever at the other end. If so? Then trans box is next to inspect. But that would have had to suffer a hard jam to damage that. And again with other people I've seen this a hundred times with rear tine tillers. Sometimes it just "cogs out" into a state of "bad mesh" with the gears and all that is needed is to push or pull the tiller a bit while you try to engage the shifter. The wheels just have to be rolled a tiny but and you'll free up the meshed gears. Happy tilling. Four thumbs up will truly be appreciated. Thanks. Joe
Sep 30, 2010 | Craftsman 8.50 Torque Rating Rear Tine...
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Tiller will go into every gear except forward/till..whats going on?
check the shift lever where it goes into the transmission. a lot of times, the lever will get sloppy where the roll pin goes through and it won't shift into till. sometimes you can drive the roll pin out, pull off the lever and peen the holes over. sometimes you have to drill the lever and shaft and put in a snug fitting bolt and nut. OR, the chain driving the tines is broken, and that means a new transmission. hope it's simple
Jul 19, 2009 | Craftsman 8.50 Torque Rating Dual...
Tines go around but wheels are locked in position and won't move
the gears in the transmission are possibly worn out if i can further help e-mail wade at wadembly@aol.com
Jun 21, 2009 | Craftsman Rear Mount Tiller
Grinding when Engaing PTO for the tiller-Troy Built Horse 8hp
It's likely that your clutch needs adjustment. To adjust, you just need to loosen the two screws on the plate and slide it a bit so the clutch better engages the rear dog clutch. Have you ever taken the tiller portion off the transmission to grease the clutch? If not, before adjusting it you might want to do that. It could be that the clutch isn't sliding back far enough to engage the rear end and a little grease is all it needs. This service requirement is explained in the owners manual for the tiller. One last point, the tiller must be in neutral when engaging the pto clutch. From your note, it sounded like you were engaging the clutch with the forward/reverse lever in the forward position. The lever must be in neutral when engaging the pto clutch.
Jun 14, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have power to the tines but the wheels are locked
Tines only spin in the T position.with cutch engaged.If thats not it split the case and check to see the shift fork operating properly. Or that chains are not broke. NOTE This is a serious job!!!
May 11, 2009 | Craftsman 8.50 Torque Rating Dual...
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
