Question about Whirlpool ACQ158XP Wall/Window Air Conditioner
Air conditioner comes on but does not blow air out
    Novelist:
    Champion:
  • 246 Answers
If the AC is coming on with no air output the problem is that although the compressor is running - the fan motor is not.
This can be because of a 'switch' malfunction, a wire burnt into, a bad fan capacitor or a bad motor.
Of the four possibilities the easiest two to identify are the 'wire that has burnt into,' and a bad fan capacitor. A wire that is burnt into is obvious and so is (sometimes) a bad fan capacitor. A fan capacitor which btw - is a little module (usually gray or silver in color) with wires attached to it. I would check all my wires to it and to the fan motor and anywhere else I could in the unit. Also examine the fan capacitor itself - looking for burnt damage or a 'bulge' in the module which are direct symptoms of a bad fan capacitor.
If it's the capacitor you can remove it making sure you mark your wires in such a way you can connect them up after acquiring a new capacitor.
You can buy capacitors at any Air Conditining Supply house - and they will run about $15-$25 or less.
A bad motor is usually indicated by the motor 'not starting/running' and/or 'the motor being hot to the touch' - there's not much that can be done these days if the motor is bad but replace it. And unless you're really mechanicaly inclined and have plenty of specility tools I would not attempt it. A Service Tech is the best bet here, and you're looking at a repair bill of around $150-$250.
A 'switch' problem is really not that likely but for a nominal fee (usually around $35-$50 you can buy a switch and change out the old one. Like I said this is not likely the problem and I would probably not do this on a hunch.
good luck!
Posted on May 09, 2010
  • if the capacitor looks ok and the fan runs fine should i still check the capacitor and can the appliance place test it for me? if the compressor kicks on then shuts off immediately . it sounds like the clicking noise is coming from capacitor. I have cleaned and oiled the unit. is there a chance it needs freon? or if capacitor isnt problem should i bite the bullet and get a compressor?
  • Tamara Kidder Jun 06, 2013
    We had this same problem and it ended up being the battery on the camper.
4 Suggested Answers
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
  • 20 Answers
SOURCE: air conditioner symbol defrost keeps coming up so
These will defrost themselves automatically when they need to - internal sensors. If it is icing up at all in cooling, then the charge is wrong. Units such as this are very sensitive to incorrect charge, so I would recommend that you have a qualified tech come out, recover all the freon and weigh in the correct charge. If this is a "new" problem, then a leak check/locate would be in order.
Posted on Sep 01, 2009
  • 534 Answers
SOURCE: Air conditioner blowing only warm air
possibly have a capacitor out on the compressor side of the a/c Since the unit works and its only blowing air the compressor isn't kicking in. The capacitor boosts the compressor to activate the compressor. I would have the capacitor to the compressor replaced first before going any further.
Good luck on your repair
Dave
Posted on Oct 17, 2009
Air conditioner isn't blowing cool air and it's not coming out of the vent very fast
Check to see if air is blowing out the back side of condersor,outside ,maybe fan not blowing on outside, or freon low.
Mar 17, 2015 | Goodman Heating & Cooling
Intertherm air conditioner won't work
First I must ask...does the compressor come on? does it just sit there and make a clicking noise? If it doesn't come on at all and if you are handy with a screw driver and can do electrical type work you can take a piece of insulated wire and jumper the thermostat (put insulated wires between the terminals the wires connect to). If it comes on and blows cold air replace thermostat.
Aug 15, 2014 | Intertherm Heating & Cooling
Does not blow out cold air. It comes on but does not blow out cold air, only has cool air
My DeLonghi PAC L90 Portable Air Conditioner does not blow out cold air,only has cool air
Jul 12, 2011 | DeLonghi PAC L90 Portable Air Conditioner
Fan blowing air not coming in the house blowing threw vents
check to see if those ducts have dampers if the do make shure there open and if they are open maybe close some of the others to balance or improve the preasure in the ducts that arent blowing enuf
Apr 04, 2010 | Ruud UBHC Air Conditioner
Dometic air conditioner not blowing cold air.
make sure fan on auto if ok and unit on cool check compressor coming on if ok bad cooling unit
Jun 15, 2009 | Dometic Rooftop RV Air Conditioner
Hot air coming out of back
portable air conditioners mainly have two hoses one hose is exhaust thats the one that is blowing hot air. the one pulling is return.. the hot air blowing out should be exhausted to the outside. the blowing air needs a hose and to be laid out a window the back should have model and serial maybe product number. the two holes are either 4 inch or three inch and most portable units other than hand me downs come with a window frame that allows the hot exchanged air to go outside and cooler air to be used for heat exchange.
May 28, 2009 | Maytag NMPEB08F2A Air Conditioner
Jun 30, 2008 | Frigidaire FAH08EJ1 Air Conditioner
Whirlpool ACQ158XP Wall/Window Air Conditioner Logo
2,629 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
