Question about HP OfficeJet Pro L7580 InkJet Printer
Change sender name on fax
Need to change the sender name on the L7580 fax as it was cleared in error and unable to locate manual
  • 55 Answers
If you are working from a windows pc open solution center, go to settings then to fax settings, from there go to fax set up wizard... that way you can also double check that the rest of the settings are the same as they should be but the set up wizard allows you to also make sure that the header is set up correctly as well as the the number and rings to answer as well name and the set up for line.
Posted on Apr 27, 2010
Fax forword ricoh mp171
Print documents received and forward to a specified end receiver. This is useful if, for example, you are visiting another office and would like a copy of your documents to be sent to that office.
You can also specify a "folder" as the forwarding destination.
  • To use this function, set [Forwarding] under [Administrator Tools] to [On].
  • The Forwarding function does not forward documents received with Memory Lock.
  • You can select end receivers only from among destinations programmed in the Address Book. You cannot specify programmed transfer stations as end receivers.
A fax number, e-mail address, IP-Fax destination, and folder can be set as the forwarding destination.
When you wish to change the end receivers depending on the senders, specify the end receivers by the senders, at "Program Special Sender". Documents not received from specified senders are sent to the destination specified in this function. For details about programming special sender, see "Program Special Sender".
You can set whether or not to print the forwarded documents on this machine in "Parameter Setting" (switch 11, bit 6). See "Parameter Settings".
Deleting a destination specified as a forward destination from the destination list causes the settings of the forward destination to be deleted, so they must be registered again. When a destination is changed, a document is transmitted to the new destination. If there is no destination of the specified type, you can set which destination to be used as an alternative destination in "Parameter Setting" (switch 32, bit 0). See "Parameter Settings".
You can program one of the User Function keys with operations for this function. See "General Settings/Adjust".
If you have specified a folder for forwarding, you can specify the file format used for forwarding in "Parameter Setting" (switch 21, bit 3). See "Parameter Settings".
User Parameters (switch 37, bit 4) on the Fax Features menu allows you to include the sender's name in the names of files sent to folders. However, garbling of the file name and data loss can result if the receiver's operating system cannot accept certain characters in file names. To prevent this, use User Parameters (switch 37, bit 5) to limit the file names to plain characters only. If you limit file names to plain characters only but errors still occur, disable display of the sender's name in the file name of documents forwarded to folders. For details, see "Parameter Settings".
Using the parameter setting (switches 38 and 39), you can specify the maximum number of resends that the machine attempts if it fails to forward a fax (including faxes from special senders) to a folder destination, and the interval between the resend attempts.
or download the operations manual to guide you here ..http://support.ricoh.com/bb_v1oi/html/oi/re/model/mp171/mp171en.htm
Mar 24, 2013 | Ricoh Aficio Office Equipment & Supplies
CLEAR MEMORY ON CANNON FAX MACHINE
if you get the message MEMORY FULL to clear it just unplug the power cord for a minute or so.
But if you want to clear all machines memory, enter the service mode ( MENU and # ) select Clear and ALL.
After these you need to reenter fax settings, such as fax number, sender name, ring count,...
Hope that helps!
Aug 26, 2010 | Canon L120 Fax Laser Printer
I cant change the name ofthe previos sender on my panasonic 8000
Press
Function
71
set
keep pressing set until you get to OWN ID
press set
press clear
type in info
press set
press stop
Jul 07, 2009 | Panasonic PanaFax UF-8000 Laser Fax
How do I change the company name that's displayed on the top of the page of a fax??? It's a Canon Faxphone B740.
On the right hand key pad
1). Press Function
2). Press 01 (data registration
3). Press set twice
Display the tel number, change if that is wrong
4). Press set twice again
Enter the company name (unit name)
Use the numeric keys-max 24 characters
if you have otehr problem, please to to the following link and download the users manual.
http://www.usa.canon.com/cpr/pdf/Manuals/B740CanonUserManual3-13.pdf
May 22, 2009 | Canon FAXPHONE B740 Plain Paper Bubblejet
I need to change the company's name on the printout page when someone receives it.
The 6600 opeations are very similar to the 6700. Go to the Sharp site at
http://www.sharpusa.com/products/TypeManuals/0,1083,23,00.html
download the FO-6700 manual, follow the instructions for setting the sender name and phone number beginning on page 29 of the manual.
Please make sure to rate this solution.
May 15, 2009 | Sharp FO 6600 Plain Paper Laser Fax
Sharp AR-275 copier with fax module. Need to edit sender ID
push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Mar 04, 2009 | Sharp AR-275 Copier
Want to change the heading to reflect my name.
On Page 6-6 of the Operation Manual, the Settings to adjust the Sender's Name (which you can store up to 99 Names) is done through the TTI SELECTOR. On my machine, the TTI SELECTOR Button is located just under the LCD Screen - last button on the right. There is little else mentioned of this therefore I assume the procedure is quite simple. However the Manual states "To Select a Sender's Name" I was hoping it went on to say, to also EDIT and/or INCLUDE a Sender's Name. I would start with the TTI SELECTOR and hope that solves your problem. Good Luck
Jan 12, 2009 | Canon Laser Class 8500 Printer
Incoming Fax Error
Maybe depends on poor phone connection from this sender, caused by bad line or a transmitt problems. In faxsettings All fax, change "error correction" to off and "V34" faxspeed to slow, this will help.
Nov 10, 2008 | HP LaserJet 2840 All-In-One Printer
How to change the sender's info
Lift the panels on the keyboard. press data registration and press set. press set again and use the down key to scroll user name and set and press the clear button and you can enter the new name by using the numericals keys corresponding on the alphabet like your cell phone. when finished press set and press the down arrow to tel number and press set. press clear and enter your fax number. and press set when finished and press stop.
Aug 16, 2007 | Canon LaserClass LC 8500 Plain Paper Fax
HP OfficeJet Pro L7580 InkJet Printer Logo
117 people viewed this question
Seeker5211
Seeker5211
