Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Power button doesn't do anything, remote doesn't work, 4 blinking lights. Sony kv 36fs120.
    Problem Solver:
  • 15 Answers
Blinking LED?
It is probably error code...If im not mistaken,,4 blinks means there's a problem in Vertical section of the TV...
Try to check if there is supply voltage of Vertical IC(usually 26 volts DC).Check electrolytic capacitors and resistors around the vertical IC.
Do visual check of Deflection Yoke,if there's corrosion.If yoke is OK,,,replace Vertical IC.
Posted on Apr 27, 2010
  • 3 Answers
You have power issue. short the prongs for a minute. then remove the short wire. then test. if not succesful go to your nearest service center.
My sony tv has sound but no picture and red light keeps blinking
In accordance with facility to watch The Wire online,you can go through entertaining .Watch Online The Wire Season 4 Episode6 - Watch-Series watch online series The Wire season 4 episode 6,download full episodes for freeWatch The Wire Online - Full Episodes ofThe Wire & More TV Set in Baltimore, this show centers around thecity's inner-city drug scene. It starts as ... the Wire - Watch Full Episodes of TV Shows Onlinecility to watch The Wire online with blinkx Remote
Jun 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv won't stay on push on button and shuts off w/in 2 seconds
common to having a flyback transformer problem. this will require parts replacement
Dec 27, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
KV-32HS500 WON'T TURN ON standby light flashes 7 and sometimes 6 times and has flashed 4 times also.
These are sony error codes while in protection mode. The 7 blinks means high voltage exceeded 33k volts ,caused by either horizontal or power supply circuits.
The 6 blinks code is for no horizontal deflection, and the 4 blinks code is for no vertical deflection.
So the one thing they all have in common is the power supply that will need to be repaired before you can use the set again.
Hope this help. Good luck
Please do not rate this answer(unless it helps) as it is only a suggestion/information.
Dec 02, 2009 | Televison & Video
Apparently, channels have to be autoprogrammed first before those buttons will work.
Our TV is 4 years old but we never used the channel buttons bc it was always hooked up to DirecTv thru video input. SO when we disconnected the TV to sell, we thought it was a problem.
Jan 06, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony - no power
Well 5 times blinking indicates EEPROM ic getting malfunction. Change this ic tv is working well and good. Note that this ic comes only in blank you have to program it as your tv model.
Aug 04, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA Won't Turn On
The key here is the count of the blinks. I'm assuming that the model number is KV-36FS120. Please post the blink count. It should be a count-pause-count...
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Tv Problem
The 4 blinks indicate the problem circuit, but I need the model number to give you the specifics. The category you entered is KV-36fs120 which is a 36 inch set. Please update this with the model number. It should be on the back.
Thanks,
Dan
Apr 03, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No Power on Sony TV Model KV 36FS120
Hiii....
The sympthon 9 blinks :
Check at G board : D6301 D6116 ( replace with new one !!!! ).Voltage around +/- 12 -13 v .
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony tv kv-36fs120 will not turn on
Use a hair dryer on the back right side of unit. Humidity sensor may be causing the unit to stay off. The hair dryer may also remove dust causing a false humidity detection
Nov 10, 2007 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
216 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
