Question about Dishwashers
No water out of top spinning arm - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that will help you...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Apr 27, 2010
Dishes in top not clean- arm in top does not spin
Hello bue.... The top arm spins due to water pressure. pull your top drawer out and inspect the rubber tube that feeds water to the top arm. Usually they have a split in them so the water does not get to the arm to spin it. The fix is to replace that rubber tube. You will need the model number of your machine to order the correct part. I usually get my dishwasher parts from searspartsdirect.com
Joe
Thanks for choosing Fixya!
Jan 30, 2011 | KitchenAid Dishwashers
The upper arm is free spinning by hand, but from all indications, it is not spinning. Water is flowing freely and drain is excellent. Is the upper arm problem a major repair.
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are oopen. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and youl'll need a Torx driver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Jan 01, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwasher is not cleaning top rack
If the top rack is not getting clean, then either the spray arm holes are slightly plugged and not allowing enough water flow to the machine. The water coming from the arms also makes the arms moved in a circular direction which also helps in cleaning. Either the arm is plugged and not allowing water flow or the arm is stuck and not rotating. I would use a toothpick and clean all the holes first. Then try it. Try and spin arm by hand and make sure it spins very easy and freely. If not, replace it or dismantle it and clean it really good so there are no clogs and it can spin easily.
Dec 31, 2010 | Jenn-Air 24 in. DW731 Built-in Dishwasher
The top two water water arms do not spin
These spray arm will only get water several times in the wash and rinse cycle. They do not turn at the same time the lower (bottom large spray arm under the bottom rack).
There is a chamber that diverts water either to the bottom sprayer or to the top sprayers, not to both at the same time.
If your top spray arms never get water, then there must be an issue with that chamber motor to divert the water. A new sump assembly that has all the new parts.
Good luck.
Jul 19, 2010 | LG LDF6810ST Stainless Steel Built-in...
My top shelve sprayer arm does not spin
its just clipped over the cap remove and clean also check the seal is not damages on the pipe that goes into case.
Jun 18, 2017 | KitchenAid 24 in. KUDI02IRBS Stainless...
Top Arm does not spin so glasses are not cleaned and detergent is not rinsed out of holder very well.
Make sure the water level is just at or below the heating element. Low water level will cause the pump to "run out of water" before all wash arms and connecting tubing are filled. A pulsing sound during the wash cycle will verify. Low water pressure or a bad water inlet valve are one cause. Water siphoning ou the drain line is another. Look under your sink and verify the drain line goes from the garbage disposal or sink tailpiece all the way up to the bottom side of the coutertop enroute to the dishwasher.
Apr 27, 2009 | Dishwashers
No-spin
the spinning of the arms is created by the force of the water shooting out of the holes. your top arm may have debris build up in it that prevents proper water flow. u can also remove the arm and see it there is build up on the contact point were it rotates. clean it if its dirty. "dishwasher magic" is good for cleaning mineral build up in your system. also, make sure your not putting dishes on the top rack that are too tall and prevent the blade from rotating
Dec 01, 2008 | Maytag MDB9600A Jetclean II Built-in...
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher
  This dishwasher does not feed water to top and bottom arms at same time.  It starts with bottom and then after awhile it switches to top and then cycles.  If water comes out arms but arms won't turn,  check all holes in arms.  It's the water spraying out these that causes arms to turn.   If arms spin freely by hand,  it's a plugged arm or holes in arm or insufficient water in tank.
  Being that it only sprays 4 inches suggests a water level problem or possible mineral build up restricting flow.
Oct 11, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Top rack arm doesn't spin.
matt, did you get down to the chopper screen? If that screen is clogged the flow to the upper arm will be restricted. Check out the pic, Catriver
Sep 29, 2007 | Kenmore 24 in. 17362 / 17364 / 17369...
Dishwashers Logo
43 people viewed this question
Top Dishwashers Experts
