Question about Flotec SimerOmni 3986 SS Sump Pump
When taking apart the pump I spilled the oil
What type of oil should I use--transformer oil, spindle??
  • 2,100 Answers
I just went to the website, they don't say one word about the oil. They do have a toll free number. 1-800-365-6832,,, hope this helps.
Posted on Apr 27, 2010
How to replace oilpump in 2003 nissan frontier. 4 zyl. 4by4 manual shift
Align the punch mark with the oil hole before oil pump installation-2.4L engine
Oil pump exploded view-2.4L engine
Click to Enlarge
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Set the engine to Top Dead Center (TDC) of the compression stroke for the No. 1 cylinder.
  3. Remove or disconnect the following:
    • Distributor cap
    • Distributor
    • Engine under cover
    • Stabilizer bar
    • Oil pump and drive spindle
To install:
  1. Fill the pump housing with engine oil, then align the punch mark on the spindle with the hole in the oil pump as shown.
  2. Install or connect the following:
    • Oil pump and drive spindle. Tighten the mounting bolts to 96-132 inch lbs. (11-15 Nm).reverse procedure on other componets Start the engine and check for leaks.Check the ignition timing and adjust, as necessary.
Dec 12, 2010 | 2000 Nissan Frontier
Pump quit....gets hot!
THAT IS A CHEAP PUMP. JUST BUY A NEW ONE, THEY ARE HARD TO GET SEALED BACK UP AND JUST TO FIND IT WORKED FOR A WEEK.. VEGETABLE OIL .. IT MUST BE NON TOXIC OIL !! .. VOTE
May 24, 2010 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Oil for submersible sump/effluent pump
I have a master plumber 1/3 HP model 539892 submersible effluent pump and was wondering if it takes oil and if it does what type of oil.
Jul 20, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
How do you prime the oil pump after rebuild
The oil pump drive is off the intermediate shaft and that is driven by the timing chains. Unless you want to take apart the chains and spin the int shaft itself, there isn' t a good way to prime the motor.
Or just try this:
Just disconnect the bulkhead plug just behind the coil pack, you know the big round thing with all the wires. Crank the engine over a few times, 10-20, reconnect the plug and start the engine.
Or this:
Look on back of block there is a metal cap held on by two bolts. Take that cap off and pull out the top gear then find a socket that fits the top of the oil pump driveshaft. Put it on a power drill with a long extension stick it in the hole onto the driveshaft and spin it, cover top of whole around the extension with a rag so it doesnt spill. This will prime the whole motor, if you do it with head open you can see the oil come up through the lifters
Jul 16, 2009 | 1991 Toyota Celica
I have a Simoniz 1900 presure washer and had to take it apart to fix it. I need to know how to put it together again as it has been awhile since I have had a chance to work on it. Can anyone tell me how to...
i took my pressurewasher simoniz s1900 apart, i had to take off the pump and all oil leaked out.
how and where can i fill the oil in to the pump
and what type of oil would i use
thanx ernte
May 17, 2009 | Garden
My xbox keeps on reading open tray when i put a disc can any one help me
Mine had the same problem. On mine the spindle wasn't turning the game. It kept trying to then quit and said "Open Tray". The warranty was out so I took it apart opened the dvd drive and took apart the spindle. The grease in the spindle was black, I guess from all the heat. Cleaned it out and put some high temperature grease on spindle shaft and in the hole. It now spins with ease. There are videos on youtube on how to take apart the xbox and to take apart the dvd drive and spindle. Just pay close attention at how tight the screws the hold the spindle down are.I hope this helps.
May 16, 2009 | Microsoft Xbox 360 Pro System Console
Open tray error on xbox 360
Apr 09, 2009 | Microsoft Xbox 360 Pro System Console
Oil spilled during shipping
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
Nov 03, 2008 | KitchenAid KSM150PS Artisan Series Stand...
Flotec SimerOmni 3986 SS Sump Pump Logo
372 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
