Question about Metra 992005 992005 Cadillac DeVilleSeVille Installation Kit
When the key is put in the ignition and i turn it on it says that the starter is disabled and that I have to wait three minutes. after all of this it does that same thing all over again.
Its probably the ignition switch.when it goes bad it doesnt read the chip in your key therefor it disables the car from starting.i just had the sam problem with my 99 deville.its about a fourty dollar part an 300 n labor to change
Posted on May 13, 2011
2004 Pontiac Grand Prix pk3 relearn procedure does the starter to disable due to theft system to turn to turn off before going to step 2off before going to the second 15 minutes with Ken secL
Your doing it wrong !
30-Minute Relearn Procedure
Use this procedure after replacing the following components:
The passkey III (PK3) keys
The BCM
The PCM, see important above
Important: This procedure is not available on vehicles equipped with option code (Z49).
If replacing a BCM with an GM SPO Replacement Part, perform the procedure to setup a new BCM prior to the 30-minute relearn procedure.
  1. With a master passkey III key, turn ON the ignition, with the engine OFF.
  2. Observe the STARTING DISABLED DUE TO THEFT message on the drivers information center (DIC), after approximately 10 minutes the STARTING DISABLED DUE TO THEFT message on the DIC will turn off.
  3. Turn OFF the ignition, and wait 5 seconds.
  4. Repeat steps 1-3 two more times for a total of 3 cycles or 30 minutes.
  5. Important: The vehicle learns the key transponder information and/or passwords on the ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
  6. With a master passkey III key, start the vehicle. The vehicle has now learned the key transponder information and the PCM has now learned the fuel continue password.
  7. With a scan tool, clear any DTCs.
Dec 07, 2015 | Pontiac Cars & Trucks
System show theft system on wait three minutes. It shows the count down and when the three minutes are up shows star car, but when I turn the key it starts all over again. The does it's normal thing but...
your key may be worn there a small sensor on your key that the ignition senses. the ignition tumbler may be worn out to. try using your extra key. you may have to have ignition key and tumbler replaced and reprogrammed to your vehicle. hope this helps
Feb 02, 2011 | 1990 Cadillac Eldorado
In my 2000 chevy camaro my security light is on and my car wont start what process do i need to do to get it running?
Your vehicle is equipped with the PASS-Key II (Personalized Automotive Security System) theft-deterrent system.
PASS-Key II is a passive theft-deterrent system. It works when you insert or remove the key from the ignition.
PASS-Key II uses a resistor pellet in the ignition key that matches a decoder in your vehicle. When the PASS-Key II system senses that someone is using the wrong key, it shuts down the vehicle's starter and fuel systems. For about three minutes, the starter won't
work and fuel won't go to the engine. If someone tries to start your vehicle again or uses another key during this time, the vehicle will not start. This discourages someone from randomly trying different keys with different resistor pellets in an attempt to make a match.
The ignition key must be clean and dry before it's inserted in the ignition or the engine may not start. If the engine does not start and the SECURITY light stays on when you try to start the vehicle, the key may be dirty or wet. Turn the ignition off.
Clean and dry the key. Wait about three minutes and try again. The SECURITY light may remain on during this time. If the starter still won't work, and the key appears to be clean and dry, wait about three minutes and try another ignition key. At this time, you may also want to check the fuses (see "Fuses and Circuit Breakers" in the Index). If the starter won't work with the other key, your vehicle needs service. If your vehicle does start, the first ignition key may be faulty. See your dealer or a locksmith who can service the PASS-Key II.
If you accidentally use a key that has a damaged or missing resistor pellet, the starter won't work. The SECURITY light will flash. But you don't have to wait three minutes before trying another ignition key.
See your dealer or a locksmith who can service the PASS-Key II to have a new key made.
If you're ever driving and the SECURITY light comes on and stays on, you will be able to restart your engine if you turn it off. Your PASS-Key II system, however, is not working properly and must be serviced by your dealer. Your vehicle is not protected by the PASS-Key II system. If you lose or damage a PASS-Key II ignition key, see your dealer or a locksmith who can service PASS-Key II to have a new key made. In an emergency, call the Chevrolet Roadside Assistance Center at 1-800-CHEV-USA or 1-800-243-8872 (In Canada call 1-800-268-6800).
Also this could helpfull: 2000 Chevrolet Camaro - Owners Manual
Hope helps.
Oct 12, 2010 | 2000 Chevrolet Camaro
1995 Cadillac STS starter disabled all night
u will need to bypass the VATS factory security systemm the part u need to fix it is no longer avail from GM, it is easy, here are the full instructions, go to the link.
http://vats.likeabigdog.com/
Jul 22, 2010 | 1995 Cadillac Seville
I turn key to on. car won't start. Dashboard display shows wait three minutes. I wait three minutes and the car starts
sounds like your problem is with the cars alarm system. this message will come up after the alert is tripped and the key is put in the ignition switch to start the car.
May 08, 2010 | 1992 Cadillac Eldorado
Changed starter in 96 sunfire now, cranks but will
Try turning the key to the on position three times, then leave it on the third time and wait about fifteen minutes for the security light to stop flashing. then turn the key off and try to start it.
Mar 09, 2010 | 1996 Pontiac Sunfire
My 1996 Pontiac Sunfire wont crank...
tryy replacing the fule injectors and the fuel pump could possibly be shot as well. you have a fuel problem.
May 07, 2009 | 1996 Pontiac Sunfire
Dash reads start disabled;due to theft sysytems;wait three minut
did you replace the fuse.if so try to get the alarm reset location,it could be in the stupidist place like my pathfinder you have to put the key in the tailgate and turn it to glass side and hold it for 20 seconds.and then hit the hidden reset switch under the rear carpet.
Feb 26, 2009 | 1995 Cadillac Eldorado
How can I bypass a anti auto theft system on my 1990 cadillac seville?
I Have A Seville 1990, When That Happen To Me I Got The Inginion
Replaced Problem Solved. What Is Happening Is Your Key Has A Chip And That Chip Is A Resister And When The Valve Is Not Sented To The Computer It Disengages the Fuel Pump And Than Tells You To Wait. Soon All That Will Happen Is You Will Get The Wait 3 Mins And It Will Never Start, A Good Locksmith Can Take Care Of This For You And That Will Save You Some Money. Cause If You Go To The Dealer Ouch They Will Hit You Up. But I Asure This Is How It Will Happen Cause It Is How It Happen To Me
And Sorry There Is No By Passing The Computer
Nov 02, 2008 | 1990 Cadillac SeVille
Metra 992005  992005 Cadillac DeVilleSeVille Installation Kit Logo
37 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
