Question about Acer Aspire One PC Notebook
Missing power cord
We have misplaced the power cord for the Acer Aspire One. S/N is lus050b22891000f12547. Which cord do we need?
    Novelist:
  • 128 Answers
Best buy should be able to furnish you with a replacement for about $60-$100
Good luck,
James
PLEASE RATE THIS WITH A 4 THUMBS UP!!!!
Posted on Apr 27, 2010
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    After booted up and just sitting there for a few
    Get the battery checked. Its malfunctioning. you probably might need to buy a new one.
    May 06, 2010 | Acer Aspire 6920 Notebook PC
    My new acer aspire one netbook absolutely refuses to power up
    if its brand new I'd suggest contacting Acer, sounds like there is a hardware fault.
    Nov 25, 2009 | Acer Aspire One Netbook 8.9" Notebook
    Hi my acer aspire 4315-2490 power cord is malfunctioning and it is not supplying power to the laptop. What power cord models can I buy to replace or is it fixable?
    Let me give you a exact model number that will work or you can stop at a best buy and pruchase a universal "expensive" or go direct to acer for this part number its a liteon PA-1650-02. that is the exact one you need for you laptop. Thanks
    Aug 10, 2009 | Acer Aspire 4315-2490 Notebook
    I have an Acer Aspire one model zg5- Power cord
    Here is another thing you can try. Unplug the power cord, and then remove the battery. Press the "Start" button and hold for 5 seconds. Replace the battery back into the computer and plug in the power cord. Start the machine and see if the low battery message still comes up. Sometimes the program that monitors the battery status gets confused. Doing the above should straighten it out. The Acer should start up and the AC power light should be lit. Look down in your task bar for the battery Icon or go to Battery Status in Control Panel and see if it shows that the battery is charging. Even newer batteries can go bad (rare) but if this is the case and a cell has shorted out in the battery, then your only recourse is exchange under warranty.
    Jul 16, 2009 | Acer Aspire One PC Notebook
    Acer aspire webcam wont open
    Follow these steps: Solution
    This applies only to those systems with a built-in camera, the Acer Orbicam.
    If the Acer Orbicam is missing or not installed, please follow the procedure below to reinstall the application.
    Close all open applications on your computer and make sure your power cord is plugged into the back of the notebook.
    1. Press ‘Alt + F10' to start eRecovery Management.
    2. Enter default password of 6 zero's. Example: 000000
      (Note: if this default password does not work, then a different password has taken its place. Acer is not responsible for any forgotten or misplaced passwords.)
    3. Select ‘Recovery Actions' and click ‘Next'
    4. Select ‘Reinstall Applications/drivers' and click ‘Next'
    5. On the left hand side of the newly opened window select the following: Windows XP
      ? Driver
      ?Camera
    6. On the right side of the same window, click ‘Install Camera Driver Now'
    7. The unit will reboot after the installation is complete.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Apr 17, 2009 | Acer Aspire 3610 Notebook
    Samsung ltm1755b dc cord missing/need replacement
    You can order a replacement AC/DC adapter power cord for this model (LTM1755B) from a major Samsung parts distributor at the link below:
    Samsung LTM1755B Replacement Part AC/DC Adapter Power Cord
    Apr 17, 2009 | Samsung LTM1755 17 in. HD-Ready LCD...
    Acer Aspire One  PC Notebook Logo
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
