Question about Epson Perfection V750-M Pro
Scans slides in a random order. How can I get scanner to scan in the sequence i place the 35mm slides. Al Nelson 314-422-6001
  • nelson3 Apr 27, 2010
    Hello and thank you. Yes I place them in sequence, left to right, down one line and the same left to right. It scans in a random order. Need to know details how to fix. I am not an expert. Thank you. Al Nelson
    my 750 scans 35mm slides in a random manner. What can I do to receive scanned slides in the order I place them in the 35mm slide holder?
    Genius:
  • 1,354 Answers
You Cannot Scan Film or Slides
  • Make sure the scanner cover is securely connected to the scanner’s OPTION port. See Removing the Document Mat for instructions.
  • Make sure the Document Type setting (Home Mode) or Document Type and Film Type settings (Professional Mode) are set correctly for your film/slide type. See Selecting Basic Settings for instructions.
Scans slides in a random order. How can I get - link_top.gifTop You Cannot Scan Film in Full Auto Mode or Using the Thumbnail Preview EPSON Scan may not be able to detect film images, or may crop or group the images unexpectedly. This may happen if your images are like the following:
  • images with a dark background.
  • images with a very bright background.
  • Color negative film with extremely light or dark base color (background).
  • Panorama and regular size images being scanned at the same time.
Try one or more of the following solutions.
  • In Full Auto Mode, you can scan only 35 mm color film strips or slides. To scan other types of film, use Home or Professional Mode.
  • Make sure the film is placed in the film holder correctly and the film holder is properly positioned on the document table. See Placing Film in the Holder for instructions.
  • Make sure the white stickers on the back of the film holder and the areas around them are not scratched, dusty, or covered in any way. If the areas are obscured, the scanner may have trouble recognizing your film or slides in Full Auto Mode. If the problem persists, try scanning in Home or Professional Mode.
  • In the Configuration window, adjust the thumbnail cropping area using the Thumbnail Cropping Area slider. See EPSON Scan Help for details.
link_top.gifTop Negative Film Preview images Look Strange
  • Make sure the Document Type setting (Home Mode) or Document Type and Film Type settings (Professional Mode) are set correctly for your film. See Selecting Basic Settings for instructions.
  • In Normal preview, the dark area around the film and the frame of the film holder is perceived as white. This alters the exposure and causes images to appear darker. Create marquees on the image area you want to scan as described in Previewing and Adjusting the Scan Area. Then click the Zoom button to preview the area.
link_top.gifTop Striped Rings Appear in Your Scanned Image A Newton ring is a ring-shaped pattern of stripes that appears on scanned images of transparent materials. It may occur if the film is curled.
Place the film with the base side facing up Scans slides in a random order. How can I get - ver515.gifw using Thumbnail preview. Then flip the previewed image by clicking the ver515.gif (mirroring) icon in the Preview window. See Previewing and Adjusting the Scans slides in a random order. How can I get - link_top.gif> for instructions.
link_top.gifTop A Line Appears in the Previewed Image The document table or transparency unit window may be dusty or scratched. Clean the document table and transparency unit window as described in Cleaning the Scanner. If you still have the problem, contact your dealer.
Posted on Apr 27, 2010
  • 4,924 Answers
After it scans you will find the actual scanning in the scanner manager ..and there you can arrange them as you want...(in case you have it connected to a computer ) ..practically you find them in thumbnail view and you can arrange them ...
why is it scanning them in this way ..I cannot tell you ....am I to understand that you place 35 mm film and you want the exact order that they were taken ...but it retrieves them as it pleases....?? in this case I can not think at other way ..but if either arrange them by consecutive number ...or so ...it actually have to have such a preset ...in the menu..and if you reset it ...probably this is the default way to scan..
  • Catalin Turcu
    Catalin Turcu Apr 27, 2010
    Im not sure why ..if they came from different shootings sessions ...I guess it scans them by the position number or by date ...from the film ...cause there is no other explaining ...that's why I suggested to use a manager ...if you do not use a computer attached to the scanner and it do not have a preview screen ..you can not do much ...but if it has at least a preview ...or a display where you can see them...change the order by select and move up and down...
    when it is connected to the computer things became easy ..cause all scans appear in the program you scanned with ..and you can just drag them in a different order...or if it arrange them by name ..you can jus rename them and they will arrange by itself..
  • Catalin Turcu
    the bottom line is that no matter how it scans them ...you should be able to manage them in the memory ..or into computer ..if you use a memory card in the scanner or so ...just scan them like they are ...and insert the memory into the computer and make the changes you need..if nothing else will work ..
My scans look like a negative and not a photo
When you go to scan your slides, the software should have a setting for "slides", or "negatives". Make sure you select the correct one for what you've put in.
Dec 31, 2014 | ION Audio ION FILM 2 SD 35mm Film and...
Photoshop not accepting scans from power slide 5000
Firstly remove your scanner what you have now. Then restart your computer. Now install your scanner driver and also restart your computer. Now try it. I hope it will be fine now.
Nov 04, 2012 | Pacific Bearing Pacific image image box...
When I scan 35mm negatives, the pixel aspect ratio is incorrect: the resulting images are stretched out by twice their width without any change in height. I can fix this after importing the image into...
I have the same problem with mine; medium format scans are fine but 35mm scans are stretched. The same happens with both the Minolta software and with Vuescan. Has anyone manage to fix this?
Dec 26, 2009 | Konica Minolta Dimage Scan Multi PRO Film...
How to scan slides with Visioneer 9520 USB Scanner - it scans who
I have successfully used my Visioneer 9520 to scan 35mm slides, and they came out perfect. To do this, in my image editing software, I select File/Import/Acquire/Visioneer ScanManger Pro. This opens the VIsioneer scan manager window, where I select "Scan 35mm using:" and then I choose the desired scanning configuration, e.g., "35mm Better, 35mm Best, Custom" etc. See image below.
BTW: After several moves, I have lost my 35mm scanning template. Do you know where I can get another one, or do you know someone who could actually scan theirs and email the image to me? I could then create a duplicate from heavy black construction paper or card stock.
Jul 26, 2009 | Visioneer OneTouch 9520 Flatbed Scanner
Getting true color on slide scans
Make sure you have the emulsion (image) side of the slide towards the scanner sensor. Some scanners have a special setting for film still in slide holders to correct for focus. You may need a photo edit program to help with color and density. I find no difference from 35mm to split 5x7s altho bigger is always better.
Jul 03, 2009 | Nikon LS-9000 Film Scanner
EPSON Perfection 4490 - Ireflective media scans, film doesn't
There are two lamps with this model. One in the base for reflective and one in the lid for negatives and slides. If the base one is going out then it will be trying to use the one in the lid. You must remove the white document mat from underneath the lid to expose this lamp so it can scan your negatives.
Jul 01, 2009 | Epson Perfection 4490 Office Flatbed...
Scanning 35mm slides and saving to computer
In order to scan 35mm slides to your computer, you need a scanner that has the capability of doing this. These scanners will either come with a 35mm adapter that will allow you to scan the slides, or there are scanners that will scan only 35mm slides. A good recommendation is either this or this.
Thanks and please take a moment to rate as fixya.
Nov 24, 2008 | Canon Office Equipment & Supplies
Scans slides too dark.
maybe the slides are too dark, in other words, the pictures you took didn't have enough exposure therefore you it shows up dark.. You could always use photoshop or someother photo manipulation software to lighten the scan, same thing happens with my hp scanner with slide adapter, if it slides just show up dark, lightening it with software will help, unless it is unsaturated/shadows too dark, etc..
Hope this helps.
Nov 11, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Random black lines on scanned slides
Normally dark lines are a speck of dirt sticking on to the glass and when scanned continuously, it appears as a line. Clean the glass thoroughly. Ensure the slides are dust free. If the lines are appearing in different locations, it means the dust gets removed while scanning. Line in the same place could be because of glass is scratched. The above is common with roller scanners.
For fat bed scanners, there will be no scratch on the glass. It must be from the slides/documents
Feb 20, 2008 | Braun MULTIMAG SlideScan 4000
Epson Perfection V750-M Pro Logo
81 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
