Question about Maytag MGR5750 Gas Kitchen Range
Maytag oven will not ignite
Maytag range model MGR5753BDW - Maytag range model MGR5753BDW - oven will not ignite (glow bar is on brightly) - retry several times - finally retry with top burner on (two attempts), oven finally ignites
  • 54 Answers
If its a square glow bar it must pull 3.5 apms to open the gas valve. Round ones pull 2.5 apms. even though the glow bar is on it must be real bright. Has it been taken over 45 second to light the oven. You will need some way to check the amps. If its getting enough amps the safety valve is bad.
Posted on Apr 27, 2010
Whirlpool oven wont start, is there away to light the pilot?
You don't say what model you have. That being said, I highly doubt it uses a pilot light. It most likely uses a glow bar igniter to ignite the gas. Take the bottom of the oven cavity off (remove the racks and you'll see a couple screws in the back on the bottom. Remove those and the bottom of the oven cavity should lift up).
Once you have the bottom cover off, turn on your oven and watch the glow bar. If it glows bright white, it's good and your gas valve is most likely bad. If it doesn't glow at all, or it's not very bright, or it has one bright white spot on it and the rest of it looks a little yellowish orange, then you need to replace the glow bar igniter.
Anyway, that's where I'd start.
Nov 04, 2014 | Whirlpool Ovens
I have a Maytag model #MGR5754QDW gas oven. The oven isn't getting hot. I think it is also called a Precision Touch Control 500. The top works fine, just the oven will not heat up at all.
Hi, the likely cause to the problem is the igniter. Pull the floor of the oven out and then the flame spreader. Now set the oven for 350, if the igniter does not glow unplug the range and test the igniter with an ohms meter. If as i suspect it shows open you should replace it. If the igniter is glowing when set for 350 it may still be bad. An igniter should glow bright yellow to the point you can't look at it. If it glows an uneven yellow/orange it's bad and you should replace it. Mike
Dec 18, 2009 | Ovens
Model MGR4452BDB range top burners work but oven
The igiter is bad and needs replaced . The glow bar has a crack and is not getting hot enough to open the oven valve allowing it to ignite.
Nov 01, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
Have a stove ,oven will not light, the igniter glows bright,but there isn"t any gas coming into the manifold, the model is MGR5755ADW
Sounds like a bad igniter. even though it seems to be working it may not be getting enough resistance to open th gas valve. 90% of the time its the glow bar that is at fault. Slight chance that the gas valve is bad. Hope this helps you. Let me know if you need more help. Do not touch the glow bar when replacing it.
Aug 10, 2009 | Maytag Kitchen Ranges
Electric ignition on a gas oven
The ignitor is probably weak. It glows but is not very bright. Mellow orannge color? Replace it.
READ HOW IT WORKS
Jun 08, 2009 | Kitchen Ranges
Oven stop working
In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. The igniter has probably gone bad. ($50.00 to $90.00 for igniter)
May 21, 2008 | Maytag Ovens
Oven won't heat
try replacing the oven igniter/ glow bar the thing you see light up it sounds like it is weak you can tell if it glows with a white color in the bar it should glow a bright orange color
Aug 28, 2007 | Tappan TGFS_63 Gas Kitchen Range
Maytag MGR5750 Gas Kitchen Range Logo
412 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
