Question about Kenmore 57029 Side by Side Refrigerator
Kenmore side by side refrigerators motor continues to run but no longer cools.
  • Kenmore Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerkenmore side by side refrigerators motor continues - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 27, 2010
Not starting after being left open all night.
You may have burned out the compressor motor as it was forced to run all night trying to cool the unit with the door open. The compressor motors in home refrigerators are not designed for running continuously. Call 1-800-KENMORE for help.
Feb 11, 2012 | Kenmore Refrigerators
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Need info for a kenmore side by side refrigerator model#59652673202 it it not cooling nor freeszing ; the light works and the fan works but not cooling any side please help me
Good day,
With that amount of info it would be hard to try to pinpoint it. Here's a list of items that can cause a refrigerator to not cool.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condenser
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
As you can see it could be one of many,many items. If your handy with a meter you might want to start at the bottom back of the machine where the compressor is located.
Sounds as if it is not running, or running without refrigerant in the system.
Also, if it has a cooling fan motor in that area, make sure it runs, since all fan motors are wired to run at the same time.
Oct 15, 2010 | Kenmore 44103 Side by Side Refrigerator
Side by side refrig by kenmore and refrig running but not cooling. freezer is fine. checked settings.
Hello there:
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running. First, answer these questions: Is the thermostat knob turned to the proper setting? If not, reset it. Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these: The compressor The Thermostat The overload, relay, or capacitor The defrost timer The condenser fan motor Cooling is poor A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas: Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Aug 07, 2010 | Refrigerators
Fridge motor on too much it seems
Remember, the colder you make the thermostat, the longer the compressor will run to try and reach the required temperature. Question is," is the temperature in the fridge cold enough or not cold enough." If it is, then you will need to have the thermostat replaced.(there is no control). If not cold enough at any time, then there is an issue with the cooling circuit.(Will then need to have it checked by a technician.
Nov 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore side by side refrigerator freezer and the fan will not stop running. The refrigerator is cooling fine but the fan is running continuously.
The fan must run otherwise the temp. cant be correctly distributed. If temp. is correct, leave alone. If temp. to cold, turn it down untill correct. Fan will very possibly switch off then.
Sep 24, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Freezer willnot longer get cold only cool air
Do you hear the compressor humming? If the compressor does not run then your freezer will not get cold.
Aug 30, 2009 | Kenmore 54263 Stainless Steel Side by Side...
Fridge not cooling.
If it is an 2 motor unit, just order a charge to the refrigerator... but first check if both motors are running, when making cool.
If it´s the gas charge, the refrigerator must be hot, be careful!
if no one hot, than could have a motor or the protection defect!
Best Regards
Aug 25, 2009 | Refrigerators
Kenmore side by side is not getting cold or freezing
Is the refrigerator completely dead?
If so, see “It's stopped completely.”
The compressor
The Thermostat
The defrost timer
The freezer and the fridge are cooled by the same system, air is moved to the fridge by a fan from the freezer, either the circulation fan is defective or the fridge thermostat is defective.
Regards:
VOTIT
Don't forget to rate;
Jul 05, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
88 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
