Question about Acer Aspire 5315 Notebook
Power light for battery charger comes on but goes
I connect power supply to the computer the power light for battery charger comes on but goes out immediately I push power on button. however after a lot of mucking about it will eventually restart and then run perfectly it then tells me that the batteries are fully charged. However should from any reason I turn the computer off it will not restart. Computer is 18 months old. Would a faulty battery cause this problem. Any help with this problem would be appreciated .if I remove the battery I still have the same problem. Bob
  • 99 Answers
From your diagnostic, seems that maybe the ac adapter , thepower supply is the one that is wrong.
if you removed the battery and still having that problem, then you already had taken the battery out of the problem.
get a new power supply, or borrow one to test it.
Posted on Apr 27, 2010
I need a validation code fro quickbooks pro 2011. the Licen number1063-0575-1585-222. and Product number 019-147
i have a dell latitude E5520 laptop,having a power-cut issues,the moment you press the power button,the light comes on then goes off immediately,. when u plug in the charger,the charger light indicator turns on and also goes off immediately. i need help to solve it.
Thank you
Aug 01, 2017 | The Computers & Internet
Laptop compaq will not charge will not turn on. Puting charger on it and pushing the on button i see lights once i release on button light goes out. thinking its charger or its where i plug in charger on...
Try this quick fix, if there are no issues with your charger and/or battery, this might work...
- remove battery
- make sure charger is not connected
- long press the power button for about 1 minute
- release then connect charger or power adapter, without the battery
- press power button to turn on the laptop
If this did not help, try using other power adapter.
Nov 05, 2014 | Computers & Internet
I have a Compaq Presario R3000 with Windows XP OS. Until recently it had been working fine. Suddenly, the power went off while still connected to the AC Supply and the Laptop just went off. The battery...
1. Remove battery from the laptop. 2. Unplug the power cord from the computer. 3. Let the computer sit for a few min. 4. Leave battery out. 5. Connect power adapter to computer 6. Push power button to turn computer on. 7. If computer powers on shut down again, and put battery back in. 8. Push power button to turn computer back on (at this point battery and power adapter should be connected to the computer)
If computer powers on with power adapter with the battery out. You are having a battery issue. You would want to look into replacing the battery. If computer does not power on with just the power adapter. You are most likely having a power issue. Depending on how old the laptop is. You will either want to contact the manufacturer. Or take the computer to a computer repair shop, or consider replacing the laptop.
May 31, 2011 | Compaq Presario R3000 Notebook
My laptop acer extensa 4420 5239 will not power on.The battery light goes green if i charged it fine. It seems that the switch is having a problem or might be the power supply. how would i know?. please...
Probably there is a problem with your battery charger or power supply. It might not charging your battery. The only reason why the laptop would not power on if there is no power supply coming in, either from a battery or a direct connection from the power supply. You can check your battery charger or power supply using a multimeter. Check if there is a voltage reading coming from your charger.
Oct 30, 2010 | Computers & Internet
My dell D810 won't power up. After pushing the power button, one LED light comes on. About 5 seconds later, that LED light goes off. I swapped power adapters and symptoms remain the same. The battery is...
Please try the following troubleshooting steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
Let me know if everything remain same.
Feb 18, 2010 | Dell Latitude D810 Notebook
My roomba mounts up to the charger the light blinks red then after a time it goes green but when I dismount it and push the green button it immediately goes red. It doesn't beep or do anything. It is that...
You have dead nimh (nickle metal hydride) batteries. You will need a replacement. You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new.
Feb 07, 2010 | iRobot Roomba 560 Robotic Vacuum
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
Power light comes on and goes off and machine is dead
The Motherboard is bad but before you buy one.Try this Remove the memory, cd rom,hard drive battery, power adapter. Press and hold the power button down for about twenty .Replace the memory only,power up if you get the same result the motherboard has to be replace
Sep 15, 2009 | Dell Inspiron 9300 Notebook
Compaq laptop will not power up
try taking the battery out, make sure the ac adaptor is not connected, hold down the power button for 60 secs and then put the battery back in and try turning it on.
Sep 14, 2009 | HP Pavilion dv6000z Notebook
Acer Aspire 5315 Notebook Logo
102 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
