Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
SGS46E22GB - Bosch Dishwasher
Installation instructions woeful. Two sides of pictures - few words - on shoddy paper from BOSCH!
First page with header should actually be page 2.
Useful words are added such as "remove disc" with arrows on picture - and repeated over in 5. Why no key words on the other very important parts.
In 1 (4) do I throw away item 4? and leave worktop lid off for under counter?
Why?
When it's on its back in 1 do I throw away plastric trim 7? It does not tell me to put it back on.
What supposed to be coming out of (5) - test water?
What is 2 (11) supposed to be telling me? and where are these brackets?
The spring clip supplied offers no grip at all between supplied out pipe and extension piece.
Go on - have a go at me for being simple - I was an electronics specialist also with a background in electrcal and mechanical engineering with a string of qualifications behind me - Gosh, I must be going senile at 61!
I simply don's beleive it.
Desmond
daddy1264
  • 76 Answers
SOURCE: How do I replace the heating element for a Bosch SHU53 dishwasher
are you sure its the element, the control boards on them get bad soldering joints and the you get the impression that the element is bad, but its the solder joint that controls the element that goes bad....you can resolder that
Posted on Dec 30, 2008
Can't find SGS43t62 float switch assembly
The float switch in most Bosch dishwasher is part of the Aquastop circuit found in the inlet water hose connected under the kitchen sink. Refer installation instructions at this page. Type in the model number and download it.
Dec 06, 2012 | Bosch Dishwashers
I need an operating manual for a Bosch electronic classic dishwasher SMS50E22AU
Please click on the following links to download any manuals you require for your dishwasher:
Bosch SMS50E22AU User Manual Bosch SMS50E22AU Installation Instructions Bosch SMS50E22AU Stacking Supplement
After clicking the links you can open the files in a browser window or save them directly to your PC. You will need to have Adobe Reader (or any other PDF file viewer) installed to open the files:
Click here to download Adobe Reader
Hope this helps. If you have any difficulty downloading the manuals or need further assistance with your dishwasher, please let me know.
Regards, BElectric
Apr 27, 2011 | Dishwashers
Nov 24, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch SHV 6800 dishwasher, 2HR error
Bosch dishwasher all cycles start at 2H and get hungup on 1 min.
Jul 02, 2008 | Bosch SHU9950 Dishwasher
Bosch Logixx dishwasher alarm
I have found the operating manual online (see link to below off Bosch site) which explains how to do this - looks a bit fiddly by twisting dial and press/hold different buttons. Too complex to repeat in detail here so check out the website:
http://www.boschappliances.com.au/content.asp?document_id=430&category_id=86
from the above page (which I know is not the same model)
- follow the User Manual link
- enter the correct model number (mine is WAS32466)
- select the operating manual instructions (installation manual may also be given)
- see section on Individual Settings / Signal.
Sorted.
Andrew
Jun 16, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
73 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
prem mathew
bosch5
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
