Question about Sewing Machines
How do I oil my Bernina 640? - Sewing Machines
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 48 Answers
-remove the needle plate and put a drop of oil near the feed dogs where the shuttle rotates around the basket that holds the bobbin case.
-remove the screw with the offset torques screwdriver,
then oil the needle bar above and below the two supporting brackets, as well asabove the presser foot shaft and on the top of the presser foot bar.
That is as far as the consumer should go, Your local Bernina Dealer whould do a full service after 80 - 100 hours of use at that time the front and back covers will have to be removed and the main bearings cleaned and oiled.
drtension
Posted on May 02, 2010
Replacing the s board in a Bernina 640
What is your question? Can it be done? Yes, but you'll probably want a Bernina tech to do it if the part can be found.
Dec 10, 2016 | Bernina Artista 640E Sewing, Quilting and...
I need the rotary hook only for a bernina 850 can anyone help me
Fixya does not sell rotary hooks and is not a buying service.
Nov 03, 2016 | Bernina Sewing Machines
I want a diagram for oiling my Bernina 640 sewing machine
Hears the first video that came up on a youtube search: https://youtu.be/hJCRfpO_MVo
Nov 02, 2016 | Bernina Sewing Machines
I inhereted a bernina ferreit in cabinet need instruction manual
I believe you probably have a Bernina Favorit. A Favorit is an early mechanical Bernina sewing machine and, to Bernina vintage lovers, is a keeper. Favorits are the flat-bed version, not the free-arm version, but is a wonderful machine nonetheless. If you search the internet using:
Brand +
Model +
the word "Manual"
(ie Bernina 640 Manual)
you might have some luck finding a manual.
Or, you can join the Yahoo BerninaThirtySomethings group
Yahoo Groups, where older manuals are available in the Files section. In addition, you will have access to a wonderful resource of Bernina users/lovers including conversations on using, maintaining, repairing, and assorted other advice about your older Bernina.
The first thing you should probably do is pick up a good quality sewing machine oil (Bernina oil for CB Hook is recommended--however, never use 3-in-1, WD-40, cooking oil, or the old oil can that you might find in the machine's accessory box). Consult the owner's manual in the Maintenance section to clean and oil your machine. If the machine has not been used in several years, the motor may sound like it is straining to move the mechanical parts. Most likely, the old oil has dried out and is sticking things together. Do not force the motor to move things without first cleaning and oiling the machine.
Remove the top cover and swing open the cover on the left side where the lightbulb is located. Gently hand rotate the handwheel and while watching the moving metal parts, apply ONLY one-two drops of oil every place that metal rubs against metal. (Sometimes the oil ports are marked with red paint as a guide, but some machines are not marked.) Use only 1-2 drops at a time. Do NOT over-oil as too much oil can be as damaging as no oil. Gently move all the levers and dials and oil those moving parts as well. Do NOT oil the white plastic gears, the belt, or the large round metal cams (which your machine may or may not have). Then, tilt your machine back and remove the bobbin & bobbincase and with a soft brush, remove any lint, dust. Then while hand-rotating the handwheel and moving the levers and knobs, apply oil to the moving parts under the machine. The feed dogs are usually a problem so be sure to test the feed dog knob. If anything seems to be sticky, resistant to movement, you can also direct hot air from a handheld hairdryer into the interior mechanism to help loosen things. Be sure to place a drop of oil on the bobbin hook in the bobbin area (the manual should show this).
If there is anything that is still sticky, then a few more drops of oil and the handheld hairdryer should be employed until things are moving well again.
A Bernina is a great machine for the sewing enthusiast, but only if it is maintained and cared for regularly. Cleaning and oiling should be performed approximately every 8-12 hours of constant sewing, or every time a bobbin is emptied, or at least every six months if not in frequent use.
Aug 30, 2015 | Bernina Sewing Machines
I have a bernina artista 640 and the material is not moving i tried on plain stich with the 1 c also
the feed dogs need to be checked on the machine, they are the ones that move the fabric thru the machine.
Mar 01, 2015 | Bernina Sewing Machines
How to recalibrate touch screen on Bernina 640?
www.bernina.com/.../BERNINA.../Manuals/031508-50-04_0601_a640_...
Jun 29, 2014 | Sewing Machines
How do i remove the hook from the bernina artista 640
If you remove the hook on a 640, the timing of the machine will need reset, and that involves pinning the machine for precise timing!
Aug 09, 2010 | Bernina Artista 180
How to find out usage on my Bernina 640 w/embroidery
For a 640: Make sure the machine is off then Press the reverse button and the needle up/down button at the same time and keep pressing while turning on the machine until the service screen come up. Select the "i" icon and then the icon that has a picture with the clock and a question mark. That will show you the hours and stitch count used. To exit the service program just turn off the machine.
Jun 14, 2009 | Bernina Artista 180
Bernina artista 640 embrodry
.g_thread_answer { overflow:visible !important; }
Jul 29, 2008 | Bernina Artista 180
Sewing Machines Logo
208 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
