Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
My bosh has been having problems such as when I do 2-3 loads of clothes there will be water still in the bottom. So I have to run a spin cycle to get it out. Or it will eat my clothes my bedding by rippingin them. The lock mechines is clear of clothing. Now I got and Message that read E:O4 and this was my 1st load of towels. what is going on with my machine?
    Problem Solver:
  • 5 Answers
Could be as simple as cleaning the screen trap on pump "the factory doesnt like the consumer doing this'and does not provide instructions in owners manual. you will need towels to sop the excess water if you open the filter knob/handle. also you can shut the water off and do several spin/or drain cycles to get rid of most of what water is left in tub before begining as a lot of water in tub can cause several gallons of water to spill on floor ! this is the reason the factorty dosent want you to mess with it! unplug washer then take a small nail and insert in "hole"of round cover and push in just a little 1/4 inch and turn cover located at bottom right side of machine "front side of machine " you will see filter knob turn it to the left "counterclockw"
clean it and replace and snug it up. eror E:04 says bad control board but that machine must be able to do the very basic operations such as unkinked drain hose,clean filter /good water pump,corect amount of soap ect.. to work right or you may get sporadic operation error codes that are not true!
unplug it and start over!
Posted on Apr 27, 2010
Spin cycle not working properly. A little water (1 inch) is left and clothes are heavy with water. I tried the spin cycle repeatedly - water still at bottom of tub.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Maytag Centennial MTW5800TW Top Load...
My whirlpool ultimate care 2 will not spin clothes completly out unless it runs a spin cycle a few times?
after the first spin cycle check to see if there is any water at the bottom of the tub if you find a couple of inches the problem is probably something plugging the pump tou know that sock your missing. if know water it could be the clutch that drives the spin tube may have oil on it or worn out if oil you will have to replace the spin tube seals and maybe the trans.
Mar 08, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Water in clothes after spin cycle
need to open washer and check the DRAIN MOTOR PUMP , usually gets clogged with lint and debris , usually located at the bottom side , small motor w/ propeller ,where the drain hose is connected, AJ
Nov 11, 2009 | GE WJRR4170E Top Load Washer
Spin cycle
it sounds like there is either an obstruction in the pump, or the load is getting off balance during the spin cycle. two things to try, fill the washer with no cloths in it, when it starts to agitate, stop the cycle and put it in drain/spin cycle. the water should be out in under a minute. its hard to see because the door locks, but you can hear a difference in the pump when its out, or after 60 seconds, press cancel and open the lid to check. if the waters out in that time, the pumps ok. then run it through the spin diagnostic with a load of cloths. make sure the cloths are wet, and a normal load you wash. this will check to see if the load is getting off balance, and shutting down during the spin cycle. let me know if you still have the problem. good luck, shane
Aug 23, 2009 | Maytag Neptune Washer
Clothes still wet at end of spin cycle
i would check your belt.the added stress of a full tub longer with water may have done it in.part#wh1x2026 God bless,tom
Jan 10, 2009 | GE WBSR3140DW Top Load Washer
Spin/rinse cycle
find tech sheet at bottom of washer and follow instructions for checking motor controller (at bottom rear)
Apr 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
Feb 24, 2008 | LG WM-2277HW Front Load Washer
No Spin
Hey, I know it's probably late, but I'm having a similar problem in that it's not spinning and I'm getting an error message of F 02. Did you have this problem? How did you fix yours? Please let me know, I need to wash clothes for my son's prom tonight. Thanks.
Oct 20, 2006 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
104 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
