Question about Kenwood Audio Players & Recorders
Kenwood KRF-V5200D, will not turn on. I'm getting 240V in, but only geting 900mV at the pins to Transformer CN201. Apparently it was dropped, the height was 1/2 to 1 foot. Is there a schematic diagram that I might be able to use?
  • 3,083 Answers
Unfortunately, I do not have a schematic diagram. However, having delt with these kinds of problems on TVs, stereos, VCRs, etc., I would say, over 90% of the time, you won't need a schematic to figure out the problem. Chances are that a solder joint slightly cracked, and possibly broke a trace. I would inspect the circuit boards carefully, especially the legs of the transformers, relays, and capacitors. Unless you can find another owner, the schematics are usually hard to find, and when you do, they can be expensive, so I would try spotting some physical damage before expending the money for a schematic. You only need them maybe once every 10 or 20 years on these machines, normally. Good luck, hope you can see and fix the problem!
Posted on Apr 27, 2010
Connecting ps3 receiver
buy a optical cable and connect between PS to the amplifier or take the optical out from the TCL to the amplifier and select optical in,
Oct 19, 2013 | Kenwood Audio Players & Recorders
Reciever keeps yurning itself off after a few seconds
Assuming running from a cold start,
it means protection circuit are activated.
If it runs hot, then turns off then it is thermal cause.
Simple solution could be disconnecting all your speakers
and power up.
If it runs OK, then reconnect one at a time to find the cause.
If disconnecting the speakers doesnt do anything,
these unit needs repair.
Start checking out power supply
Check the supply rails to the main amp ( B+ and B-)
and most important , check for DC offset voltage on all amp outputs.
Let me know if you need further assistance!
Sep 27, 2012 | Kenwood Audio Players & Recorders
How do I hook up a pioneer dynamic expander ex9000 to a kenwood KRF-V7030D receiver?
• Pioneer EX9000 out to Kenwood V7030D play In
• Pioneer EX9000 in to Kenwood V7030D rec Out
• instruction on page 8 of the manual
PDF] KRF-V7030D KRF-V6030D KRF-V5030D KRF-V4530D
Jul 31, 2012 | Audio Players & Recorders
I NEED A manual for a krf v5200d
  • Hope this helps.
Nov 02, 2011 | Kenwood KRF-V5060D Receiver
I have a Kenwood KRF v5200d audio video control center that worked great for 2 years . It is just out of warranty and is now giving problems. It turns on for about 15 seconds and then cut out and goes into...
i'm not the perfect expert in this but did you try removing all speaker,rca,s video, etc from the back and seeing if something maybe back feeding to the receiver. the red light blinking usually means its detecting a short somewhere and it goes in a fail safe mode to prevent more damage. if it stays on with everything disconnected the problem is with something else. try them one at a time to isolate the problem. hope this helps thank you.
Jan 01, 2011 | Kenwood Audio Players & Recorders
Music, sound effects no dialogue
MAKE SURE YOU HAVE ALL THE AUDIO SELECTIONS ON UR PS3 CHECK THE BOXES ,,IN THE AUDIO SETUP
May 14, 2009 | Kenwood KRF-V5060D Receiver
I have a brand new kenwood krf-v5200d amp. when I turned it on the first time it when't straight to the standby light blinking. I have checked all speakers and they are connect correctly. Any idears
#1 check the batteries in your remote,#2 if this is a new system contact the the dealer(let them handle it)i'm sure they will make it right.(what i'm saying,is don't void your warranty buy trying to fix it your self.enough said!thanx for using fix-ya!!!
Nov 29, 2008 | Kenwood Audio Players & Recorders
Amplifier main channel non operational.
first pull out the power transistor then biased the output terminal. base,emitter have dc volts .4 to .5 collector to emitter have full voltage. if this voltage are in ur pre amp buy new trasistor
Sep 09, 2008 | Audio Players & Recorders
Increase AM bandwidth to 531khz to 1700khz
ya am booster antenna of the am output u could try 1st or u saying teh kenwood limites u to 1620 max only ch >
Jan 23, 2008 | Kenwood KRF-V5060D Receiver
746 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
