Water does not shut off unless turn off manually
  • Washing Mach... Master
  • 43,501 Answers
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Posted on Apr 27, 2010
Water will not turn off.
The washer that stops the water has broken and needs to be replaced.
May 27, 2013 | Kenmore Washing Machines
Steam valve won't shut off
If the water sprays after the dry cycle has completed and you have to physically have to turn the tap off, then you need to replace the water inlet valve on the unit. Here is a link to the valve.
Oct 20, 2012 | Frigidaire FASE7073LW Affinity 7.0 cu ft...
What's your problem?Water dispenser spewing out water on GSH25KGMB
Solenoid water inlet valve stuck open. Probably foreign object in the plunger. You can probably twist the top off to clean it.
Apr 25, 2012 | GE Refrigerators
Simple question. no manual. need to shut down mac2000v for a couple weeks. besides turning to "0", do I need to blow out steam?
No, unless it will be in a cold location that it might freeze, the most you will have to do is turn off machine and water supply.
Aug 16, 2011 | Nuova Simonelli Mac 2000 Espresso Machine
The automatic drain hose is hooked up to the back of the unit, but when the bucket is full, the automatic pump does not work. The automatic pump should come on and empty the bucket, but it does not come...
Any automatic pumps operate off a swith that is turned on when the water rises. They normally have some type of ball lift, that will raise the switch when water is high and then drops with the water and shuts the pumps off. It sounds like yours is stuck and not activating the pump.
Jul 06, 2011 | Vacuums
Front windshield wipers turned on by themselves and will not shut off manually unless fuse is taken out . please help 2002 gmc chevy envoy SE
If you have the automatic rain sensors try un-plugging the round "disc" on the windscreen. This is the sensor and might be shot.
Feb 25, 2011 | 2002 GMC Envoy
Our Miele DW just keeps going through cycles constantly and will not shut off on its own. It has gone all day. When we turned the dial manually to "OFF", the water keeps filling until it overflows the...
hi,
sounds like a faulty electronic unit as i have seen this before where the unit continously fills with water.
you will probably need a service call to repair the unit unless you are happy to fix it yourselves. have a chat with Miele directly as they are very helpful
Hope this helps.
Jun 20, 2010 | Miele 24 in. G865 Built-in Dishwasher
Cooling unit does not shut off
Replace Thermostat and find the model number, Sea Breeze
Mar 17, 2010 | Hamilton Beach Water Cooler with Storage...
On my Maytag Neptune MAH-3, the water is running non-stop
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
Oct 12, 2009 | Maytag Neptune Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
