Question about Adobe Audition 1.5
Adobe Audition 3.0 freezes when I try to burn a disk.
    Scholar:
  • 103 Answers
I'm not sure if applying the Audition patches / updates will do it for you. I haven't installed them myself since I havent had the need for it.
If Adobe Audition 3 freezes when refreshing DirectX plugins list, follow these instructions to temporarily disable the DX plugin. This should allow you to refresh the list without freezing Audition and then go back afterwards and re-enable the DX plugin to avoid damaging the full functionality of its parent application. (Note: This said because Roxio and Nero, for example, use DX plugins that are detected by audition and make it freeze, but if deleted permanently could impair either the application, FOLLOW INSTRUCTIONS EXACTLY!)
This method I figured out and used for my own purposes on my own system. It has worked flawlessly and repeatedly whenever I require. I warn you, it can be a huge a pain in the ****, so be ready.
Disclaimer:
I am not in any way responsible or liable for any damage caused by the usage of these instructions. You agree to use them at your own risk!
Instructions:
You will need to have downloaded and installed DXman from AnalogX site, get it here:
http://www.analogx.com/files/dxmani.exe
1. Start Adobe Audition
2. Go to 'EDIT' mode
3. Once in 'Edit' mode, drop down the Effects menu.
4. Make sure the DirectX Effects are enabled (otherwise click on 'Enable DirectX Effects' to do so)
5. Click on 'Refresh Effects List'
6. Let the refresh start and standby until the progress bar freezes.
7. Notice on the lower right corner of the 'Refreshing Effects list...' dialog box the name of the effect that is displayed and write it down. That should be the one that has caused the freeze. (i.e. ROXIO VCFWaveform 1.0 or something like that)
8. Go ahead and close Adobe Audition. If it won't click closed because of the freeze, use the task manager and kill the process.
9. Run DXMan
10. Once the list is populated, search through and find the DX effect you just wrote down.
11. Once found highlight it and click on 'Info'
12. Notice on the 'Info' Screen the "Filename' and 'CLSID' fields and make note of them.
13. Open the path to the 'Filename' you wrote down on a window and find the file indicated (.dll or .ax)
14. Right click the file and select rename. It will highlight.
15. DO NOT delete the name while highlighted. Hit the END button to go to the end of the filename beyond the extension and type .BAK
It should look something like this:
filename.dll.BAK or filename.ax.BAK
(If you don't see the original filename's three or two-character extension (.dll or .ax), make sure you have that feature enabled within folder options in Windows)
16. Now go to the start menu and click on 'Run'
17. In the field type in 'regedit' (without the hyphens ofcourse) to open the Registry Editor
NOTE: YOU ARE ABOUT TO USE A REALLY SENSITIVE PART OF THE SYSTEM, DO NOT MESS WITH ANYTHING ELSE IN HERE EXCEPT WHAT HAS BEEN INDICATED! YOU COULD PERMAMNENTLY DAMAGE WINDOWS OTHERWISE.
18. Click on 'Edit' and then 'Find...'
19. Type in the long CLSID number you wrote down earlier (Exactly as it is) and click 'Find Next'
20. It will search through for a bit and will find and highlight a matching entry
21. Once found, right-click that entry and click 'Export'
22. Save the entry to the desktop with the Effect's name so you won't forget what it's linked to (i.e. effectname.reg)
23. Once saved, right-click the entry and delete it. At the confirmation dialog click yes
24. Once deleted click 'F3' key to find the next ocurrance within the registry (if there should be one) and repeat steps 20-24 until there are no more matches found, with the only exception you'll save the following ones with a numerical difference to avoid overwritting the first one found.
i.e.
effectname.reg
effectname2.reg
effectname3.reg , etc
25. Run Adobe Audition and try refreshing the list again (steps 1-5)
26. If there was only one DX Effect creating the conflict, it should refresh and finish just fine this time. If it freeezes again repeat steps 7-24 and follow the cycle until the refreshing goes by fine.
27. Once successful close down Audition to re-enable the DX plugins (again, as to not affect the parent application)
28. Go back to the filename path back in step 15. Right-click the original file and remove the .BAK to return it to its original format (back to .dll or .ax) but remember if you should refresh the Effects list after re-enabling the DX effects it will more than likely freeze again and you'll have to start over. Audition should work just fine with all your VST and DirectX effects after fixing it, you shouldn't have to refresh the list unless you install a new effect in the future. If you know you might purchase and install new effects later on, then keep handy the name and info of the effect that was making the conflict for easier fix later on.
29. Once that done, go to the folder you saved the .REG file(s) (step 21-22) and double-click them and hit yes for every confirmation.
30. Voila!, you have disabled and re-enabled the conflicting DX Effects and saved the day for Adobe Audition!
Happy music making!
Posted on Apr 27, 2010
Can you download Adobe free from enternet. does it help see music videos on the net or any videos for that matter.
Adobe's a company. They make products for print and web design. You can buy their stock at an exchange, and you can download their software via the internet; but many of their products (including educational products all about Adobe Audition) are not licensed free of cost. Some are though, so check out Adobe.com. Adobe Audition is used in editing and compositing audio, as if it were software for making an audition reel; so music videos might (and do) credit Adobe Audition with having helped out making professional-grade work. Audition can come bundled with Adobe's CS5 suite.
Aug 28, 2011 | Adobe Audition 3 for PC (22011292)
I dont have a adobe audition.
Try this website if not this http://www.brothersoft.com/adobe-audition-67325.html choose anyone for your suitable.
Hope you'll like it
Thanks for Using FixYa All the Best!
Aug 01, 2011 | Adobe Audition 3 for PC (22011292)
Serial number
try this serial number for adobe audition 3
S/N: 1137-1764-5946-8723-9926-5853
keygen; http://www.badongo.com/file/5116403
Crack; http://www.badongo.com/file/5116104
May 17, 2011 | Adobe Audition 3 for PC (22011292)
Free serial key for Audition 3.0 anywhere?
Glad to help YOU!
Sorry to offer you this information... but THERE IS NO FREE SERIAL for Adobe Audition 3...!
Once you have purchased it you will get your UNIQUE serial that will fit that software.
But it's in your power to do a search on the Internet like "Adobe Audition 3 serial" and see what you will find out.... You'll never know!...
GOOD LUCK!
Mar 12, 2011 | Adobe Audition 3 for PC (22011292)
Fast download of adobe audition for free
1- Partner with artists and producers at studios using Audition.
2- Get some fame and share props with Adobe Audition developers for a year or two.
3- Fast free download and license from Adobe!
Aug 13, 2010 | Adobe Audition 3 for PC (22011292)
No sound in waveform editing in Adobe Audition 1.5
try uninstalling and then reinstalling back Adobe Audition 1.5 or try out Adobe Audition 3
Feb 10, 2010 | Adobe Audition 1.5
I cannot switch to multitrack view
I have the same exact problem....same damn thing and it is so frustrating because I need to finish a song today!!!!!!
Dec 07, 2008 | Adobe Audition 3 for PC (22011292)
Can't record in multitrack
Adobe Audition 1.5
It seems your adobe audition 1.5 is missing file / files or adobe's registry has gone corrupt. If you ever run registry cleaners or registry fix some of them corrupt the registry of this adobe audition 1.5 try Reinstalling the Program and it should work. This Program is very Reliable and shoud have no problems with it. I use it all the time to download from internet and then edit to my requirement. I hope this helps. If you still have problems try to down load trial software from www.adobe.com Adobe audition 2.0 is free for download to try.
Good Luck
Jan 17, 2008 | Adobe Audition 1.5
Adobe Audition 1.5 Logo
278 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
Laxman Bisht
Laxman Bisht
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
