Question about Brother MFC 6490CW InkJet Printer
Unable to print
Hi my printer says unable to print #36 what does this mean and how can I fix
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
Hi I have Brother dcp 350 printer. I have the error 46 unable to print/clean i cant get the printer back to normal functions. I have change the inks (all) and I am still get the same error message 46....
The messages unable to print, unable to clean, unable 36, error 46 and error 32 are all print head errors.
1. Remove all the ink cartridges from the machine
2. Clean the contacts on the cartridges as well as inside the machine itself with a small amount of warm water or alcohol on a cotton swab until no ink comes off on the swab.
Note: if any of the other cartridges are low, empty, leaking or bulging replace them
3. Then turn off the machine and unplug it for 70 seconds
4. Plug it back it and wait for the insert cartridges message
5. Insert the cartridges and check to see if the problem is still there. If it is it means the print head has failed and in order to fix this the print head inside the printer needs to be replaced. The print head is the part of the printer that puts ink from the cartridges onto the page
Unfortunately this can sometimes cost more to replace then the machine itself.
Apr 18, 2011 | Brother DCP-350C InkJet Printer
I have a message on my display screen that says "unable to print 36" What does that mean and how do I fix it?
36 usually means that a paper is jammed. You will have to open it up and manually remove the paper.
Mar 22, 2011 | Brother MFC-845CW multi-function...
Give me solutation of errore 36 came inb DCP165C Brother Printer
That error 36 - means "Head/carriage unit travel error" , if the printer is still under warranty, have it serviced. But if its out of warranty try to find any obstacles on the travel path of the head/carriage unit. If you cant find anything, it only means you need to replace some parts.
1. carriage PCB
2. head/carriage unit
3. CR encoder strip
4. carriage motor
5. main PCB
6. power supply PCB
7. maintenance unit
May 13, 2010 | Brother DCP 165C Compact Color Inkjet...
Printer message "unable to print 36"
That error usually means a paper scrap or something is stopping the carriage from moving across the paper correctly, or there are scraps caught on either side of the carriage assembly.
Aug 28, 2009 | Brother MFC-465CN InkJet Printer
Error message on my printer that says unable to print 36
If this is a Brother clean the clear strip on the carriage assy. it is a timing strip for the carriage , I have seen ink on these cause the "36" code
Jun 05, 2009 | Office Equipment & Supplies
Unable to print 36
lift the lid to where the connections cable is
I have had this problem several times & this is the only fix
Jan 26, 2009 | Brother MultiFunction Center MFC-440CN...
Print unable 36 error
The 36 error mean: The machine does not work due to a paper jam. Clear the paper jam, if doesn't work maybe a sensor is dirt or bad. To disassambly the printer you need the service manual and some know how ( electronics knowledge).
All the best !
Feb 21, 2018 | Brother Multi-Function Center MFC-240C...
Brother MFC 6490CW InkJet Printer Logo
713 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
