Question about Cell Phones
Phone will not ring
New LG 290C is set to ring and vibrate, but will not ring - only vibrates. Will not play any of the preloaded ringers. Have tried all of the settings & ringers, but no luck.
  • 4 Answers
SOURCE: Setting Vibrate on an AX260 (LG Scoop)
Okay, here's your answer:
1. Open up your menu and go to "Settings"
2. Select "Sound"
3. Select "Alert Type"
4. And finally select ring and vibrate
Cheers!
Posted on Mar 17, 2009
SOURCE: no sound when phone rings
I called Verizon Wireless and the said, if you go to “My Sounds” or “My Ringtones” select the song that you want to hear and press the play button. While the ringtone is playing press the button on the side of the phone to raise the volume…you should be able to hear the ringtone. Hope this helps!
Posted on Dec 12, 2007
SOURCE: Stuck on silent mode and cannot get the ringer to ring
rings
Posted on Dec 22, 2007
  • 21 Answers
SOURCE: Pebble ringer inop
1 try this go setting initial/setup/master clear
password 000000 (6time) or full up 0 .
Posted on Mar 10, 2008
SOURCE: lg shine #cu720 will not ring and vibrate simotaneously
1. Menu -> "Settings"
2. "Audio & Ringtones"
3. "Alert Types"
4. "Ringtones"
5. "Ring & Vibration"
-Nick G
Posted on Apr 25, 2009
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
Phone will only vibrate and not ring
a. Make sure your ringer is not in vibrate mode.
1. Press Menu > Settings/Tools > Settings > Sounds > Ringer Type > Voice Calls. 2. Select Caller IDor No Caller ID. (A list of ring type categories will be displayed.) 3. Select a category, and then use your navigation key to scroll through the available ringers. A sample ringer will sound as you highlight each option. 4. Press OK to assign a ringer.
b. Make sure your speaker works. Turn On your speaker phone while talking to someone and see whether you can hear or not.
c.Make sure the increase the volume using keys on side of your phone.
Mar 14, 2011 | LG RUMOR Cellular Phone
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Feb 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
LG AX390 phone does not ring, only vibrates
Mine will not ring... It just has a stupid female voice that says call from xxxxxxx call from xxxx and I can't hear the voice when I am operating loud equipment?????
Aug 02, 2010 | LG AX390 Cellular Phone
My LG VX-8700 does not vibrate. Ring works, but vibrate mode is the same as silent mode. Can this be fixed?
Yes,
What happened is you probably set it on silent and from the soft keys, you increased the ringer volume. What you want to do is go to main menu => settings => profiles, and from there make sure your ringing volume is set on lowest possible.
Oct 28, 2009 | LG VX-8700 Cellular Phone
Vibration only vibrates once
You will have to change the ringer under sound settings to "Vibrate and Ring", it is currently set on "Vibrate Then Ring".
Hope this helps,
Simon.
Oct 23, 2008 | LG VX8300 Cellular Phone
Locked on vibrate
Problrm solved, found the ringer volume was set to lowest level, thus turnning on the vibrate. Wife did it!!
Mar 09, 2008 | LG CU400 Cellular Phone
Pebble ringer inop
Mar 03, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Will not ring or vibrate.
Go to settings... personalize....ring type... pick loud ...scroll down to edit then go in and change from silent to the ringer setting you choose
Jun 26, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Cell Phones Logo
109 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
