Question about Acer AL1916W 19" LCD Monitor
Unclear picture I have turned on the monitor and I have green small boxes all over the screen, very unclear.
  • 813 Answers
Install your vga driver proper & set the resolution of ur monitor
Posted on Mar 24, 2008
Small rectangle in the middle of the screen with the letter i in the left corner, the buttons are lockeder la hello 17
If the picture disappears from the screen and the
1 (power) indicator is green
Turn off the 1 (power) switch and disconnect the
video signal cables from the monitor.
Turn the monitor on by pressing the 1 (power)
switch.
If all four color bars appear (white, red, green, blue), the monitor
is working properly. Reconnect the video signal cables and check
the condition of your computer(s).
If the color bars do not appear, there is a potential monitor failure.
Inform your authorized Sony dealer of the monitor's condition.
Be sure to note the model name and serial number of your
monitor. Also note the make and model of your computer and
graphics board.
Mar 18, 2014 | Sony SDM-HS75 17" LCD Monitor
I have a Sharp LC-46E77UN TV. Remote will start TV green light on. No picture, just stays black. PVR is on and connected to TV via HDMI cable. Cannot turn off green light. Must use power button on TV and...
THe problem is in the set top box. Or common called the tuner box. IT looses the 5 volts to the main display and thus the monitor will go into a shut down state. THESE boxes are factory repair only and must be sent off to repair.
Feb 20, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sound is ok picture with green screen
The exact problem you are describing here is unclear. Are you getting a clear picture just in green or are you getting just a green screen with no picture at all? If the first, then you are sending a composite signal into the component connectors. A composite signal (typically the yellow connector) is the entire picture over 1 wire. Component requires 3 (RGB being the most common). Verify that you are using the correct input for the signal type and update this with any additional details about the status of the set.
Thanks,
Dan
Dec 29, 2010 | LG 42LC2D 42 in. LCD HDTV
Hi sir. when i watch any video songs or movies
your videoes have a small pixel say 320x240 so when you blow it up to say 1440x900 the player has to ADD pixels that dont exist. so you get an unclear picture.
Aug 12, 2010 | LG W1953TPF 19" Monitor
Even if i switch on my computer with moniter it doesnt show anything on moniter screen it remains black
Hello. With the computer and monitor OFF, disconnect the signal cable from the video card on your system. Next, turn on the monitor. There should be a bright green box with a pink outline of a video connector inside showing. If there isn't, and the monitor is definitely powered up, then there is an internal problem. If there IS a little green box, etc., the video card in your system is suspect.
  • 1) When turning on the monitor, do you hear the sound of the high voltage initiating?(i.e. you should hear some type of electronic noise like a vibration or crackling of static on the picture tube)
  • 2) If you do hear that high voltage kicking in, it may very well mean that the picture tube is dead and getting a replacement monitor is in your future.
  • 3) If you don't hear the high voltage, quite possibly the transformer that produces it(called a flyback transformer) is defective.
Due to the vast array of inexpensive monitors available, you probably should consider getting a new unit--the cost of a new display will rival the cost of the repair--and you get a fresh warranty to boot. If the picture tube is gone, there's no choice.---Rick
Oct 02, 2009 | Samsung 793S 17" CRT Monitor
The screen looks out of focus and the top and botton bend inward.
Remove front bottom panel behind it is a small black control box top controls are focus controls for R/G/B and Bottom 3 controls are your screen drives adjust one at a time turn off G/B adjust red first,then Do Green and Blue fter adjusting focu to each tube leave them set then adjust screen drive turn color off adjust RGB for a Black and white picture get as close as you can then turn color back If after doing this you still have blurry looking picture look down into Tubes you should be able to see picture clearly in each one if you cannot see picture then projection Fluid need to be changed out. Call Mats 1-800-628-1118.
Sep 26, 2009 | Sony KP-53S65 53" Rear Projection...
The adapater box (small retanglar black box with green light (when monitor is on)is severly overheating on my StarLogic Monitor. I have a single plug in cable that goes into the back of the monitor. I them...
you need to get a better grade cable from the wall outlet to the plugs for the computer and monitor it most likely can not take the load high energy use will cause degrading on the wire and can cause a fire hazard, at your local hardware store they can sell you a better quality extension with a power surge protection unit built in that would be best.
Mar 20, 2009 | Computers & Internet
Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Mar 14, 2009 | Protron PLTV-37 37 in. LCD Television
LG 710s monitor problem screen turns green
Your AUTO settings button is stuck in! Try tapping on it a few times. Otherwise you may have to take the frame apart so you can get at the button.
Dec 28, 2008 | Amptron AMV 17V5 17" LCD Flat Panel...
Acer AL1916W 19" LCD Monitor Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
