Question about Dell OptiPlex GX280 PC Desktop
Hello, The Dell GX 280 is giving 6 long beeps when turned on, and the fan is running very high. The operating system does not boot up. Thank you.
  • 1 more comment
  • billb108 Apr 27, 2010
    Thank you for writing. I'm a novice at this, so I went to a diagram, can you help me by identifying the numbers of the battery and ram, Thank you. Bill
    Small Desktop System Board
    RTC reset jumper (RTCRST)
    14
    front-panel audio cable connector (FRONTAUDIO)
    power connector (POWER)
    15
    line-in, line-out, and microphone connectors (AUDIO)
    floppy drive connector (DSKT)
    16
    network connector (NIC) and USB connector (USB2)
    battery socket (BATTERY)
    17
    USB connectors (USB1)
    5
    internal speaker (SPEAKER)
    18
    diagnostic lights (DIAG LED)
    6
    front-panel connector (FRONT PANEL)
    19
    serial port connector (SER1) and video connector (VGA)
    7
    CD/DVD drive connector (IDE)
    20
    parallel port connector (PAR)
    8
    serial ATA drive 0 connector (SATA0)
    21
    power connector (12VPOWER)
    9
    standby power light (AUX_PWR)
    22
    processor connector (CPU)
    10
    memory module connectors (DIMM1, DIMM2, DIMM3, DIMM4)
    23
    heat-sink/blower retention pad
    11
    PCI Express x16 connector (PEG)
    24
    fan connector (FAN)
    12
    PCI riser connector (PCI2)
    25
    serial port 2 connector (SER_PS2)
    13
    CD drive analog audio cable connector for optional analog audio cable (CD_IN)
    26
    password jumper (PSWD)
    Also, please forgive, me I understood that holding down the on/off button was to be done with the power cord off, perhaps that is not true. Thank you.
    Please refer to part nos. below if possible. Thank you.
    Small Desktop System Board GX280
    14
    15
    16
    17
    5
    18
    6
    19
    7
    20
    8
    21
    9
    22
    10
    23
    11
    24
    fan connector (FAN)
    12
    25
    13
    26
    President:
  • 1,851 Answers
Usually the 6 long beeps refer to keyboard problem. This is an idea but in case your Dell uses the Optiplex bios this maybe different. Try the keyboard and post me back. Also take a look at the 4 leds at the connectors' side of the motherboad. What is their state, green or orange?
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Aug 09, 2010
  • 560 Answers
Remove and reseat all expansion cards and memory modules. Clean the cards/memory contacts with pencil eraser and clean the mainboard with air blower before re-inserting expansion cards and memory module. Insert memory module and video card (if external) then turn on the computer. If the computer turns on properly, re-insert all other expansion cards.
Posted on Apr 27, 2010
  • Liza Halbrook
    Liza Halbrook Apr 27, 2010
    There should be four (4) LED (small lights), which ones are on and what are the colors? Those are diagnostic lights and should tells us something.
  • 2,427 Answers
Ok try,, first unplug system
1.) open the system
2.) locate the bios battery
remove battery
remove rams
press and hold power button for 30 seconds
replace rams and battery..
turn on system ,,
press F2
  • Rishi Roshan Ali Apr 27, 2010
    10 is the rams,,
    the battery is a large version of a watch battery,, it looks like a shiney silver coin..
Dell optiplex gx 280 beeps 6 times when turnd on and nothing happens
The ram is either bad or unseated. Reme it all and reseat it. If that doesn't work, boot after adding each stick to find which stick or slot is bad.
Nov 11, 2012 | Dell Computers & Internet
I have dell optiplex gx 150 beeps 6 times and a and b led is amber and c and d led is green
the 6 beep codes will be in a specific timing i.e. two beeps, a space 2 more beeps, and another space and 2 more beeps.
Looks like it may be a memory problem according to the lights.
ad54556.gif Possible memory failure
Reseat all DIMMs and restart the system to retest.
Here is the link to the beep codes and diagnostic lights for your dell optiplex gx 150 HERE
The Beep codes are in Table 2 and the diagnostic lights are in Table 3.
Apr 14, 2010 | Dell Computers & Internet
No Display in dell optiplex gx280 & Fan speed is veyy high
GM from pakistan fsd problem in motherboard chepset......you should repare u r gx 280 or heat the chepset with heat gun ........
Aug 16, 2009 | Dell OptiPlex GX280 PC Desktop
6 long beeps Dell GX280 -- unsolved Please help auntie! I have four PCs model RB-DT-OL-Dell GX280 ? they are fairly thin and light, you can open them like a suitcase. They worked just fine, then all of a...
I had 1 long beep, 3 faster beeps, then 2 beeps *I think*, and also my fan was going crazy fast - like someone else said "a vacuum cleaner"...
Well, I reseated the memory and problem was gone - it did seem like the memory was kind of "loose" - perhaps from shipping (bought this used).
The link to Dell's website was good for the beeps AND the "ABCD" codes reading on the back. Thanks very much! God Bless.
Jun 27, 2009 | Dell OptiPlex GX280 PC Desktop
Checkpoint [ithr]
the problem description is
Ithr
Smm mode is initializing the thermal probes.
problably the system is running at high temperature because of improper fan speed, so try to clear the nvram if its not working flash the bios if still the issue persists, replace the heatsink assembly and the motherbord.
Apr 02, 2009 | Dell OptiPlex GX280 PC Desktop
My dell gx 280 just put new ram
Here is the code,Please make sure the memory you used is DDR2 and please rate this a fixya
Feb 14, 2009 | Dell OptiPlex GX280 PC Desktop
Dell gx 150
Chuck,
The 6 beeps are an error code. You should note a pattern such as 3 beeps, short pause, 1 beep, short pause, 2 beeps. Also, you may have a set of 4 error indicators on the back of the unit that will show a pattern of green and yellow lights. In any case, you will want to try to run the Dell diagnostics. Let us know the beep pattern and the light pattern and we should be able to give you some more specific information.
R-
Nov 05, 2007 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
162 people viewed this question
Alun Cox
