Question about Brother 1034D Mechanical Sewing Machine
BROTHER OVERLOCKER I have forgotten how to move the blades left of their normal position (in order to make a narrower stitch when I use a narrow footplate). Also, I have forgotten how to make the overlocking stitch shorter (closer together). Can you help?
  • overlocker59 Mar 24, 2008
    I forgot to say I am using an older machine - not the one pictured - mine has the manual turning tension wheels
    Problem Solver:
  • 9 Answers
Click on this to go to the brother website and download your manual in PDF format.
Posted on Dec 13, 2008
Setting a elna 792d for rolled hem
I don't know your model in particular but generally this is how you set up a serger/overlocker to create a rolled hem. Remove the left hand needle and thread if 4 threads are threaded). Now there is usually a lever around the stitching area that you slide back towards you to remove the stitching finger back (disengaged). Then you adjust the top looper tension looser (about 2-3) and lower looper tension tighter (7 or 8). Leave needle tension at normal tension (5). You may need to move the cutting blade to the right too. The technique is to cut the fabric wider but with a narrow stitch so the cut edge rolls under within the stitching. You want the top looper thread really loose so it rolls right around underneath up against the needle thread, the lower looper thread needs to be tight and almost invisible, pulling the upper looper thread down. I usually do a few test runs and check the stitching. Once happy, I turn the stitch length right down to 1 so it is very dense. This uses a lot of thread up.
Ideally use a wooly overlock thread on the upper looper as this "fluffs" out once stitched and "fills" in covering the fabric edge completely.
some good images here
Sewing Basics Narrow Rolled Hems with Serger Sew Mama Sew Outstanding...
Jul 18, 2017 | Elna Sewing Machines
Adjust stitch width to narrow for an Elna 654 overlocker
What you are looking for is "cutting" width. The adjustment moves the cutting blades in or out, thus increasing or decreasing the seam width.
Mar 11, 2016 | Elna Sewing Machines
I don't have a owners manual for a14SH654 singer serger, my sister in law gave me hers when she got a newone. My question is: Who do get a smaller stitch, I need to get a really short stitch, like a...
If you mean you want to close up the density of the stitching then you change the setting on the stitch length knob which would be on the right side of the machine near to the flywheel. However, if you mean you want to make a narrower stitch width wise, then this is achieved by several adjustments. Firstly, if it s a 4 thread, then unthread the left hand needle so it is only making a seam with three threads, the upper and lower loopers and right needle. Test this seam and see if it is narrow enough.
If you want it narrower, then you need to move the position of the lower cutting blade to the left so the machine is trimming closer to the needle. Test again. If the stitches are now hanging off the cut edge a bit, then tighten up the upper and lower looper thread tensions by a half number and test again. You want the threads to meet right on the cut edge so if the top looper is rolling under to the bottom then tighten it up some more (higher number) in small increments, test stitching after every adjustment.
I hope this makes sense to you. You should be able to download a manual from the Singer website, link is then type in just the number of your model and click "search" give the page time to build, then click on the "free download" button to bring up the pdf file, again give it time to load, its a large file. Then save to your PC.
Oct 15, 2011 | Singer 14SH654
Correct settings for 804dsp serger to sew a sweater.
Are you wanting to use the serger to sew a hand knitted sweater together? or do you mean a sweat shirt knit or other knit fabric. If it is the first option, I'd say don't bother, as you can't do it with the blades working because it will cut your knitting and the wool will unravel in the seams.
If it is the second option then I would start with the following settings.
Four thread stitch, so both needles and the upper and lower loopers threaded. Set tension on all four dials to 5, stitch length to between 2 and 3, and differential on zero. Move the cutting blade over to the right for a wider seam. Now test stitch on some fabric scraps double layer and see what the seam is looking like.
Now you want to adjust a couple of things: firstly width of the seam. Is it the size you want? If you'd like it a little narrower, then adjust the cutting blade back a little to the left to narrow the seam slightly - just depends on the fabric weight. For example if it is a loose open weave like boucle you would want a wide seam to make sure it holds the fibres fully.
Now you can adjust the upper and lower loopers to get the thread wrapping around the edge looking nice. Look at the seam and the fabric inside it. Is it tunnelling and pulling up the fabric? if so, release tension on both loopers a half number to put more thread into the seam. Test stitch again and see if the loopers are meeting nicely on the cut edge of the fabric. Upper and lower looper threads should be meeting right on the cut edge so if this isn't happening and one showing on the other side, then tighten the looser one by half a number and test again.
If the threads are hanging off the edge then you have the choice of moving the blade to the right to cut less fabric off, or tightening up the looper tensions to pull in the thread.
That's it, hope this helps you to master your serger.
If you'd like some images and further explanations of other stitching you can do with your overlocker, then Debbie Coswell has some great information on line at, just search "overlocker" to find the specific pages.
Good luck
Oct 11, 2011 | Simplicity Serge Pro SW432 Mechanical...
Bernette 334D overlocker - the edge of the fabric rolls under - can someone please tell me which thread needs adjusting? I only seem to make it worse...I don't think I have ever been able to get this...
I can help you with your 334D as I have the same machine; there is several ways to adjust the stitching width but firstly check the stitching finger position is forward not back for rolled hemming. There is a little lever that is on the side of the cutting plate just in front of the foot and feed dogs, you need to push this forward; this inserts a stitching finger into the needle plate and the overlock seam forms around it. When you pull it back the finger retracts to form rolled hemming where you want the fabric to roll under. So hopefully this is all that is happening now with yours but I'll go through the whole process for clarity and others.
This is how I set up for a new fabric project. Turn the tension dials for all four threads to 5. Your needle tensions should not need to be changed often; perhaps just if from the right side of a seam you can see the needle stitch, you may tighten it fractionally. Stitch length knob on the side by the flywheel should be on about 2 and a half and the differential knob on zero also.
Now you want to adjust the cutting blade position firstly to get the width of seam best suited to the weight and type of fabric you are going to seam. If you are going to use the overlocker to join two pieces of fabric in a 4 thread seam to assemble a garment, then always test with two layers too. And if you are going to just neaten a single layer seam allowance, then test on just a single layer and set up for that.
I'm assuming you are seaming 4 thread but the comments are the same for the 3 thread, you just take out the left or right hand needle first or just cut the thread to that needle and leave it in place to get the 3 thread stitch. (Obviously if you are seaming something delicate like silk, take the unused needle out as it will leave holes in your fabric. Be careful when changing needles, use tweezers to hold the needle right up into the housing and never unscrew the screw too far, just enough to get the needles in and out. And always manually turn the flywheel towards you through a stitch sequence afterwards to make sure you've got the needles clearing the loopers, if you hear them touching, recheck needles are fully into housing.)
If you are seaming something light then you'll want a narrower seam. Have you moved your blade before? If not, you need to turn the needle to the highest point, open the front cover and raise the pressure foot and swing it to the side so you can see better. Now put pressure on the upper cutting blade towards the right to release the spring on it, then swing it upwards out of the cutting position. Adjust the position of the lower fixed blade by turning the knob that is nearby to it. You'll see the blade moving over. Once you get used to making this change, you can just put pressure onto the upper blade to release it with one hand, and turn the knob to move the bottom blade with the other.
If you move it towards the right it will trim further away from your needles giving you a wider seam and if you move towards the left you'll get a narrower seam, ie it cuts closer to the needles. So set it to the position you want depending on what you are seaming. Now relower the upper blade into position, swing pressure foot back into place and test stitch again on fabric offcuts. Take a look at the seam. Is the fabric "tunnelling" inside the seam? if so, release the tensions on the upper and lower loopers by a half increment only. Test again. Repeat process until tunnelling is gone and fabric is sitting flat inside the threads.
If the threads are looping off the edge of the fabric, then increase the tensions on the upper and lower loopers by a half increment only. Test again. Repeat process until the threads are sitting right up against the cut edge, and meeting right on the edge.
That is basically it - please feel free to ask me again for more help is this hasn't been clear or you still struggle with this machine. I presume that you don't have the instruction manual for it so I could scan a page or two if this will help.
This is a really good quality overlocker so don't give up on it; it sounds like you have just never been shown how to use it fully or never had the manual; consider purchasing one from Bernina or online as it is very instructive. If you find that you still struggle with getting the stitch tensions right, its a good idea to spend an hour or two with some calico and thread it up with four different coloured threads like the diagram inside the looper cover, then make stitching samples and adjust until its right. You can make a four thread, three thread wide with left needle, three thread narrow with right needle, 3 thread rolled hem and flat lock. Write down the tension numbers, stitch length and blade position onto the fabric sample and keep these in a note book for future reference. This will help you to remember what you need to change when you want to use that stitch type again.
And my last suggestion, if you can find a good sewing machine dealership or fabric store that runs classes, see if they run one for "introduction to overlockers" - I took a class from the Bernina dealer I bought my machine from back in 1992 and it was fantastic. I've used mine for bridal veils with fishing line, made table cloths, curtains, cushions, sewed dozens of knit garments for the kids and made most of my own clothes with my trusty Elna and this overlocker; its a very strong machine and better quality than many others on the market.
Oct 08, 2011 | Bernina Bernette 75
I have just been given a huskylock 341. The tension is off. How do I correct this?
Have you used an overlocker before? If not, I'd suggest that you obtain a user manual for it as they are completely different to a sewing machine and at some point you will need to rethread it. You can purchase one from here
This machine makes three and four thread seams, which is a combination of two needles and two loopers. For the three thread seam you can use either the left or right needle which gives you different sized seams. For the four thread you use both needles, one goes through the middle of the seam and the other is on the left side securing the seam. tally_girl_70.jpg On most overlockers you are able to move the cutting blade too and this will reduce or increase the amount of fabric being trimmed from the right side.
This page will give you some general information on sergers/overlockers too.
So adjusting tension is a matter of changing the tension on the top and lower looper threads to close up against the cut edge, or moving the blade over to make the seam a little wider or narrower. You may also need to finess the left needle tension so that the seam doesn't pull apart, I always test serge two layers and then pull open from the right side and see if the needle thread is showing (it will show a little bit but you dont want it so loose that it pulls open. Only tighten the needles in very small increments though, as you'll break threads and needles if you turn them up too tight.
Hard to explain without seeing what your machine is seaming now. But as a rule of thumb, start with all four tension dials (or 3 if doing a three thread seam) on 5. If the tension dials are correctly calibrated then this should give you a pretty good seam. You may wish to lengthen the stitches, I usually work with stitch length of 2.5 (same as your sewing machine stitch length) Stitch length will be a dial on the right side beside the flywheel or in front of the blade area. The blade adjustment should be a little knob near the blade area too. There will be a lower fixed blade and a moving upper blade which sits against the lower one, they work like scissors to trim the fabric. So to adjust the blade, you will need to take the pressure off the upper blade, then wind the knob to move it left or right.
Different weights of fabric will behave differently on the overlocker so you do need to adjust tension for each new project. For example, if seaming a jersey knit you'd use a four thread seam, this gives elasticity and strength and you can join two garment pieces with this seam. You'd probably make a 6mm or 7mm wide seam, the left needle will secure the fabric and the loopers will encase the fabric smoothly while the right needle secures them and gives extra strenth to the seam.
But on organza for example, I would make a very narrow three thread seam using the right needle as the organza will roll inside the overlocking if you cut the fabric too wide.
And on something like curtains I would neaten the edge with a wide 3 thread seam using the left needle to get a very wide seam, the fabric wont roll so you'd need to loosen the two loopers a little to smoothly encase the cut edge.
tally_girl_71.jpg For example, on this image above you can see that the looper threads are laying a little off the edge of the fabric in places, particularly the lower looper, (the side that looks like Y's where you can't really see the middle needle thread), so I would tighten the lower looper about .5 on its dial, then test again.
I hope that this makes sense to you, you will need to test serge, and adjust one dial at a time, test again and look at the result, then maybe adjust another thread until you are getting a smooth looking seam.
Sep 05, 2011 | Sewing Machines
I have a Singer Ultarlock 14U34 and need to know how to adjust the stitch width.
You can download a manual from this link,234b.pdf
Check page 16, changing the seam width is done by moving the cutting blade left or right and using only one needle. So if you want the narrowest seam, use the right needle only, remove the left one, and move the blade as far left as you can. Your manual says to turn machine off at the wall for safety, many overlockers will have a motor cutout when you open the front covers, but its good practice to turn off too. Then you put pressure against the upper moveable blade and swing it up out of the way and make adjustment to the lower fixed blade with a screwdriver in your kit (some overlockers it is a knob you move to move the blade position).
And reverse for a wide stitch, use left needle for 3 thread wide seam, and move the blade far right.
You can also use the 4 thread seam where you use both needles and trim up narrow but the seam will be heavier than a three thread.
Each time you make changes to the amount of fabric being trimmed, you may need to finess the upper and lower looper tensions to ensure the seam is tensioned enough to just meet on the cut edge of the fabric. This is the norm for overlockers, each fabric will behave a little differently so you need to test stitch and adjust a little. Your manual will explain this process too.
Sep 05, 2011 | Singer 14SH654
How do i adjust the loose thread on top? Using the 3 thread stitch the top loop is loose and bulging over edge instead of smooth with rest of stitches. Setting is set to recommended setting but is still...
I always adjust my overlocker stitch in several ways. I start test serging with the blade set right out to the right so that it "fills" the stitching. I'll set all the thread dials to the middle setting, ie. 5. Then I test serge, and check the stitch formation. If the needle is looping underneath, then I'll tighten it "A LITTLE". If the looper threads are lying off the cut edge of the fabric, then I'll dial both the top and bottom looper numbers up a little to make those threads tighter.
Each fabric behaves differently depending on its "hand" so the right stitch settings do vary, ie. organza is different to heavy weight cotton or denim. So if my inital setting is then "bunching" up the fabric within the stitching, I will then lower the numbers for the top and bottom looper to release the thread some. And if the fabric is very soft and light and still bunches up, then I will move the blade over to the left some, cutting a narrower edge within the overlocking so the threads lie better.
So revist the settings, check that the cones are flowing freely, thread is into the tension devices fully, then retest the stitching. If it is the top looper only that is looping off the edge, and not the bottom as well, and they are both set to the same number, then I'd be a bit suss about the tension dial.
Feb 28, 2011 | Singer 14SH654
I have a Baby Lock 5280E. Can you tell me how to set the machine for rolled hem?
Assuming you mean a narrow rolled edge:
  1. Remove the left needle and thread.
  2. Open both the front and side covers.
  3. Raise the presser foot and the upper knife to the highest position.
  4. Clear the stitch fingers.
  5. Push the stitch with former release lever and remove the stitch former from the lower knife base. (Don't lose it!)
  6. Turn the stitch with adjusting dial until the "M" on the dial matches the red indicator on the needle plate.
  7. Set the stitch width length to "M".
  8. Close the covers, lower the presser foot and the upper knife.
This gives you a narrow edge. To roll the edge, increase the tension of the lower looper (the green knob) about three numbers higher than normal.
Nov 03, 2010 | Baby Lock Evolve
I want to know which knob I use to make the stitching narrower
there are generally two variable controls .. one adjusts the stitch length (distance between stitches measured in stitches per inch) ... the second is stitch width .. that adjusts how far the zigzag moves left and right .. thats usually just a number from 0 to 10 or so .. 10 would be maximum width .. 0 would be used for straight stitch ..
so you need to adjust the stitch width control to make the stitching narrower .. the controls are called different things on different brand sewing machines .. if you have the brand and model number then there may be instruction booklets available ...
Jan 04, 2010 | Sewing Machines
Open Questions:
See all Brother 1034D Mechanical Sewing Machine Questions
Brother 1034D Mechanical Sewing Machine Logo
313 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
