Question about Mitsubishi WD-65733 65" HDTV
I have a WD-65734 with white spots. It started with one and currently have 15 spots. They are adding up slowly. What is the part that I need and where can I get it at? I tried reseting the set and that didnt work. Help please!!!!
    Guru:
  • 416 Answers
Your DLP chip is failing. The part number for the light engine is: 938P075050. This is going to cost a bit of money... if you have some TV experience, you could try to tear down the optical block and try to get some numbers of the DLP chip itself. Mitsi does not supply the DLP part number for service... they want the engine replaced. TVLampsForLess.com has the part for $450. I hope this was helpful, best wishes.
Posted on Apr 27, 2010
  • 1,476 Answers
Your light engine is going bad and needs replaced. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the problem, how to repair it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Ed Mitsubishi WD 65734 with some back dots on the screen? Bulb needs replacing or what do you suggest?
No a bulb would not cause this, you have serious PCB issues, like a shorted cap capacitor(s). Before you start spending money that may or not fix the set take a look at current flat screen prices, a Vizio 46" 4K for less than $400.
Aug 19, 2016 | Mitsubishi Televison & Video
I need a code for my samsun blue ray to be used with the Mitsubishi wd-65734 remote
The Mitsubishi has a list of its codes in the owner manual and also I think has a search mode---can try all possible codes one at a time.
No owner manual? Google the model number of set with "manual" if cannot find let me know with a comment here and I will try for you.
SD TECH
Apr 24, 2012 | Mitsubishi WD-65734 65" HDTV
Mitsubishi wd-65734 65 in. Tv shuts off on its own and red lamp light comes on. after a few minutes i can turn it back on and works fine for a few min to an hr before doing it again. anyone no wat the...
Same thing on my tv after replacing lamp. Lamp manufacturer advised me that after changing bulb, tv must be reset or tv will go into safety mode and will not turn on. To do this on my model WD-65734 you must hold reset button in with a pen or paperclip for about 10 secs.The LED will start blinking for a few mins. When itstops you need to unplug tv set for about 1 hour. After this the tv will be reset.
Apr 22, 2012 | Mitsubishi WD-65734 65" HDTV
Wd 65 733 I have read the posts arounf the white spots on screen. I currently have just a small amount popping up. Looking for cheap price on parts and labor. Thx Will in atlanta, ga
normally white spots are whithin the screen. it is also called "panel". it is the most costly part in the tv. but one need to inspect the tv first before making sure it need to be replace. try to disconnect all cables inside the tv by opening the back cover & fix them again.
Sep 22, 2011 | Mitsubishi WD-65738 DLP TV
WD-65734 Mitsubishi TV won't turn on. System reset
Are there any lights lit on the front of the TV? Have you checked for a bad lamp? When you reset the TV the timer/power light should flash on and off rapidly for 60-70 sseconds. Does that happen?
Aug 26, 2011 | Mitsubishi WD-62526 Projection TV
There are white spots on TV . Heard it can be the dmd chip. Can DMD Chips be ordered. Or can it be any other problem? Can it be repaired at home?
There is a very easy way to decide if it is your Digital board or your light engine. When you turn off your TV and the logo come up, are the spots still there? If they are then your light engine is bad and needs to be replaced. If they go away, then your digital board needs to be replaced. And yes you can get that board from just about anywhere.
May 05, 2011 | Mitsubishi WD-65734 65" HDTV
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
I have a 65" Mistubishi WD - 65734 and have no
Yes,"LAMP" LED light indication front of tv bazel frame is on or blinking,yes mean tv projection lamp life are over.The whole tv warrenty only for a year,tv projection lamp should last at leat 1 1/2 or 2 years,by tv been on and watches used it like 4 or 5 hours daily?U never done tv replacement parts,any kinds before?Yes,hire a tv Tech. to do it.Shop around for a Tv tech.should replaced the projection lamp for u shoud be around $250 to $300 that including part the projection lamp.
Jan 03, 2011 | Mitsubishi WD-65734 65" HDTV
How to reset lamp timer on mitsubishi wd-65734
This model there is no reset for lamp timer.
Nov 14, 2009 | Mitsubishi WD-65733 65" HDTV
Mitsubishi WD-65733 65" HDTV Logo
3,376 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
