Question about Mitsubishi VS-55601 55" Rear Projection Television
Picture has color separation and halos. Picture distorted.
Have tried hooking tv directly and bypassing DVD player. Another tv on this satellite is fine. Removed and replace all connections. Rebooted satellite. Turned tv off and back on. Picture is distorted and colors are separated. Picture resembles looking into an amusement park mirror.
  • 1,476 Answers
Your convergence is bad and you need to replace the convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating.
hardrocko
Posted on Apr 27, 2010
Alba tv dvd combi problem
Picture noise / distortion
  1. Disc is dirty or damaged. Clean the disc or try another disc.
  2. Reset the color system of the player or the TV set.
  3. Try a direct connection from the DVD player to the TV set, instead of via other components.
    Test the wires connector terminal from dirty and corrosion, clean it with contacts cleaner very well and try again.Use the Disk cleaner for clean the Pickup system
    God bless you
Feb 09, 2013 | Televison & Video
Color distortion when playing DVDs
If the player has other outputs try connecting the player to the tv using one of them, ie: use the A/V output instead of HDMI from the player. If the problem goes away there is something wrong with the input on the tv.
Mar 16, 2008 | Televison & Video
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
My polaroid fxm-1911c picture is distorted, sound distorted with loud buzzing when I try to utilize the tv signal input jack, also the dvd player doesn't work
Looks like there are some partial defects in the TV and might need attention of a qualified service technician. Anyhow, make sure that the input cable, RC jacks and sockets all do not have any loose contacts. Go through settings and ensure that every set up is as it should be.
Aug 02, 2012 | Polaroid FXM-1911C 19 in. LCD Television
I have a Hitachi Projection TV 51G500A 2004 ,
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Hitachi 51G500 51" Rear Projection...
Distorted color on hdmi output
If you haven't already stumbled across the fix: I just had the exact same problem after about eights months of casual use. Unplugging the DVD player for about 15 minutes and then plugging it back in "solved" the problem. Until next time it happens, anyway.
Apr 17, 2009 | Philips DVP5990 DVD Player
We have a philips up-grader dvd player and get color distortion
I would try hooking something else up to your tv that is hdmi compatible. If your tv looks fine, then you know it would be the dvd player. If it's the dvd player, then I would suggest getting a different brand completely. I have had alot of bad experiences myself and other people as well when it comes to the philips brand
Apr 07, 2009 | Philips DVP3960
Trying to record from TV.
TRY HOOKING THE COAX TO THE DVD RECORDER THEN TO THE TV ,BEST I COULD THINK OF.
Mar 27, 2009 | Cyberhome DVR 1600 DVD Recorder
Dull picture, whites have halos, need to watch tv thru dvd player
the picture color problem is the coolant in the CRTs. You can get the coolant replacemnt Kit at the following link. The other problem with the Input through DVD sounds like the signal board. You can get the replacement board and the Phillips CRT coolant kit at the following link.
http://servicemanuals.vstore.ca/
Sep 14, 2008 | Philips 60PP9202 60" Rear Projection...
Can't get the DVD connected to the TV directly without Cable or Satellite...
what brand is your TV and your DVD? Most TVs have a Audio In(put) and Video In(put) connection at the rear. Similarly, most DVD players have a Video OUT and Audio (L) and Audio (R) outputs at the rear. Now all you need to do take the supplied cable - or if you do not have one, buy a cable from radio shack - should not cost you more than 5$ - and connect the Video Out of the DVD player to the Video IN of the TV and Audio Out of the DVD to the Audio Input of the TV. On the TV, using the remote, select Video Input using the TV/AV button. Play your DVD machine, and enjoy your movies.
Apr 07, 2007 | Durabrand DWT1905 TV
Televison & Video Logo
267 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
