Question about Samsung DV328AE Electric Dryer
My samsung dryer is showing FE what does it mean
  • 6 more comments
  • aweleezeoke Apr 27, 2010
    Lee, thanks for ur advise. its not washer but dryer so i dont see where water comes in. the problem is that the unit is not coming on after it and nothing displays on the panel again.Awele
    The model no is DV328AEG. Thanks
  • aweleezeoke Apr 28, 2010
    Thanks, but my question now is do i also need to replace the panel because nothing displays on it even if u connect it to power supply or has the unit been damaged or do i just check the electrical connection?
    Thanks rylee, but nothing comes on if u press the power button so how will i know if the connection is working well before thinking of replacing the panel. nothing comes on when u press the power button but even if i have to change panel where do i buy it from? and do u know like how much its gonna cost me? Thanks
    i am overseas and i was told the dryer is 120 volts to 240 volts so my voltage in my country is 240 v so that is no problem but i think the freuency is 50hz while my country is 60hz . could that have caused a problem? is there a way to adjust this things. am afraid will it ever work. thanks
  • aweleezeoke Apr 29, 2010
    please where can i also buy the suitable surge protector from?
    Appreciate it rylee. u have been quite helpful . one last question the issue of 50hz or 60hz doesn't matter u feel it will be sorted once i get the panel and protector
    thanks a lot rylee, i will try all those out and hope it does work
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. FE error means overflow error or in some models its also Fan error. To start with you’ll need to check if water is overflowing. If this is the case then water level sensor needs to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Apr 27, 2010
  • 5 more comments
  • Rylee Smith
    Rylee Smith Apr 27, 2010
    Seems to be a power supply related issue, please post back with the model no# so that I can assist you further.
  • Rylee Smith
    FE error on you dryer means Power source frequency Error. You'll need to check for:- Not using regular power source frequency and/or Invalid power frequency sense circuit. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Apr 28, 2010
    Check the connections if that seems to be working fine then you have to replace the control panel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    To start with check the connections going to the control panel if all of them seems to be fine then you can buy the parts from this link.
  • Rylee Smith
    Dont think it might have caused the issue however, it can be fixed by replacing the control panel and in future you can use surge protector just to protect it from any kind of power issues.
  • Rylee Smith
    Rylee Smith Apr 29, 2010
    You can buy it from any local repair shops, let them know what you are looking for and they'll provide you with it.
  • Rylee Smith
    Yes right it doesn't matter, thats normal. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Why would a Samsung gas dryer, model DV400GWHDWR-AA cutout and show a FE code after about three seconds after pressing the start button?
Samsung Dryer Error Code = FE
Error Condition = Power supply out of range (frequency)
Check and or Repair = If the dryer is getting the power it requires then replace the electronic control panel board.
Parts For Replacement = Electronic Control Board
Sep 26, 2016 | Samsung Dryers
I get an FE code on my samsung WD0704RQQ short time after setting the machine on dryer mode. Please help as my manual doesnt have the code and its meaning.
http://appliancejunk.com/forums/index.php?topic=17042.0
I SUGGST REMOVING POPWER, SHUT OFF BREAKER, THEN RESET, IF IT DOESNT HELP IT WOULD NEED SERVICE
Apr 14, 2016 | Samsung Washing Machines
Code FE on samsung dryer??
Hello. The FE error indicates a problem with the incoming AC power. It means the frequency of the power (which is normally 60 Hz) is incorrect. Check the wiring to the dryer, also, is this unit from a foreign country where the power is 50 Hz? The dryer has line filtering built in--make sure the incoming power is correct and that the wiring to the dryer is correctly connected! Get back to me on what you find.Thanks!
Oct 31, 2015 | Samsung Dryers
How do I fix a fe code problem on a Samsung dryer
According to the Samsung website, here is the description of your problem:
FE
  • The FE code indicates a problem with the power source. Loose or incorrect wiring probably exists where the dryer connects to the power cord, or the power cord is the wrong type. If the dryer is hard-wired, it is possibly improperly wired. These kinds of repairs are dangerous for a novice, so contact an electrician or repair center.
Read more : http://www.ehow.com/list_7103891_samsung-dryer-error-codes.html
Dec 31, 2014 | Samsung Dryers
My dryer shows hE code what does it mean its a samsung
Samsung Dryer Fault Codes ts Thermistor short Check for restricted vent. Replace thermistor to Thermistor open Check for restricted vent Replace Thermistor do Door Open Check connections. Replace door switch. FE Power Source Frequency error Check power source dF Door circuit failure Check wiring to door switch. Replace door switch hE Heater error Restricted vent. Replace thermistor. bE Button Error Check and / or replace PCB od Over dry Sensor Bar open. Adjust time up excessively. Et eeprom failure Replace Eeprom
hE Heater error Restricted vent. Replace thermistor. Heater error
Clean vent and replace thermistor.
Clean all vents from outside all the way to the blwer housing. If you dont get all the lint it will cause this to happen again.
If you need further assistance please feel free to contact.
Jul 24, 2011 | Samsung WF203ANW Front Load Washer
I have a LG washer model WM2487 H*M suddendly water started coming out from underneath and also the front panel shows a light saying FE....I read that means something about is due the faulty water...
FE = Fill Error. Not a faulty water valve in your case. (FE codes if it takes too long to fill the machine, but if the water is leaking out, the valve is not the problem, the leak is) If you take the back cover off, you might be able to see where the water is comming from. Possibly the black rubber hose from the tub to the pump has a leak.
Mar 17, 2011 | LG WM2487HWMA Front Load Stacked Washer /...
What cause FE error on a samsung dryer
We did some extensive research and somehow found a service manual for our Samsung unit online. According to its section 4-1 "Error Items and Diagnostic Codes" the following is the problem:
(code) FE - (description) Power source frequency error - (Trigger) Invalid power source frequency - (Action taken) Check for: (a) Not using regular power source frequency (b) Invalid power frequency sense circuit.
In other words, either the thing you have plugged your machine into is faulty, the electricity itself is of poor quality where you live, or the sensor within the unit is faulty and giving an erroneous error code.
In our case, we had our machine hooked up to a cheap surge protector; which we thought might be the likely source of our problem in the light of the error code description above. So I tried connecting it to a commercial extension cord (I still got an FE code). So I tried moving the extension cord to another room's circuit, thinking maybe it was localized in the laundry room (I still got an FE code).
So, I am guessing we either have a bad "power frequency sensor" or the problem is due to the terrible electricity we have where we live (i.e. that the power frequency fluctuates too much due to our local power company's poor system).
Regardless, I hope this answer helps somebody with the "FE code" problem, now that you know what the code means.
Oct 26, 2009 | Samsung WF203ANW Front Load Washer
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Fe MEANING
It typically means that one of the water valves (that opens and closes to let the appropriate amount of water into the machine) is not functioning properly. It is frequently accompanied by a continuous flow of water into the machine (although with the drain pump also running you won't necessarily see any water building up inside the drum.) I believe the letters actually stand for "Fill Error."
Mar 17, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Samsung DV328AE Electric Dryer Logo
279 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
