Question about Coleman Powermate Powermate 5000W Generator
How to flash or remagnitize Coleman Powermate 6875 or Husky 40500
We bought a reconditioned Coleman Powermate 6875 November 2009.
We made sure that it started for a minute, then stored it until April 2010.
Now it has no output and will not even run a drill.
Does it need to be re-magnatized or flashed?
If so, how would that be done?
  • 355 Answers
Field Flashing of Portable Generators This tip comes from the Briggs & Stratton Customer Education Department. As an alternative to flashing a rotor winding with a battery applied to the brushes, an electric drill may be used. Follow these steps to flash the generator:
  • Plug the electric drill into the generator receptacle. (Cordless drills do not work)
  • If the drill is reversible, move the direction switch to the forward position.
  • Start the generator
  • While depressing the trigger on the drill, spin the drill chuck in reverse direction. This will excite the field and the generator will now produce electricity. If spinning the chuck one direction does not work, try spinning the chuck in the other direction as you may have the reverse switch positioned backwards.
Use caution not to get your hand or other materials caught in the chuck. As soon as the field is excited, the generator will produce power and the drill will turn on.
The reason this works is because the electric motor in the drill will act as a small generator when spun backwards. The magnets in the drill's motor induce a voltage into the motor windings, which is fed back through the trigger, cord and into the generators receptacle. From there it goes into the power winding of the stator. The voltage going through the power winding creates a magnetic field, which is intensified due to the iron core of the stator laminations. The rotor intersects this magnetic field as it is spun past the power winding, thus inducing a voltage in the rotor winding. Once current flow is present in the rotor winding the rotor has been flashed.
If flashing the field does not make the generator work, you may have additional problems, besides a lack of magnetism in the rotor. Further testing will be needed. Hopefully, this will give a simple way to field flash your generator if needed - Bruce Perrault
Posted on Apr 28, 2010
What spark plug does a Coleman Powermate 6875 use
Doesn't seem to be anything online. Phone them and ask.
Specs are here
http://salestores.com/colema21.html
Generator manual with phone number
http://www.powermate.com/generators/0062929_0706.pdf
Oct 05, 2016 | Coleman Electrical Supplies
What kind of oil do I use in the Coleman powermate 6875?
You can use numerous engine oils. 10W - 40, 30W Detergent, 30W Non detergent (SAE)
The best all around above 40 deg F and below 100 F oil to use is a 30W detergent oil. Brand name does NOT matter. Oil level should be checked EACH time you add fuel. Change oil any time the oil appears Dark BLACK when checked regardless of the hour intervals. .
Thanks for choosing FixYa,
Kelly
Aug 29, 2011 | Coleman Powermate Powermate 5000W...
Need a stater kit for a powermate generator 6875
You will need to contact a Coleman dealer to purchase any parts. Fixya.com has no resources to order or sell parts for any consumer product.
Jan 30, 2011 | Coleman Powermate Generator Start &...
What carb does the powermate 6875 use?
check this web site http://www.powermate.com/productmanuals.php?cat_id=3 you can down load the manual and parts list for your gen.
Mar 24, 2009 | Coleman Powermate Powermate 5000W...
Coleman 6875, Does it have an auto idle???
If you've got an auto idle function you'll also have a switch somewhere to shut it off, so look for that first.
Engine surging is almost always a problem somewhere in either the air cleaner or the carb. Check the air cleaner, if it's not dirty take the bowl off the carb and look for dirt in the bottom.
Regards,
Carl
Feb 02, 2009 | Coleman Powermate Powermate 5000W...
Add auto idle to generator
Your genny should already have this feature as it is part of the function to maintain the output voltage, if it isnt working I would look for a service manual for it and taker it from there as there can be many things that could prevent it from working properly
Dec 31, 2008 | Coleman Powermate 7,000 Watt 13 Hp...
Wont turn over
Check the oil level, these generators have an oil monitoring system that prevents the engine running if the oil isn't all the way up to the bottom of the threads in the oil fill hole.
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
COLEMAN POWERMATE 6875 11 HP GENERATOR
Hello, If your generator has sat for a long time, the residual magnetism in the field coil may have dissipated completely this will cause the generator to produce no electricity. If this is the case there is a fix that is so simple it will amaze you by how easy it is to get it running properly again. The process is called flashing the field and it is done with an electric corded drill. Here is a link on how to do it. http://www.perr.com/tip16.html I hope this helps. If my solution works for you would you kindly give me a positive rating. Thank you, Michael Burke
Nov 01, 2008 | Coleman Powermate Medium Generator Cover...
Coleman Powermate Powermate 5000W Generator Logo
2,220 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
