Question about GE (PSS26MSRSS) Side by Side Refrigerator
My GE side by side fridge does not dispense water because the line freezes up, how can I fix this? I was lucky enough to see a GE appliance repair man on my block and I told him that my water dispenser doesnt work, but the ice maker works. He said that my water line is probably frozen. So he told me to shutdown my fridge and leave the freezer door open for 2 hours. I did that and it worked, water starting dispensing. But the next day the line froze again, I need a permanet fix, please assist, thanks.
  • GE Master
  • 1,606 Answers
Install the water line heater to the dispenser , part number WR49X10173 . This comes with installation instructions .
Posted on Apr 27, 2010
    New Friend:
  • 8 Answers
Yes, the water line heater will fix it. It fixed mine.
Rumor has it this problem is caused by water vapor getting absorbed by the foam insulation inside of the freezer door, and then the insulation doesn't insulate as well, and the cold from the freezer reaches the water line.
However...about a year later, your problem will be back.
As time passes, it will absorb more moisture, and the heater kit will not work anymore. I've seen several posts where the problem came back, with no solution.
So here's your fix-ya:
Buy a second heater kit, and remove the foil sticky wrapper from the wire. The center portion between the black heat-shrink portions is the actual heater; the other end wires are normal wire.
Wrap the center portion tightly around right where the water tube comes out of the door, just below the ice dispenser flapper. Put some large heat shrink (not electrical tape - it won't hold) over the two existing heat shrink portions to hold the loop tight against the dispenser tube. I then put some aluminum foil tape, used for sealing duct work, over the loop and onto a portion of the dispenser tube, to hold it in place.
Connect it the same way electrically, so you now have two heaters in the circuit.
Then reassemble. You will need to take a Dremel tool to widen the hang-down actuator that your glass pushes on to dispense, around the dispenser tube. I needed about a 3/4" wide slot. This is because it will hit the coil of heater wire. Also be sure wires are out of the way behind this actuator as you reassemble everything, or the switch won't work reliably.
Mine had been frozen solid for a year, and it started working in the 2-3 minutes after I connected the front panel, which powers the heaters. Amazing!
The theory I used to come up with this solution is this: put gently heated air up the dispenser pipe, and it will steam the ice away. Voila!
Enjoy your water dispenser.
BTW, you can call GE and tell them your problem, and if you're kind and persistent, they will send you a free heater kit. Worked for me. Otherwise check eBay.
And yes, it's a very bad design, putting a water tube through a freezer door. What were they thinking?
Posted on Jun 15, 2015
Water dispenser in door does not dispense
Had this happen on my LG side-by-side a few years back. It's a common part. Find the version for your make and model. Easy ti replace. It is located where the water suppy connects to the bottm refridge.
http://www.amazon.com/LG-Electronics-MJX41178908-Refrigerator-Water/dp/B00AUDAJ0I
Oct 25, 2015 | GE Profile 26.6 cu. ft. Side-by-Side...
Water line keeps freezing on my GE side by side refigerator
Check to see if the water tank in the bottom of the refrigerator section is frozen. If it is, you will need to turn the refrigerator section temp down.
Dec 05, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser won't shut off nor will the ice dispenser motor
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Electrolux Refrigerators
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
No water thru door
I have a hotpoint fridge model HSS25GFPHWW. The ice maker/dispenser works, but the water dispenser quit a couple of months ago. I have good water supply & pressure to the appliance. Could the controlling electronics (mother board) be "half dead"?? If so, how much are new ones??
Mar 25, 2008 | Hotpoint HSS25GFP Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Dec 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
No water but ice is fine
I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Oct 28, 2007 | GE GSL25JFPBS Side by Side Refrigerator
Oct 11, 2007 | GE GSH25JFR Side by Side Refrigerator
Water dispenser not working
Mar 10, 2007 | GE GSH25JFR Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
577 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
